Just now, ThreePointFive said:
Nice, I've never seen earth straps that can double as recovery points before.
Chinook attatchment points........
Heard on the grapevine the military were interested in a steroid lightweight.........lol
Regards Stephen
4 minutes ago, Stellaghost said:
Had a couple of hours spare this afternoon so started having a look at rock slider
This is where I'm at, using 100 x 100 x 3mm angle iron, obviously this will be boxed when finished and provide a means to bolt the floor panels to
was thinking of riveting some thin aluminium checker plate onto the top once fabricated
thoughts ?
regards Stephen
Looks good,  why not weld some webbing over the top?   In my mind way better to look at
  • Thanks 1
27 minutes ago, hurbie said:
weld on a small strip off steel checker plate , much more in line with your fabrication.
Could do, I'm thinking I may need something just to grip on when climbing in as it's around seven inches higher than it was before but I will get it fabbed up first and see what it's like getting in an out and make a decision based on that
Regards Stephen
3 minutes ago, ThreePointFive said:
In that case, I would go with someting like grip tape, given how terrible chequer plate is for stepping on.
Hmmmmm, some nice orange grip tape available on the bay, cheap enough to try and throw away if not suitable
Regards Stephen
  • Like 1
Looking good - I'd add my vote for grip tape although black would be more tasteful than orange!
Also as Dirtydiesel did on my rock sliders, a couple of ridges under each end (I think he welded 10mm bar width-ways) for a hi-lift to engage on is a decent little addition too.
  • Like 2
They are already in my build plan as I had read that on the forum somewhere, might have been yours
regards Stephen
