Slammed Landy anyone?
jason110
I know of that landie, deff wasn't built with snow in mind!
Slightly more info here;
http://retrorides.pr...ad=40056&page=1
I have to say, I quite like it.
It has a certain something and if he ever did put a modified truck cab on it then it would be *really* good :) . Although the rear axle mounting looks a little... erm... under spec in my mind, stacked open ended off cuts of box section in tension as spacers .... they'll be flexing a bit.... then one day crack and a little bit more slammed lol :)
I'm more worried about the spring/U-bolt plates which seem to be 3mm steel, and bent as the bolts were done up!
You're right about that plate :blink: , and I was mistaken about the spacer blocks as they will be in compression due to the U-bolts (I'm blaming it on being a Monday) however I still think they should at least be boxed in.
I didn't say I liked the craftsmanship, I too thought the back axle looked a little iffy spring mount wise.
I might point out it has nothing to do with me, I just read about it a while ago!
Lol, I've seen your craftmanship task so it's obvious that it has nothing to do with you :) Your CSK is a work of art sir :)
