Hybrid_From_Hell Posted March 18, 2012 Share Posted March 18, 2012 Ignition lead clips, the ones that seperate - doing the 5.2s plug leads now, and need to make all the leads routing nice and tidy - so some seperators needed. Scrap cars are nearly always 7mm mine are 8mm, I thought I had some tucked away - gawd knows if I have / where So, bay of E I went, and tried and tried and ....... http://www.ebay.co.u...#ht_1146wt_1163 I just cannot belive thats all the clips/seperators listed on the entire UK EBay site !! And those aren't the sorts I wnat really either WTF else can they be called ? failing that where might I find a goodly selection to look through and then buy on line ? Things that you'd think would be easy peasy .............. Nige Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2012 Share Posted March 18, 2012 Try ignition lead spacer did a search with that & found 10mm only here Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 Hmmmm Still not much to chose from, 10mm no good as leads 8mm Going in the workshop to hit something <sigh> Nige Quote Link to comment Share on other sites More sharing options...
martifers Posted March 18, 2012 Share Posted March 18, 2012 Any of these do Nige? http://www.ebay.co.u...b0#ht_729wt_932 http://www.autoelectricsupplies.co.uk/product/90/category/18 http://www.burtonpower.com/ezk65b.html?utm_source=google&utm_medium=base&utm_campaign=gb_feed?WbRf=GBase Quote Link to comment Share on other sites More sharing options...
luke keeper of badger Posted March 18, 2012 Share Posted March 18, 2012 https://www.europaspares.com/product/147/18475/ELECTRICAL/IGNITION/Moroso_7_9mm_Loom_Divider_Kit__Red_____72172.html try that nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 er "non" $12 to Buy $14 shipping And not the type I really want Mmmmm scrapyard calleth maybe ? Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 £28 POUNDS Er "Non" merci buckets Nige Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 18, 2012 Share Posted March 18, 2012 http://www.ebay.co.uk/itm/Mr-Gasket-3677-Ignition-Wire-Separators-8mm-Black-/110752829462?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19c9621016 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 18, 2012 Share Posted March 18, 2012 Nige!: http://www.cbsonline...ble_Rail_PLSEP2 Sexeh Or: http://www.summitracing.com/parts/MOR-72133/?rtype=10 http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Lead_Dividers_Etc http://www.ebay.co.uk/itm/12PC-SPARK-PLUG-WIRES-BILLET-WIRE-SEPARATORS-DIVIDERS-/360277258445 Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 18, 2012 Share Posted March 18, 2012 http://www.ebay.co.u...=item19c9621016 Come on Barry, I can hear the teeth sucking from here, PMSL Quote Link to comment Share on other sites More sharing options...
team_wingnut Posted March 18, 2012 Share Posted March 18, 2012 probably abit of a bodge, but can look ok if you get it right, you can do it with cableties, a loose loop around the leads, then a cable tie around the loop spacing the leads, then pull the loop tight! Personally I think cable ties have 1001 possible uses! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 18, 2012 Share Posted March 18, 2012 Come on Barry, I can hear the teeth sucking from here, PMSL Lol, strangely there seem to be no 8mm spacers in the country other than that carp. Everything seems to be USA or Aussie. Quote Link to comment Share on other sites More sharing options...
team_wingnut Posted March 18, 2012 Share Posted March 18, 2012 could try europa spares or merlin motor sport, or if your feeling rich deamon freakes Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 Anything where shipping is near as much or more than item <suck teeth> or anythying that requires a remortgage (That rules out Demon Sqeaks) proving tricky, some cars must have 8mm leads as std ?, or are they as I think 7mm often ?? Hmmm Scrap yard tomorow maybe ? - Just some nice cheap 8mm clippypos, maybe where some can be fixed to rockers etc? Ta for helping tho Nige Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted March 18, 2012 Share Posted March 18, 2012 Can't you run an 8mm drill through some 7mm ones? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 Yep, but I would like the "Horse shoe" shaped ones so tricky Also ones that I can fix to rovers etc / make brackets so leads are held in place rather than flapping about Hmmm Nige Quote Link to comment Share on other sites More sharing options...
muddy Posted March 18, 2012 Share Posted March 18, 2012 You've probably even got these in stock: http://www.ebay.co.uk/itm/4X-NAIL-ART-TOE-NAILS-SOFT-FOAM-SEPARATORS-MANICURE-PEDICURE-HAND-SPACERS-UK-/260960363052?pt=UK_Health_Beauty_Nails_Manicure_Pedicure_CA&hash=item3cc273222c Will. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted March 18, 2012 Share Posted March 18, 2012 COP Nige. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 18, 2012 Author Share Posted March 18, 2012 Just Go away and weld something Nige Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 18, 2012 Share Posted March 18, 2012 Why not buy a sheet or plastic and get busy with the mill? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 18, 2012 Share Posted March 18, 2012 Draw something up and get it cut by your friendly laser Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 18, 2012 Share Posted March 18, 2012 I'm sure you could find a reponsable adult who can weld to knock you up something out of a bit of stainless..... Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 18, 2012 Share Posted March 18, 2012 Or what about these? http://www.machine7.com/section.php?xSec=144&jssCart=f89b1ce38ac368899b276aee7cc33f2e Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 18, 2012 Share Posted March 18, 2012 or these http://www.autoelectricsupplies.co.uk/product/90/category/18 Quote Link to comment Share on other sites More sharing options...
Simon119 Posted March 19, 2012 Share Posted March 19, 2012 http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Engine_Dress-Up Bottom item on the page any good?? Quote Link to comment Share on other sites More sharing options...
