landrovermanuk Posted February 24, 2013 Share Posted February 24, 2013 Ok. So it appears to a case of personal choice... Thanks Quote Link to comment Share on other sites More sharing options...
landy_andy Posted February 25, 2013 Share Posted February 25, 2013 Rebuilds looking good.... what rad & fan(s) are you going to use ? I'm halfway through my D90 rebuild & am at the point that I need to decide between a mechanical VC fan or electrics (am running MS to on a 3.9, will be a 4.6 laters). Was going to get an Allisport rad but am not 100% confident that the twin electrics will do the job in summer here (BC, Canada)..... been reading up over the weekend & found that some owners in Florida are getting good results with the Flex-a-lite 220 and if you go for a slightly wider rad the 292 will fit on..... thoughts ? Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 25, 2013 Share Posted February 25, 2013 I struggled with an OEM rad and twin electrics but only on the warmest months in UK so upgraded to a HD 4 row OEM type rad. I then had my second set of fan bearings fail and got annoyed, plus it was never super cool, so switched back to viscous and now wouldn't have it any other way, so much cooling available at all times. Quote Link to comment Share on other sites More sharing options...
muddy Posted February 25, 2013 Share Posted February 25, 2013 Landyandy surley you can get a nice Ali rad with proper mounted fans from summit for a good price? Looking good bingy, id hazard a guess you from bingley? Will. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted February 25, 2013 Share Posted February 25, 2013 Landyandy surley you can get a nice Ali rad with proper mounted fans from summit for a good price? Not that are a drop in fit & have the integral oil coolers with BSP fittings. Did get a quote from Ron Davis radiators for a NAS spec one & it's alot more than Allisport. Linky to my build if you want a look - http://www.d-90.com/forum/showthread.php?t=36827 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted February 26, 2013 Share Posted February 26, 2013 Linky to my build if you want a look - http://www.d-90.com/forum/showthread.php?t=36827 Slightly off topic, but nice build. Love the chassis roll cage mounts, just like mine as nowhere sells them, so I too make my own! Steve Quote Link to comment Share on other sites More sharing options...
discomark10 Posted February 26, 2013 Share Posted February 26, 2013 Rebuilds looking good.... what rad & fan(s) are you going to use ?I'm halfway through my D90 rebuild & am at the point that I need to decide between a mechanical VC fan or electrics (am running MS to on a 3.9, will be a 4.6 laters). Was going to get an Allisport rad but am not 100% confident that the twin electrics will do the job in summer here (BC, Canada)..... been reading up over the weekend & found that some owners in Florida are getting good results with the Flex-a-lite 220 and if you go for a slightly wider rad the 292 will fit on..... thoughts ? Ive got a duel fan setup, have them come on a different temps so they only come on when/if needed, also got an override so they can be turned off or on. didnt cost much at all to setup, just a couple relays, thermostatic switches and a bunch of wire. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted February 26, 2013 Share Posted February 26, 2013 Slightly off topic, but nice build. Love the chassis roll cage mounts, just like mine as nowhere sells them, so I too make my own!Steve Thanks Steve, shipping is a killer to Canada from the UK.... esp for lumps of steel..... that's why I made my own rear winch tray, cage mounts etc..... was also easier to 4 link the back end too, rather than do a custom 'A' frame.... sorry Bingy, thread hijack off Quote Link to comment Share on other sites More sharing options...
Bingy Posted March 17, 2013 Author Share Posted March 17, 2013 Thanks Steve, shipping is a killer to Canada from the UK.... esp for lumps of steel..... that's why I made my own rear winch tray, cage mounts etc..... was also easier to 4 link the back end too, rather than do a custom 'A' frame.... sorry Bingy, thread hijack off No problem pal, Nice build. Looking good bingy, id hazard a guess you from bingley? Will. Near, but just a coincidence Will. It was a nickname given to me at school - looooong story. Quote Link to comment Share on other sites More sharing options...
