gsr341 Posted March 19, 2006 Share Posted March 19, 2006 hello , im on the search for sum switches to install my winches , and was wondering what you lot use (preferably the push type ) but show me them all any way ive looke at the rs site , and a few otheres for 'SPNO' push switches but they all only really rated around 500mA and an electrician at work has worked it out and recons i need a switch rated at 2A DC to carry the load ? so what ya got pics would be grat can see how you all mounted them then too Quote Link to comment Share on other sites More sharing options...
MogLite Posted March 19, 2006 Share Posted March 19, 2006 I prefer a toggle - easier to use in gloves If you wanted a push (rocker) switch - electric window switch would be ideal. Quote Link to comment Share on other sites More sharing options...
bathtub Posted March 19, 2006 Share Posted March 19, 2006 Wireless remote controls on both Quote Link to comment Share on other sites More sharing options...
Budgie Posted March 20, 2006 Share Posted March 20, 2006 In the Disco I've gone for an electric window switch with a seperate power on/off switch. Nice & easy to wire up and I can still use the normal remote for spooling. Not a good photo but you get the idea, oh and it's a 3 door so I had two blanks on the centre consol for the winch controls. Quote Link to comment Share on other sites More sharing options...
Divster Posted March 20, 2006 Share Posted March 20, 2006 Using a durite rocker switch (mom-off-mom) as supplied by vehicle wiring. Sorry no pics at the mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 20, 2006 Share Posted March 20, 2006 My set up is similar to Budgie's - window rocker switch with isolator that also isolates the winch via a can solenoid - stops undesirables having some fun with the wanderlead socket on the front grille... Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 same as divster with VWP one mom/off/mom Quote Link to comment Share on other sites More sharing options...
Mark90 Posted March 20, 2006 Share Posted March 20, 2006 I prefer toggle switch to rocker for winching, as mentioned easier with gloved/cold/muddy hands and less chance of operating the switch in the wrong direction. Quote Link to comment Share on other sites More sharing options...
Divster Posted March 20, 2006 Share Posted March 20, 2006 My set up is similar to Budgie's - window rocker switch with isolator that also isolates the winch via a can solenoid - stops undesirables having some fun with the wanderlead socket on the front grille... I'm also using the secondary solenoid to isolate via a rocker. I'm just starting to look at an external switch mounted near the winch f0r the winch biatch to use. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Michele Posted March 20, 2006 Share Posted March 20, 2006 as in the tech archive Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted March 20, 2006 Share Posted March 20, 2006 I've got a momentary toggle switch mounted on the gearstick (don't have to stop winching to engage/change gear - you never know), a socket on the front grille for the wanderlead, and - controversially - a latching toggle switch on the front grille. It's a Milemarker, there's plenty of time to get out of the way. All three are isolated from inside the cab. Toggle switches are ideal in gloves, otherwise go for BIG chunky pushbuttons. Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 Winch bitch control switches, now that is something i am after, anyone got any decent waterproof, reasonably large button switches or know where you can get some? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted March 20, 2006 Share Posted March 20, 2006 Winch bitch control switches, now that is something i am after, anyone got any decent waterproof, reasonably large button switches or know where you can get some? You can get switches for bitches now? cool B) I mostly shout Quote Link to comment Share on other sites More sharing options...
davidlandy Posted March 20, 2006 Share Posted March 20, 2006 Heres mine - completed it last week cost about £15 in bits from our local auto electrics place for switches and a few metres of 7 core trailer cable. Its simply wired direct to an albright under the bonnet. The switches are durite ones - got the part numbers somewhere Nice and simple to use and discreet Quote Link to comment Share on other sites More sharing options...
andylandy Posted March 20, 2006 Share Posted March 20, 2006 i use switches from david bower there the same as in a super winch hand controler complete with id plate very flash they are fitted in th cab and one on the front wing and one on the back of the 90 cant remember what i piad now but had now problems Quote Link to comment Share on other sites More sharing options...
gsr341 Posted March 20, 2006 Author Share Posted March 20, 2006 which cable should i use for the main power supply to the solinoids /winches ? 40mm2 flexable batt cable (300 amp capacity) or 35mm2 weling cable (240 amp capacity) not much between the price both from vehicle wiring products http://www.vehicle-wiring-products.co.uk/V...les/cables.html Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 my husky uses 35mm2 240amp and the 8274 uses 40mm2 300 amp why because thats what they both came with! Quote Link to comment Share on other sites More sharing options...
gsr341 Posted May 2, 2006 Author Share Posted May 2, 2006 finally got round to making a panal and fitting some switches hes my go at it , still loades to do Quote Link to comment Share on other sites More sharing options...
Mark90 Posted May 2, 2006 Share Posted May 2, 2006 Nice job. I've put a toggle switch on the top left of the instrument binacle for in/out.... and the red 'figher pilot' switch is the cut off.... Still got to build, fit and wire the winch though Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 2, 2006 Share Posted May 2, 2006 I've got a master and two push switches on the dash And a sprung toggle on the wingtop Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 2, 2006 Share Posted May 2, 2006 I have a waterproofish toggle from VWP waiting to go inside the cab but I ain't got a round tuit yet... Quote Link to comment Share on other sites More sharing options...
reads90 Posted May 2, 2006 Share Posted May 2, 2006 hello , im on the search for sum switches to install my winches , and was wondering what you lot use (preferably the push type ) but show me them all any way ive looke at the rs site , and a few otheres for 'SPNO' push switches but they all only really rated around 500mA and an electrician at work has worked it out and recons i need a switch rated at 2A DC to carry the load ? so what ya got pics would be grat can see how you all mounted them then too i used dicso electric window swiches for some of my dash mounted ones Quote Link to comment Share on other sites More sharing options...
simonr Posted May 2, 2006 Share Posted May 2, 2006 With a wee bit of luck, Pugwash & I will soon have ARB Style carlton switches available for front & rear winch, winch enable and freespool (for the few with pneumatic freespools). Si Quote Link to comment Share on other sites More sharing options...
Gnomeranger Posted May 3, 2006 Share Posted May 3, 2006 I just switch to the direction I require and press the black button. Quote Link to comment Share on other sites More sharing options...
Divster Posted May 3, 2006 Share Posted May 3, 2006 Finally got pics of mine: Left hand switch is for my voltmeter, middle switch is the winch isolator and right hand is my winch in/out. Also fitted this biatch switch: Quote Link to comment Share on other sites More sharing options...
