need4speed Posted July 6 Share Posted July 6 As title. Looking to have a crusty old Ford 302 block dipped and cleaned of all corrosion in preparation of a build. Does anyone know of a company in Scotland that they could recommend? Maybe even a galvanizing company would do it as they tank parts before dipping in zinc? As usual a google search churns out loads of companies in South England but none up here…. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 6 Share Posted July 6 @need4speed not seen you around here for a while, good to see you back. Cant rightly help with question, but interested to know also. Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 6 Author Share Posted July 6 Cheers Mav! I’ve been lurking from time to time but the 110 is in the hands of my old man just now so I let him get on with that - he needs a hobby!!! Im starting to build a 302 to go in the Capri. It will replace the 4.6 Rover to stop Henry Ford and Carrol Shelby from rolling in their graves at the fact that there’s a Buick motor in it…… 1 2 Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 6 Author Share Posted July 6 Someone has suggested to build a wooden box just big enough, line with plastic sheet and submerge in white vinegar for couple days. Does this sound viable? Is the vinegar really strong enough to remove all that carp? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 7 Share Posted July 7 Vinegar or citric acid will do a great job, as you say it does take time. If you can warm the solution it makes a real difference, both can be bought cheap, which does make it worth a look in my book. The other one I heard of was molasses, no idea where you would get that in decent quantity though! 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted Sunday at 07:33 AM Share Posted Sunday at 07:33 AM I’ve used vinegar to clean the inside of classic bike petrol tanks .. it does work, to a point. It’s cheap (ish) and not dangerous, and does an ok job. Not sure if this is a plus or minus, but it does end up smelling like a chip shop. I stopped using though and switched to stronger acids in the end though because I wanted it ‘bare metal clean’, and the vinegar wasn’t doing that in all places. Is acid the thing to use though ? Is it for rust removal or just degreasing ? If it’s degreasing and cleaning could you fill a barrel with thinners and soak it in that? If it is acid you want perhaps look at powder coating places, the ones near me dip things before they spray them. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted Sunday at 08:24 AM Share Posted Sunday at 08:24 AM What about laser rust removal There is a firm called LaserTec that hires equipment and have courier services Regards Stephen Quote Link to comment Share on other sites More sharing options...
fmmv Posted Sunday at 09:34 AM Share Posted Sunday at 09:34 AM If its just rust removal what about good old electrolysis or even sandblasting? With electrolysis you could do a bit at a time even if you can't manage total immersion - I guess its quite a lump. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted Sunday at 03:27 PM Share Posted Sunday at 03:27 PM Does the galv plant in Glasgow not do it? Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 03:45 PM Author Share Posted Sunday at 03:45 PM Yes it’s for rust removal more than anything. It’s nasty. Sand blasting would be great for the outer block surfaces but obviously will do nothing for the water jacket/internal areas. However electrolysis could be an idea. Funny you mention the galv place in Glasgow, I pinged them an email last night. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted Sunday at 04:20 PM Share Posted Sunday at 04:20 PM I think acid dipping would be the best option. Electrolysis isn’t great if it’s a section like oil/water galleries that don’t have line of sight to the electrode. 1 Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 04:36 PM Author Share Posted Sunday at 04:36 PM Agreed Ross Just need to find somewhere relatively close to me. Edit: Or could I purchase the required acid myself and make a bath for it?? Ive already got a decent engine crane and chains to lift in/out etc Quote Link to comment Share on other sites More sharing options...
muzaz Posted Sunday at 04:59 PM Share Posted Sunday at 04:59 PM They mostly use hydrochloric or sulphuric acid but then they dip in molten zinc straight away, and the zinc will have a very good adhesion. Just like soldering in the old days with killed spirit. But I see a problem in your case, as you're not galvanising the block, it will flash rust immediately with the acid, and it's a bit of a nightmare to neutralise especially the passages in the water jacket. Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 05:17 PM Author Share Posted Sunday at 05:17 PM Hmmm. Good point that. Tho if I were doing it myself could I not maybe have a separate bath for naturalising I could submerge it in immediately? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted Sunday at 05:54 PM Share Posted Sunday at 05:54 PM I wonder if it would just end up with it rusting anyway. Have you got any engine builders locally that could hot wash it? Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 06:00 PM Author Share Posted Sunday at 06:00 PM As long as i got the acid neutralised quickly enough it wouldn’t rust again too quickly. I’d get the external surfaces primed for painting and coat interior in WD40. Then use Graphogen during assembly. Unfortunately I’m not aware of any builders near me. Quote Link to comment Share on other sites More sharing options...
muzaz Posted Sunday at 06:03 PM Share Posted Sunday at 06:03 PM 41 minutes ago, need4speed said: Hmmm. Good point that. Tho if I were doing it myself could I not maybe have a separate bath for naturalising I could submerge it in immediately? You can neutralise the acid with an alkali, caustic soda comes into my mind and it's a pretty strong one. But I suspect the passages will rust anyway if left untreated. I have used phosphoric acid, it's good for rust removal and leaves a coat of iron phosphate which prevents further rusting. But it's not agressive as much as HCL, so it takes longer to work. 1 Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 06:08 PM Author Share Posted Sunday at 06:08 PM So Tank of Phosphoric for what? 3 or 4 days? In no rush so could leave as long as it takes. Quote Link to comment Share on other sites More sharing options...
muzaz Posted Sunday at 06:50 PM Share Posted Sunday at 06:50 PM Depends on the severity of rust I think, and also the concentration of the acid. If not in a hurry all the better, you can always leave it more. When done don't rinse with water, blow with air and let it dry. But you're going to need quite a bit of acid to dunk the engine block! Quote Link to comment Share on other sites More sharing options...
need4speed Posted Sunday at 07:04 PM Author Share Posted Sunday at 07:04 PM Which is the next question. Can I buy the quantity needed without license here in UK? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Sunday at 07:40 PM Share Posted Sunday at 07:40 PM eBay. Quote Link to comment Share on other sites More sharing options...
fmmv Posted Monday at 04:38 PM Share Posted Monday at 04:38 PM Or maybe something like a tank of evaporust? Especially if MI5 pop round to inquire why you're buying industrial quantities of acid. Edd China did a whole RR chassis in some. I think its reasonably innocuous stuff. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted Monday at 04:50 PM Share Posted Monday at 04:50 PM Wasn’t there some speculation in the YouTube comments that Edd China used so much that he must have been sponsored by the supplier? It was a huge bath! Quote Link to comment Share on other sites More sharing options...
elbekko Posted Monday at 04:54 PM Share Posted Monday at 04:54 PM And here. That was 10k+ of EvapoRust. Good stuff for sure, but not feasible for one person, much cheaper just taking your chassis to an acid dipper on the other side of the country. 1 Quote Link to comment Share on other sites More sharing options...
need4speed Posted Monday at 07:36 PM Author Share Posted Monday at 07:36 PM No way am I getting it from eBay. Think I’m buggered Quote Link to comment Share on other sites More sharing options...
