L19MUD Posted January 6, 2022 Share Posted January 6, 2022 I have just dropped my engine and gearbox into my new Richards chassis. When fitting the steering box I have probably only 2-3mm of clearance. Looking at another 300tdi there should be more like 15mm I think The engine mounts have no adjustment in them but the front drivers side (RHD) does appear to be twisted forward slightly. The gearbox mount on that side had to be pushed with a bar to get into the rearmost of the slotted hole. Do the gearbox crossmembers normally come with slotted holes to allow for adjustment? Mine has just got normal holes Has anyone else experienced this? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 6, 2022 Share Posted January 6, 2022 If you've got your old chassis, can you take some measurements? Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 6, 2022 Author Share Posted January 6, 2022 Yes I can, the issue however is that my chassis was a 200tdi chassis that was later swapped to a 300tdi in the standard 300tdi position so welded on mounts might not have been quite right anyway. Quote Link to comment Share on other sites More sharing options...
steve b Posted January 6, 2022 Share Posted January 6, 2022 You're welcome to measure the 300 tdi 110 chassis I'm working on now and the old rusty one is still here too . I've also got the front calipers (vented) off it too - new ones going on the build Steve Quote Link to comment Share on other sites More sharing options...
pat_pending Posted January 6, 2022 Share Posted January 6, 2022 What steering box have you got? 6 bolt Gemmer boxes are bigger than the 4 bolt Adwest and were never fitted to 300tdis. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 6, 2022 Author Share Posted January 6, 2022 21 minutes ago, steve b said: You're welcome to measure the 300 tdi 110 chassis I'm working on now and the old rusty one is still here too . I've also got the front calipers (vented) off it too - new ones going on the build Steve Thanks Steve. Will drop you a PM Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 6, 2022 Author Share Posted January 6, 2022 10 minutes ago, pat_pending said: What steering box have you got? 6 bolt Gemmer boxes are bigger than the 4 bolt Adwest and were never fitted to 300tdis. Standard 4 bolt Adwest box Quote Link to comment Share on other sites More sharing options...
pat_pending Posted January 6, 2022 Share Posted January 6, 2022 Oh well, worth an ask, I remember thinking I'd have to swap to an Adwest when I considered replacing my 200tdi with a 300. I found this picture and it appears there should be plenty of clearance. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 6, 2022 Author Share Posted January 6, 2022 2 minutes ago, pat_pending said: Oh well, worth an ask, I remember thinking I'd have to swap to an Adwest when I considered replacing my 200tdi with a 300. I found this picture and it appears there should be plenty of clearance. Certainly a lot more clearance than I have. Looking at that the engine is much higher than mine in relation to the steering box. I did not change the engine mounts as they looked fine but now wondering if that is the cause. Worst case I could pack them up to lift the engine Quote Link to comment Share on other sites More sharing options...
pat_pending Posted January 6, 2022 Share Posted January 6, 2022 I think you need to have a run over it with a tape measure against a genuine 300 chassis. Something's wrong and if it's on the chassis, Richards should put it right. The rubbers would have to be totally shot to reduce that clearance. 2 Quote Link to comment Share on other sites More sharing options...
Crashbanggg Posted January 6, 2022 Share Posted January 6, 2022 I spent a lot of time on my recent 110 300tdi chassis rebuild from Richards scratching my head as to why nothing seemed to be sitting quite right. Turns out they had drilled the holes in the chassis for the gearbox cross member in the wrong place. They sent me modified crossmember to counteract the incorrectly drilled holes in the end. Richards were very helpful in resolving the matter (despite me initally assuming it was something I'd messed up), but certainly pretty frustrating and a lot of wasted time. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 7, 2022 Share Posted January 7, 2022 Brother in Laws mate had same problem with a 200 Tdi 90 chassis from them. The mounts were in the right place, but were set slightly further apart. ISTR that the actual mount brackets were a bit smaller, and this had the effect of dropping the engine down. It doesnt take much. Solved by making some packers out of 8mm plate. 300 mounts are flatter (more horizontal) though, so this fault wouldnt have quite the same effect. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 7, 2022 Author Share Posted January 7, 2022 10 hours ago, Crashbanggg said: I spent a lot of time on my recent 110 300tdi chassis rebuild from Richards scratching my head as to why nothing seemed to be sitting quite right. Turns out they had drilled the holes in the chassis for the gearbox cross member in the wrong place. They sent me modified crossmember to counteract the incorrectly drilled holes in the end. Richards were very helpful in resolving the matter (despite me initally assuming it was something I'd messed up), but certainly pretty frustrating and a lot of wasted time. Not ideal and not good to hear! The other two chassis I have had from them have been fine with no problems Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 7, 2022 Author Share Posted January 7, 2022 1 hour ago, smallfry said: Brother in Laws mate had same problem with a 200 Tdi 90 chassis from them. The mounts were in the right place, but were set slightly further apart. ISTR that the actual mount brackets were a bit smaller, and this had the effect of dropping the engine down. It doesnt take much. Solved by making some packers out of 8mm plate. 