Hybrid_From_Hell Posted April 20 Share Posted April 20 Can anyone advise wtf these are called / wheee to get them they are off a very late D2 diff and are not sold by LR ! approx dimensions are width 16mm height 13.73mm thickness 1.15mm if I could just find something close to buy but really struggling all dimensional flexible - the of as is whacked into a casing hole the height as I can adjust it and thickness not cricjal help !!!! Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 20 Share Posted April 20 I don't know the correct name but that's the sort of thing for keeping a control knob on a pot on an old fashioned radio or cooker. I (carefully)googled ' control knob spring clip' and some were returned. 1 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 20 Share Posted April 20 https://www.ransomspares.co.uk/parts/cookers-hobs/leisure/control-knob-pressure-spring--clip/146592.htm Seems a viable option. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 20 Share Posted April 20 Willing to bet if you needed a few one of the smaller spring manufacturers would be willing & able... I did have some catalogues somewhere from Southern Manufacturing Show. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted April 20 Share Posted April 20 2 hours ago, Hybrid_From_Hell said: Can anyone advise wtf these are called I take it it's for aligninging casings? It's a split dowel sleeve. You could try an agri' or plant dealers or a machine shop. Quote Link to comment Share on other sites More sharing options...
TSD Posted April 20 Share Posted April 20 (edited) 2 hours ago, Hybrid_From_Hell said: all dimensional flexible - the of as is whacked into a casing hole the height as I can adjust it and thickness not cricjal Help is clearly needed... Edited April 20 by TSD forgot much needed smiley 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 20 Share Posted April 20 What about 16mm diameter roll pins https://www.ebay.co.uk/itm/303493875071?itmmeta=01HVY2BW3TYES6ZSF1ZQ59FKJJ&hash=item46a9a5057f:g:XPgAAOSw6WleTj2O&itmprp=enc%3AAQAJAAAA8ET%2FLN9rFFQ83CgMocVt%2B6vHzf%2Fer%2FU4zVtkNa174BL1FT1aG%2Fq7ih9g1OeCkUuZr%2BTMUpw4yeOuO2sKH%2FPdoOVWjQXzxMHxed7HNidY%2Fzzqf7%2F7CzGzBXdzemM2agTK3BjpP22gy3ILlxDYaTRmBlzSYffqZAAe6quJTrmApwe%2F3mzoRII6KZDZW8JdgPbLhMUYF1W3fKE0ftiaNKY5H6psgIFsV8JNcwyJVbNb8c8sje5l%2FTv0j5ouxITDwoT20BtKIDk9ef%2BEJt%2BPM2lsZkBFlyJamxmizRA5OFzmhAqQTJatD7t2frWGr04W%2FXGsng%3D%3D|tkp%3ABk9SR4LCr8LfYw Regards Stephen Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 20 Share Posted April 20 If its use is just as a dowel, could not a person with a lathe produce something similar, ok not sprung, but maybe loctited into place? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted April 20 Share Posted April 20 They look surprisingly like some little end bushes I've seen. Quote Link to comment Share on other sites More sharing options...
B reg 90 Posted April 20 Share Posted April 20 Try here: Spring Alignment Dowels / Bushings | SPIROL Adrian Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 20 Share Posted April 20 They look similar to head locating dowels. Turner Engineering might have something a similar size, as may your local engineering workshop. The kink in the slot would not be essential to its function - I suspect that just ensures the ends line up evenly as it gets closed in the bore, but a tap on the end with a hammer would do that. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 21 Share Posted April 21 https://www.moss-europe.co.uk/alignment-dowel-timing-cover-alignment-cam-stud-genuine-jaguar-ebc9705.html Mike Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 21 Share Posted April 21 https://www.mcmaster.com/products/alignment-dowels/unthreaded-inserts~/ Doesn't deliver to Europe, but a great site to figure out what the hell things are called sometimes Quote Link to comment Share on other sites More sharing options...
