western Posted March 13, 2020 Share Posted March 13, 2020 On the way home from work, a bit of a clunk & some screeching from below floor in gearbox area, after dropping front diff oil & checking the magnetic drain plug, all was good, so refilled with fresh oil, rotated both props as the screech sounded like a dry UJ, but these were all good & were lubricated while under the 110, so next stop was remove the transfer box fill/level plug this is a magnetic one as well, Oh lots of bits, looked like a heavily loaded Xmas tree, cleaned it off & found some of the bits in first photo, so next was drain the oil & drop the big sump off the transfer box, second photo & as it came off some more bits dropped out, the inside of sump was covered in bits of something, so once the oil finished draining, I found the intermediate gear sitting a bit cock eyed, & looks like the rear bearing on the shaft has failed, so made the short video. next job is to remove the transfer box & then remove the intermediate gear & its shaft, I'm hoping the damage is just to the rear bearing Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 13, 2020 Share Posted March 13, 2020 I hope you stopped in time to protect the teeth of the intermediate gear ... Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2020 Author Share Posted March 13, 2020 (edited) managed to get 110 on my driveway, all the gear teeth look OK, didn't see any parts of gear teeth fall out. Edited March 13, 2020 by western video edited Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 13, 2020 Share Posted March 13, 2020 That's definitely not good Did you get any warning @western? Amazed it kept going! Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2020 Author Share Posted March 13, 2020 Only the noise mentioned & a bit of a clunk, trying to upload a short video to my YouTube so I can link it to here. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 13, 2020 Share Posted March 13, 2020 Crikey, I think you were jolly lucky it didn't just stop. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 13, 2020 Share Posted March 13, 2020 Let's hope there was sufficient movement in the bearing to allow those rollers that have clearly been between some teeth to pass through without chipping anything. How many miles on this box, Ralph? I'm sure you have it noted somewhere :p Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2020 Author Share Posted March 13, 2020 it was fitted 30/3/2008 at 399420 miles, so its done 107715 miles up to now. in 12 years. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 13, 2020 Share Posted March 13, 2020 1 minute ago, Bowie69 said: ... that have clearly been between some teeth to pass through without chipping anything I don't think so. It would have stopped immediately if a roller had been between the teeth Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 13, 2020 Share Posted March 13, 2020 If the surfaces of all teeth are ok, it will be done with a new shaft and new bearings. On the other hand it's not really young ... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 13, 2020 Share Posted March 13, 2020 I'd also check the case itself Ralf . where the shaft goes through as the holes can elongate and give play in the shaft , Ashcrofts do a machined sleeve that fits in the case , just in case . Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2020 Author Share Posted March 13, 2020 Once it off the 110 & I can get the intermediate shaft & gears out, If the case is damaged, then I'll go for a replacement unit. then I know everything inside is fine. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 13, 2020 Share Posted March 13, 2020 check thrust washers in the diff as well Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 13, 2020 Share Posted March 13, 2020 I just ordered a LT230 at Ashcroft with sleeved casing, ATB diff and 1.1 ratio ... it will arrive soon 👍 Quote Link to comment Share on other sites More sharing options...
steve b Posted March 13, 2020 Share Posted March 13, 2020 I think , with the amount of fine debris in the bottom of the pan and the hammered look of the rollers , a full strip down and cleaning of all bearings might be wise ? In reality I'd be thinking about a re-con exchange unit ... the gear train will not have enjoyed any part of the failure . cheers Steve b Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2020 Author Share Posted March 13, 2020 it only gave up today in the last 1/2 mile from home, but it did whine a little & had new fresh EP80 put in a few months ago. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 13, 2020 Share Posted March 13, 2020 3 hours ago, ianmayco68 said: I'd also check the case itself Ralf . where the shaft goes through as the holes can elongate and give play in the shaft , Ashcrofts do a machined sleeve that fits in the case , just in case . I do them as well, just for info. 2 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 14, 2020 Share Posted March 14, 2020 7 hours ago, vulcan bomber said: I do them as well, just for info. Nice to know as I’m not far from you 👍. 1 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 14, 2020 Share Posted March 14, 2020 (edited) from experience the LT230 tolerates a lot of abuse, I stripped one which had been running for unknown thousands of miles with intermediate gear circlips collapsed so intermediate gear was loose on shaft with no adverse affects on gear teeth. Just finished this LT230. Previously reconditioned not very well (company unknown), had just been chucked together with no regard to correct shimming. Now has sleeved casing, Q gear set, hardened intermediate shaft, late diff housing and shift dog with enlarged splines, one piece Ashcroft diff spider and Timken bearings throughout, shimmed and set up correctly. Edited March 14, 2020 by oneandtwo Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 14, 2020 Share Posted March 14, 2020 I've got three words for anyone reading this thread: MAGNETIC DRAIN PLUGS! You can get gen parts for some things, Nige sells some insanely strong ones (surprise!), or any hydraulics shop should be able to sell you one with a magnet in. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 14, 2020 Share Posted March 14, 2020 2 hours ago, FridgeFreezer said: I've got three words for anyone reading this thread: MAGNETIC DRAIN PLUGS! You can get gen parts for some things, Nige sells some insanely strong ones (surprise!), or any hydraulics shop should be able to sell you one with a magnet in. Every lt230 ever made comes with magnetic drain plug anyway Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 14, 2020 Share Posted March 14, 2020 14 minutes ago, oneandtwo said: Every lt230 ever made comes with magnetic drain plug anyway I can only assume I've had ones where a plug has been replaced then, because I've definitely had ones without. Same goes for any drain plug though - sump, diff, gearbox. Quote Link to comment Share on other sites More sharing options...
western Posted March 14, 2020 Author Share Posted March 14, 2020 This transfer box & both axles have magnetic plugs from xcess4x4, there is no damage on the gears inside, Video will appear later. Found this bit of damage on rear bearing carrier, the gear that sits on main gearbox shaft is fine too Quote Link to comment Share on other sites More sharing options...
western Posted March 14, 2020 Author Share Posted March 14, 2020 Quote Link to comment Share on other sites More sharing options...
Vogler Posted March 14, 2020 Share Posted March 14, 2020 7 hours ago, FridgeFreezer said: MAGNETIC DRAIN PLUGS! Coulnd't agree more. Three front crown wheel bolts of our 110 broke and chipped some teeth. The drained oil showed nothing but literally one tiny single flint, despite the presence of plenty of shrapnel in there. With magnetic plugs I wouldn't have suspected and disassembled the LT230. 11 hours ago, oneandtwo said: shift dog with enlarged splines, Out of curiosity: who supplies these? 2 hours ago, western said: Amazing that all teeth survived. Have you had the opportunity to check the condition of the intermediate shaft holes yet? Greetings Joris Quote Link to comment Share on other sites More sharing options...
