Bowie69 Posted August 23, 2023 Share Posted August 23, 2023 They are cool things! And quite pricey if I remember right... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 23, 2023 Share Posted August 23, 2023 12 minutes ago, Bowie69 said: They are cool things! And quite pricey if I remember right... Good ones are - but these days thanks to the 3D printer & DIY CNC crowd you can get surprisingly cheap ones too that tend to be way better than they have any right to be. Seen a few folks upgrade old or cheap lathes & mills with them. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 23, 2023 Author Share Posted August 23, 2023 11 minutes ago, Bowie69 said: And quite pricey if I remember right... From what I've found up to now your right, thankfully this is already mine and the good news only £11 for a hundred new balls to get it functioning again Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 23, 2023 Author Share Posted August 23, 2023 Just now, FridgeFreezer said: Seen a few folks upgrade old or cheap lathes & mills with them. It is one of the debates on forums dealing with Bridgeport mills, probably other machines as well It is supposed to be a fantastic upgrade Regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 23, 2023 Share Posted August 23, 2023 48 minutes ago, Stellaghost said: I now know they are called ball screws, never seen and never heard of them You genuinely surprise me that you hadn't heard of them! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 23, 2023 Author Share Posted August 23, 2023 3 minutes ago, Ed Poore said: You genuinely surprise me that you hadn't heard of them! Please don't think less of me ..........lol Never ever been on my radar, but every day is a school day and it's nice to get some surprises now and then Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 24, 2023 Share Posted August 24, 2023 I guess your kind of ballscrew is made up of huge steel wheels rather than tiddly ball bearings. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 29, 2023 Author Share Posted August 29, 2023 So bridgeport cross slide sorted, very fiddly I must say but sorted all the same new ball bearings fitted mill working great again Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted November 13, 2023 Author Popular Post Share Posted November 13, 2023 Quite a few of us will have changed big end shells, not too bad a job, so I thought I would post this white metal bearing change ( think massive shells ) Old bearing had failed causing white metal to wipe, my foot to give perspective New one to be installed, these are supplied round and oil lead has to be scraped in on the white metal surface, hence the need for bearing scrapers ( I know this makes you happy @Nonimouse ) this is what it is getting fitted onto lifted to allow bearing to be slid out bearing slides in here trunnion that sits on it bearing half weighs around a ton, ring in the middle is an oil lifter regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 13, 2023 Share Posted November 13, 2023 Wow! Impressive machinery. The oil lifter - is that just like a set of buckets set into the collar that simply scoop oil up at the bottom and pour it as they pass over the top? Simplicity is elegance… Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 13, 2023 Author Share Posted November 13, 2023 Just now, Snagger said: Wow! Impressive machinery. The oil lifter - is that just like a set of buckets set into the collar that simply scoop oil up at the bottom and pour it as they pass over the top? Simplicity is elegance… That is exactly what happens regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 14, 2023 Share Posted November 14, 2023 Stephen what does the machine that is off, actually do? Quote Link to comment Share on other sites More sharing options...
steve b Posted November 14, 2023 Share Posted November 14, 2023 looks like the (concrete) kiln maybe? Steve Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted November 14, 2023 Author Popular Post Share Posted November 14, 2023 5 hours ago, Nonimouse said: Stephen what does the machine that is off, actually do? 6 minutes ago, steve b said: looks like the (concrete) kiln maybe? Steve It is a cement mill, clinker and gypsum in one end, ground into cement through two Chambers, first one containing a mix of 70 upto 90mm balls, second chamber is three times longer containing a mix of 17mm to 20mm balls for the finishing grind. Total weight including shell around 150 tonnes Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted December 12, 2023 Author Popular Post Share Posted December 12, 2023 To finish this off, cement mill back up and running 20231212_182428.mp4 Regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted December 13, 2023 Share Posted December 13, 2023 How long was it down for and what will you do to recover the lost output? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 13, 2023 Author Share Posted December 13, 2023 1 hour ago, Peaklander said: How long was it down for and what will you do to recover the lost output? It was down around 8 days, you never really recover the lost output because increasing the mill throughput would affect quality. You just have to have full storage silos to cover unplanned outages Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted March 19 Author Popular Post Share Posted March 19 Picture from inside the kiln and also the kiln inlet regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Stinkfloyd Posted March 19 Share Posted March 19 (edited) 3 hours ago, Stellaghost said: Picture from inside the kiln and also the kiln inlet regards Stephen Too busy taking photos to get the mill 1 inlet mods done I see 😉 Edit: to anyone working sees the torrent of abuse I will get from this comment.. don't worry, it is exactly what I expect. 😂 Edited March 19 by Stinkfloyd 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 19 Author Share Posted March 19 1 hour ago, Stinkfloyd said: Edit: to anyone working sees the torrent of abuse I will get from this comment.. don't worry, it is exactly what I expect. 😂 Who !!!! Me........ Right you little B............... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Arjan Posted March 19 Share Posted March 19 Love this sort of posts ! Thanks Stephan. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 19 Share Posted March 19 What are the tyre tracks from? I'm assuming not Sid Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 19 Author Share Posted March 19 1 hour ago, Bowie69 said: What are the tyre tracks from? I'm assuming not Sid Small telehandler for carrying pallets of bricks up kiln, also large bobcat with profiled bucket to match kiln diameter, makes it easier to lift rubble out Regards Stephen 2 1 Quote Link to comment Share on other sites More sharing options...
