Mossberg Posted February 13, 2022 Share Posted February 13, 2022 Just a quick question on painting hub faces - do or don't? I want to minimise future rust so want to know if it is a good idea to paint the hub faces. I was going to leave them bare and just put anti seize on it as I thought the paint may bind hub and wheel. So what are your thoughts please? As always, thanks for your help and advice as I am finding it really helpful as I start the maintenance on my defender. Mick Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 13, 2022 Share Posted February 13, 2022 By face I assume you mean the surface that the studs protrude from and the outside of the bearing housing? If so I painted mine - and the back. I also painted the flange and the face of the stub too. Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 13, 2022 Share Posted February 13, 2022 1 vote for paint ! Quote Link to comment Share on other sites More sharing options...
Mossberg Posted February 13, 2022 Author Share Posted February 13, 2022 Thanks gents, I will do that. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 13, 2022 Share Posted February 13, 2022 Paint, or rust. You decide. 1 Quote Link to comment Share on other sites More sharing options...
Mossberg Posted February 13, 2022 Author Share Posted February 13, 2022 49 minutes ago, Gazzar said: Paint, or rust. You decide. I will take the paint option! 2 Quote Link to comment Share on other sites More sharing options...
De Ranged Posted February 14, 2022 Share Posted February 14, 2022 Grease or anti-seize If you paint a mating surface when you torque up your wheel nuts it will need to force the paint out of the contact area of your rim.... if it doesn't your rim will come loose as the paint gives due to use 2 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 14, 2022 Share Posted February 14, 2022 Correct, paint is along for trouble. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 14, 2022 Share Posted February 14, 2022 I have paint but it's 2k and one coat so thin but robust. Mike Quote Link to comment Share on other sites More sharing options...
Mossberg Posted February 14, 2022 Author Share Posted February 14, 2022 7 hours ago, De Ranged said: Grease or anti-seize If you paint a mating surface when you torque up your wheel nuts it will need to force the paint out of the contact area of your rim.... if it doesn't your rim will come loose as the paint gives due to use And I was thinking the issue would be the wheel binding to the hub! I have painted them now so I will keep checking the torque. Quote Link to comment Share on other sites More sharing options...
De Ranged Posted February 14, 2022 Share Posted February 14, 2022 5 hours ago, Mossberg said: And I was thinking the issue would be the wheel binding to the hub! I have painted them now so I will keep checking the torque. It can be.... depends on the mating face of the rim. But its not a biggie lol with the nuts off kick your tyre a bit and they pop loose 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 14, 2022 Share Posted February 14, 2022 It’ll compress and seat very quickly - and you’ll still have the benefit of protecting the rest of it from rust. 1 Quote Link to comment Share on other sites More sharing options...
smallfry Posted February 18, 2022 Share Posted February 18, 2022 For many years I have always cleaned paint and rust off the surface and painted on Rocol J166, a heavy duty copper antiseize grease (they have changed the name though) Never have problems with wheels seizing to hubs, or corrosion problems. Use it on studs/bolts/nuts too. Wouldnt use paint of any sort, will ultimately chip, and I have concerns about seating the wheel properly. Also, note that manufacturers never paint these surfaces. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 19, 2022 Share Posted February 19, 2022 The steel wheels are painted. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 24, 2022 Share Posted February 24, 2022 No issue painting IMO. As Anderzander says... the wheels are painted or powder coated in the case of steels and no one cleans that off before fitting! Quote Link to comment Share on other sites More sharing options...
smallfry Posted February 24, 2022 Share Posted February 24, 2022 13 hours ago, landroversforever said: No issue painting IMO. As Anderzander says... the wheels are painted or powder coated in the case of steels and no one cleans that off before fitting! Normally powder coated, which is somewhat harder than paint. Quote Link to comment Share on other sites More sharing options...
uninformed Posted April 12, 2022 Share Posted April 12, 2022 Hubs are painted from factory… Quote Link to comment Share on other sites More sharing options...
