The Grave yard
Bos
Err, Hypothetically - you only had one hand on the wheel, and your eyes on the phone ( I presume it was your phone) in your hand - It's illegal to use a phone whilst driving, £60 and 3 penalty points Mr Bickerton! :o
TUT!
You're grounded!
:rtfm:
You see this is what I mean about these highway safety/patrol/ bods. They can't resist stepping over the mark.
PCSO's in 4x4's. ;)
Stick to what you do well mate ... sweeping up glass from the motorway....... :P
I have an Irish plate starting MIL on my hybrid, anyone want it too match there initials?
Basically being a bit of a tart i have found a better plate for myself that matches my name!!
Its B16 WVL, if its still about?
Worst thing is my dad had the chance to buy the 'right' plate for our surname, but he chickened out and bought the 'cheap' one. Had the chance to get W1 VEL, he got W11 VEL, its now gone, hey ho!!
Anyone know what the maximum size SD card this will recognise ?
or what you have in yours
So I can get a fair bit of memory mapping on there ;)
My N35 will take upto 1GB sd cards. I have a 2gb from the works hp hx4700 that will not work in it. Currently running 1 region of MM2004 plus load of 1:25k & tomtom on the 1Gb.
Bum.....I can't access the page to ge the info....can anyone get the info and post it up please ? ;)
Les
we have three of these for an experiment.
The instructions i have for updating the OS are a little bit different and have worked for me, instructions are at the bottom of This post
I had to update to the latest OS so that the latest version of the .net framework would work.
It did take up to 10 mins for the OS to rully reboot- so long that i got worried and thought i had broken it. Eventually i put it down and left it for a while.
the N35 does have some issues with how it works- we've had no end of problems getting it to run a prog in .net which works on another pocket PC with the same software on it!
found a link which answers your second question but i can't find it at the moment- if i come across it then i'll post it on here!
Unfortunately, even after hard reset with totally clean device .NET CF
v2 installation fails (not intended for this device, I tried also SP1).
I agree, that problem is probably wrong reporting from the device.
The only solution, that worked for me, was upgrade:
1. download
ftp://ftp.support.acer-euro.com/handheld/...ge/n35_SE_Eboot
6.2.rar
and OS image according to your language (or use
n35_SE_v2.10.12_WWE_SD.rar - english)
2. erase SD card (do not format it, if you must, use FAT16, FAT 32
won´t work)
3. to the root of SD extract two files from
6.2.rar
4. put SD to the device, switch hard reset to position 1 (left)
5. hold power button an click hard reset back to position 2 (right)
while holding power button (e boot should deploy very quickly and write
COMPLETED)
6. switch hard reset to position 1, remove SD card, erase it, extract
to the root of SD all files from OS image
7. put SD back to the device, hold power button and switch hard reset
to position 2 (right) while holding power button - hold it for cca. 10
sec or more! "downloading img" should appear
8. wait for soft reset (for 3 minutes it seems,that nothing is
hapenning, be patient)
9. you are good to go - upgraded to PPC 4.21
After this upgrade, installation of .NET CF v2 is no trouble at
all-works just fine.
Warning, you are upgrading to your own risk ;) Known problems - some
noname SD cards with high capacity (over 1GB) won´t work for this
upgrade. You must get smaller one :)
Its far cheaper and easier to change your name to match your plate. Quick call to the deed Poll offices and £40 on your card.
Henceforth I wish to be known as Wendoline Avril Virginia. :ph34r:
Willy Aard Viagra?
[cough, cough, clears throat] What's that you say? Ahem. ;)
Chris
I have just brought a 90 rear door of Lewis on the forum. Anyone travelling from Staffordshire WS15 area south via the M1 one weekend ? I live in Thurleigh Bedfordshire (MK44 2DS) so need to get the door to me as cheaply as possible.
Cheers
Ivan
Cheers
Ivan
I am heading down to Bedfordshire on the 4th March if it helps, but its getting it to me or somewhere on the way.
Paul
