7 hours ago, landroversforever said:
Brake caliper mounts?
So trying to sort the above out
This is how it was
pieces cut away to get rims on
addition of coil pack holders, space invader, toast rack and chassis step notch
drilled and tapped
more or less complete
regards Stephen
  • Like 3
If you can remember the horse shoe brackets I made to hang the calipers off, the first photo shows the top of them brackets cut off to allow 17" rims to fit when moved inboard
The new brackets are to tie everything back in again so it still has the original strength because all portal box fastening points are connected again
Hope that makes sense
Regards Stephen
  • Like 1
  • Thanks 1
Do you sometimes wish you hadn't started something, I'm nearly at that point with fitting the rims to the axle
Trying to tie the caliper brackets in at the top of the portal box has caused me a lot of issues, although it wouldn't be an problem if width wasn't an issue
On my previous post wheel was not tried due to other priorities last night, so got up get wheel on and it turned to rat poop
So this didn't work
why ? Wheel rim catching
so this is where I'm at now
Cap heads drilled out or countersunk to fit
rim no longer catches but it is very tight
If it becomes an issue I can always space rim out a bit
Regards Stephen
  • Sad 1
Due to tight tolerances I also modified the brake connections  and re-routed the pipe
Small angled connection made with copper pipe
Brake pipe routed to the front of the rear axle instead of running along the back, this will give the braided hose more protection
regards Stephen
  • Like 2
17 hours ago, Bowie69 said:
If I am honest, I'm not entirely sure what I am looking at, some bracing for the portal box or something?
Pictures below explain better than me
Regards Stephen
  • Thanks 1
Crikey that's all very close - I had similar pain with my callipers although thankfully it was only the callipers / wheels that got adjusted, looks like yours is in danger of encroaching on the axle itself which is a real pain :blink:
It is a pain, I'm reluctant to hack more of the axle housing away as that will weaken the axle / portal box ends, if it becomes an issue I can put spacers in to move wheel away from the axle slightly, in fact I may just make them anyway so they are already available if I need them
Regards Stephen
I had this problem with my conversion. I know we’ve gone slightly different routes but I ended up welding a 10mm spacer to each hub. That buys loads of clearance for your brakes but is nothing on overall width
On 7/3/2020 at 9:37 AM, landroversforever said:
Still follow that thread after you put me onto it Ben! :D  Even pinned to my browser.
......only 4 years late to respond to your comment!!!  :)
Still plugging away on the 1972 K5 Blazer.  The axles are a hybrid Unimog404 portal box mounted to a Ford 9" centersection.... this allows the gearing to be brought WAY down (from 7.56:1 to 5.26:1) by swapping gears in the 3rd member, and makes the packaging of the axle simpler by removing that long pinion snout as well.
Haven't done much "axle specific" work lately, but still need to get them measured for lockers, axleshafts and get the plumbing for the CTIS completed.   It's not easy being a one-man-show.... everything takes forever.
Cheers!
-G
  • Like 4
I humbly disagree with that statement.........lol
Regards Stephen
  • Haha 1
Completed all 4 axle ends and brake pipe mods tonight, so wheels now turn great, close tolerances mind, however I have a plan if that becomes an issue
Calipers and axle end now double up as a internal wheel scraper to stop the build up of mud etc....lol
Also looking at a spare wheel carrier, that will lift the wheel off the deck and also swing away to allow access into the rear tub
Regards Stephen
  • Like 2
Cheers!
-G
Welcome to the forum Greg!
  • Like 1
Cheers!
-G
Nice work!
I’m with the others - working by yourself is far more peaceful, less chaotic and more cathartic.  Of course, the best situation would be to work alone but have four arms…
  • Like 1
Cheers!
-G
This looks cool!
I'm sure we'll all be up for a build thread on this one!
Steve
  • Like 1
Don't shoot me yet......
Just having a play about
Below is part of my spare wheel containment, swing open and pivot down holder
Thoughts appreciated as always
regards Stephen
  • Like 2
22 hours ago, Stellaghost said:
And another one
Turned my head onto this
just missed out on an x marks the spot for scarring.......lol
really need to buy a bump cap
regards Stephen
Paint that pink or safety yellow😁
regards Stephen
Land Rover spider webb it is!  Can't wait to see the swing/fold mechanism taking shape
  • Haha 1
regards Stephen
My 'Spidey Senses' are tingling.
Regards, Mark
  • Haha 1
regards Stephen
Please tell us you won’t be wearing a tight blue and red lycra onesie while driving.
  • Haha 4
  • Sad 1
