Shielder or terrain tech bulkhead ?
1 hour ago, Anderzander said:
I’ve read about people putting a frame on their bulkheads when they go for galvanising to control warping .. any suggestions on that? Would you just pick up the chassis mounts across the bottom ? or do something more?
I wouldn’t mind cosmetic things - but would like it to fit again.
Thats all I did regarding bracing. I havent fitted mine yet though so I dont know if it has warped! I couldnt see anything else to brace!
Edited by reb78
  • Thanks 1
  • 2 months later...
Gents:
An update on the project to replace the Defender TD5 bulkhead.
Replacement galvanised bulkhead has been received from Shielder and the TD5 was picked up before Christmas by LR specialist
Here are some pics that I have got back showing the bulkhead that is being removed.
Vehicle is 2004 and has spent the last 10 years sat outside in the Scottish rain.
1724185283_TD5pic(5).thumb.jpg.9b757dea00c0be20d9e13a3066519406.jpg2008696431_TD5pic(4).thumb.jpg.aefcf420b099ab5fac53e63b4ac0c85d.jpg
2020154148_TD5pic(3).thumb.jpg.66ef1608f66e32ce5a41b4d22dc81347.jpg1444308785_TD5pic(2).thumb.jpg.be9ec0ebf63f3c925b69dca0fc7ed431.jpg
  • 3 weeks later...
On 7/23/2021 at 6:19 PM, steve b said:
Yeah , that was my point - why bother putting them up with all the same "fill in blanks text" and then stick names on them ?
Anyhoo , that's most likely web designer stuff slipped through proof check , more interested in the product .
I know the guy starting up the business and got him to send an actual photo. He has been quite busy getting set up and making tools etc. Hopefully you can see the end product clearly 5A4F8169-E1C7-4954-89B9-55187E6F46F2.thumb.jpeg.5ed92e797aaac2062b1769ea960e7882.jpeg
OK, I'd be up for giving him a try and a fair review as well.
Are they galvanised? And can you give me his/your name so I can at least have an intro when I call him? (PM if you prefer)
Cheers,
Simon
Just a hint: If holes are (almost) closed with zinc from galvanisation, don't drill them. The surface might get hurt and pure iron will be seen again. Heat the zinc with a blow torch to melt the zinc and blow them free with compressed air. Sometimes it works with a hotwind. All the surface will stay covered with zinc reliably and you don't have to paint these areas with zinc spray.
