Lightweight vent panel and bulkhead build
Stellaghost
13 hours ago, Ed Poore said:
I'm disappointed - I thought you were going to start fabricating a bulkhead out of that plate. <_<
For a moment there I did wonder if he was about to build a lightweight armour-plated aluminium bulkhead :ph34r:
Watching with interest... as if I'd ever have the time or skill to do it :lol:
  • landroversforever changed the title to Lightweight vent panel and bulkhead build
Put it this way - you'd have the skill once you'd finished...
To be fair I think the biggest advantage Stephen has over us is a good scrap pile! I've been slowly accumulating mine and it's surprising once you've got some stock how quickly and easily you can start to knock things together. I built a link box for the back of my little tractor out of scrap, built a quick-remove concealed bike rack for my sisters old house out of scrap I had lying around.
  • Like 1
On 6/30/2022 at 10:16 AM, FridgeFreezer said:
 :ph34r:
Don't worry about the skill just follow @Ed Poore advice
The better the scrap pile the more skill you will have.........
If that makes sense....lol
Right I'm away to buy 30 tonnes of scrap...
Regards Stephen
Had another couple of goes at pressing, this time with annealed test pieces
First press, not happy with it
, did not have it centralised
now I'm very happy, it's pressed a treat, what do you guys think regards Stephen
  • Like 2
7 minutes ago, Maverik said:
It looks pretty good - for comparison have you got a pic of the steel equivalent to hand to compare against? :)
As requested,
The sides aren't as steep as the steel one, but that was homemade using a cover from a motor junction box regards Stephen
  • Like 1
First stab this morning at making full hinge panel
One thing I have learnt is softwood is no good as a bending template, will make steel ones later in the week
Couple of sheets of 2mm aluminium annealed
Wooden template made
sheet pressed and cut to shape
Clamped in-between formers
Flanges hammered and removed from former
For comparison
I'm reasonably happy with that, steel formers will make corners on folds a wee bit sharper or I may try folding in my gabro although I need the formers for the curved flange at the top
Once the corners are tigged up, blended and painted should be not to bad at all
Regards Stephen
  • Like 3
Mk2 panel in the press
again pressed OK, you can see where the edge has rippled with the stretching process
a wee bit of planishing later it's not too bad, that section folds over at 90 degrees so all good, now to make steel formers, not happy with wood ones regards Stephen
  • Like 3
Steel formers made and mk2 panel formed
20220716_164357.thumb.jpg.cdf247c37f25c108ae4644460fedf327.jpg20220716_165840.thumb.jpg.3d67bc1bd6d0d64ca32ecbd0ed16a014.jpg
Clamped and hammer forming around Steel dies
Curved section needing a wee bit more work than straight sides
completed panel
mk1 and mk2 side by side, one on the left is mk2, I think it looks a wee bit sharper, what do you guys think regards Stephen
  • Like 4
