Recovery
Paul64
I am no expert when it comes to vehicle recovery and was having a look for some film clips on the subject. I came across the following. This snatch recovery using a joined kinetic rope seems quite aggressive. Is it OK to snatch in this way without risk of a shackle flying through your windscreen?
Cheers,
Paul
NO!! Never join a kinetic to a strop/rope/other kinetic with a shackle as if it fails it can be flung with huge force and possibly kill someone. It is even a bit dodgy to join a kinetic to another strop/rope/other kinetic by looping as this is still a potential fail point.
Thanks Dan. So if the fella in the film was recovering with a single non joined rope would taking up the slack at that speed be OK?
Wot he said!
The forces exerted by kinetic ropes are enormous. You have to be 100% sure that everything is in tip-top condition, especially recovery points.
Kinetics have thier use, but joining two together is an absolute NO-NO.
Unfortunately many peolpe get the kit without the faintest idea how to use it. This is where clubs and marshals come in handy. If I saw somebody doing this at one of our playdays I would be straight in there explaining what was wrong with the recovery.
Providing the recovery points are up to the job then the idea is to get some stretch on the rope so that the stuck vehicle gets twanged out if ya see what I mean :rolleyes: The only way to do this is to take a run up. The textbook recovery would show the rope laid out on the ground in a zigzag and not crossed over itself anywhere.
LASHING EYES ARE NOT SUITABLE RECOVERY POINTS!
Given the choice I'd use the winch over kinetic recovery everytime, much safer and much more controlled.
All above is good advice re kinetic recoveries, however I'm not sure I'd call that recovery agressive though.
My inexperience that makes me think it looks aggressive I suppose, as only used to car towing with an ordinary rope. It just looks pretty damn dangerous snatching like that with a massive elastic band!
One has to wonder what they joined the rope to the Discovery with too. I assume it was the standard screw in recovery eye - which I would not use to snatch recover with!
I have seen the result of a towball coming loose when attached to a kinetic rope. It was not pretty and literally destroyed the wing of a Landrover. If it had hit a person I am in little doubt that it could have been fatal - or very nasty at best.
Never take up the slack in a "dead" rope at speed.
Chris
It is. The forces involved can be enournous. Which is why you have to be 100% sure that all the attachament points are up to the job and not do silly things like joining ropes/strops with shackles. Obviously the more agressive you are the greater the risk.
Also despite the poster's defence of using reverse gear to recover because "sometimes it's lower", I've been told reverse gear is often weaker than the rest due to having an extra gear in the train to reverse rotation.
I guess from the point of view of a KERR recovery there's also less truck between you and any flying bits of tackle...
Good GOD :o
Having watched it just about everything wrong
NEVER EVER join 2 KERRs with a shckle
Look at the view out of the 2Windscreen" that straight rope = its aiming for you :huh:
Recovery points - doubtfull they are good enough - there a real "Muppetry" air around this event
NEVER do recovery in reverse - wekaest gear and you have little sterring or visibility FFS
Winching was a nightmare too - poor practise
All in all just remember this video and remember to do NOTHING as they did - accident waiting to happen
Nige
I am relieved it is not just me that views this as dangerous. I would have thought if you know you are going in for a drive like this you would have a nice big fat set of low inflated muddies on? If you do choose a kinetic rope, what would be the best recovery point to use?
Having never winched a single thing in my life what was he doing wrong in the video when using his?
Cheers,
Paul
Sometimes it might be but usually it isn't! Reverse is usually somewhere between 1st and 2nd in ratio. Not sure about reverse being weaker - its true of older LT77 gearboxes I think but not sure about newer ones or something completely different like the D3 gearbox.
Not a bunch of people I would choose to go anywhere with, that's for sure!
Has anybody tried using a high lift for recovery or is that even more dangerous?
using a hi-lift jack & adjustable chains is very slow & extremely hard work, it's all manual power, as for safe it's as safe as any other method provided the users know what thier doing & how to do it.
have a read here use the 'learn with david' link in the left column & then the 'using a hi-lift' in the index :D
the KERR bit aside i would have thought the recovery points would have been alright, the D3 has a large single eye in the middle at the front designed for recovering off and the td5 is using the tow bar attachments isint he? both upto the task, as long as the rope is attached to them properly
What do you use now?
Superwinch G10 on the front and a Husky 8 on the rear. Not that I've used the rear that much. More of an insurance policy. Then again I don't get out much nowadays. To busy at work