300 mounts are flatter (more horizontal) though, so this fault wouldnt have quite the same effect. I am beginning to think the mounts are too low but in the right place. I will measure up all the critical points and then compare that to the genuine chassis that Steve B has at the weekend. I do have another 300tdi locally to me that I look after but will be easier measuring something up that is already stripped of bodywork I don't really understand how they can get this sort of thing wrong though? Surely they have a jig for all of this and every bracket/weld should be in exactly the same place each time? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 7, 2022 Share Posted January 7, 2022 1 hour ago, L19MUD said: I don't really understand how they can get this sort of thing wrong though? Surely they have a jig for all of this and every bracket/weld should be in exactly the same place each time? I wonder if its a jig that does multiple different things and was used in the wrong manner. It does seem strange! Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 7, 2022 Share Posted January 7, 2022 One of the many faults on my new chassis (different well know supplier) was the engine mounts and gear box cross member with transmission mounts being in the wrong places - all are an inch or so too far aft, and that caused a lot of knock on issues. As far as I know, mine was their last 109 chassis, presumably because those faults, plus the misalignment of the rear spring shackle hangars, front dumb iron spring bolt holes and all the tub support hoops showed their jig was useless. Just because a chassis has come from a well renowned supplier and was built on a tried an trusted jig, it doesn’t guarantee anything. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 7, 2022 Share Posted January 7, 2022 14 minutes ago, Snagger said: As far as I know, mine was their last 109 chassis I wonder how many they had made before yours and if they were originally built to the correct specification? It's not unusual for jigs and fixtures to wear but to 'move' that far is surprising at least. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 7, 2022 Share Posted January 7, 2022 The hoop line was really crooked, uneven side to side but over 2” too high for the front most hoops. My guess is that it had been bent by some sort of accident, not wear. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 26, 2022 Author Share Posted June 26, 2022 OK so to update what I did to clear the power steering box. I just added some 10mm plate under the RH mount and managed to get enough clearance. However the problem has reared its head again. My viscos fan won't fit by about 25mm, that is a huge amount To recap this is a 300tdi discovery engine in a Richards chassis that is new. I have checked and the engine mount locations appear correct to other 300tdi's I have measured, also the Discovery and Defender engine mounts are identical part numbers. This takes me to the gearbox mounts. The Discovery 300tdi appears to use the older style mounts that carried from the 200tdi so I am now pretty confident from pictures online of part ANR2898 and ANR3225 that I have the right gearbox mounts too. What is now playing on my mind is the comment from Crashbangg above.... On 1/6/2022 at 10:28 PM, Crashbanggg said: I spent a lot of time on my recent 110 300tdi chassis rebuild from Richards scratching my head as to why nothing seemed to be sitting quite right. Turns out they had drilled the holes in the chassis for the gearbox cross member in the wrong place. They sent me modified crossmember to counteract the incorrectly drilled holes in the end. Richards were very helpful in resolving the matter (despite me initally assuming it was something I'd messed up), but certainly pretty frustrating and a lot of wasted time. This could be my answer. Need to go and get the tape measure out @Crashbanggg did they give you any measurements to check? Quote Link to comment Share on other sites More sharing options...
steve b Posted June 26, 2022 Share Posted June 26, 2022 What's the clearance between the top of the gearbox and the tunnel flange on the seat box ? Steve Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 26, 2022 Author Share Posted June 26, 2022 6 minutes ago, steve b said: What's the clearance between the top of the gearbox and the tunnel flange on the seat box ? Steve It is almost touching at the top. 1mm gap. Remember I used a template to make a new flange for the seatbox and then fitted a genuine tunnel which did then fit fine. I am guessing it should be a lot more than that? Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 26, 2022 Author Share Posted June 26, 2022 My issue is I feel like I have no known good point to compare to Quote Link to comment Share on other sites More sharing options...
muddy Posted June 26, 2022 Share Posted June 26, 2022 What measurements would you like? I have an old and new 300 TDi chassis sat here. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 26, 2022 Share Posted June 26, 2022 (edited) A couple of dimensions from the 300Tdi 110 sw I'm part way through building onto a GKN chassis A straight edge across the underside of the main rails under the hand brake drum , gap is about 2 - 3 mm A level on the back of fifth gear housing at the highest point to the top of the seat box forward mounting bracket (floor level give or take a couple of mill) 190mm Front to back position , rear of front cross member to front face of crank pulley/damper 115mm Minimum clearance between PAS box and cam belt chest 20mm Edit to add , transfer box mounts are welded to the chassis Steve Edited June 26, 2022 by steve b Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 27, 2022 Author Share Posted June 27, 2022 Thanks Steve. I will check against those measurements Quote Link to comment Share on other sites More sharing options...