Bingy Posted March 17, 2013 Author Share Posted March 17, 2013 Onto the engine. Now that i had proceeded enough, i decided to start on the engine. I heard the engine running before i bought it. It also came with the full lpg kit, wiring and all pipework, together with the lt95 and transferbox out of a RRC. Starting from the top the 3.9 was stripped piece by peice and then scrubbed with a nylon tooth brush and kerosine to clean the parts. I did just one head to see how dirty the engine was and how long it would take to do. I carried on stripping the engine peice by piece until i was just left with the block. Then i began scrubbing, a dirty job to say the least. By the looks of the pistons these are the originals no marks on top. And the big ends look as though they are too. But the camshaft looks new, according to the lobes. But the bores look to have had a bit of extra honing done to them. I set about making a list of all the parts needed to rebuild the engine. I decided that whilst io was going about it i would get the engine top hat linered. I didnt see the piont in doing a rebuild then find that one of the liners was knackered or had gone walkabout. I rang loads of engine rebuilders, some had never heard of top hat linering. One well known, highly recommended rebuilding company told me, that if the block wanted top hatting the block was scrap! I was getting nowhere, time was passing on, i was starting to neglect and have secvond thoughts about the build. Thoughts had crossed my mind regarding giving up and selling up - even though i had done all the work myself. I didnt even venture into the workshop for a few months, I just decided to take my mid off it and work nearly every opportunity i could. After a few months, i went back into the workshop and had a long hard think. These never ending dark dreary days have to come to an end some how Sod it. A few new phone calls and another few months and it arrived. A shiny new performance stage 3 4.6 v8 from v8 developments Top hat linered, fully balanced and lightened ported and polished heads bigger inlet and exhaust valves Custom ground solid cam Now im happy Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 17, 2013 Share Posted March 17, 2013 Very nice, but I bet your wallet isn't! Quote Link to comment Share on other sites More sharing options...
discomark10 Posted March 17, 2013 Share Posted March 17, 2013 after all the time you spent cleaning it, you buy a new one! lol but never the less, looking forward to the build! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 17, 2013 Share Posted March 17, 2013 mmmmmmm V8 Looking forward to more shiney V8 porn! Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 19, 2013 Share Posted March 19, 2013 the same block as me, not head yet, yeah, next MS and i will read your experience for help me Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 20, 2013 Share Posted March 20, 2013 Just looks like a big lump of cling film to me........ Quote Link to comment Share on other sites More sharing options...
ian_s Posted March 21, 2013 Share Posted March 21, 2013 i wonder how good clingfilm is at waterproofing the lucas electronics? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 21, 2013 Share Posted March 21, 2013 Bale wrap might be a better idea.... bit tougher? Quote Link to comment Share on other sites More sharing options...
muddy Posted March 22, 2013 Share Posted March 22, 2013 Industrial clingfilm would ve better than bale wrap. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 22, 2013 Share Posted March 22, 2013 Please stick a photo of the unwrapped engine up Bingy! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 22, 2013 Share Posted March 22, 2013 Please stick a photo of the unwrapped engine up Bingy! ****ing yes indeed!!!! Quote Link to comment Share on other sites More sharing options...
Bingy Posted March 22, 2013 Author Share Posted March 22, 2013 Well, was going to put the full engine build up, but im a bit pressed for time this weekend and i will be away all next so... or did you want them in focus as well Thasnk Nige for the apt title Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 23, 2013 Share Posted March 23, 2013 Doesn't look like a very good engine... its all blurry Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 23, 2013 Share Posted March 23, 2013 Damn fine ports you have there Quote Link to comment Share on other sites More sharing options...
Bingy Posted June 6, 2013 Author Share Posted June 6, 2013 Bit of an update So Once i had unwrapped the engine and got it onto the stand the first thing i did was to fit the Vr sensor loosly. then turn down the back of the front pulley enough to get the triggerwhell to fit niceley. As the engine didnt have the timing cover or the oil filter on, setting up the timing was easy. As with V8 there are a mark on the crankshaft timing gear and one on the camshaft timing gear. Siumply rotate the crank until they both are inline through an imagianary line on the crank and camshaft, camshaft mark to the bottom, crankshaft mark to the top. Just double check with the pencil through the sparkplug hole, Bingo. Put the bottom pulley on and the triggerwheel on. Spin the trigger wheel round so its 5 marks past the cutout. Mark the two holes through the bottom pulley with the pencil, remove and drill. Bolt back together then just check the alignment. Job Done Timing cover and new oil pump gears with new seal New water pump, timing cover, oil pump, bottom pulley, Vr sensor and brackets fitted. Valley gasket fitted, inlet manifold, injectors, fuel rail. Steering pump, alternator, idler, tensioner pulley fitted. Rocer covers and top plemum cover fitted. Sump, Engine mounts coils and stainless steel headers fitted. Onto the crane, flywheel, clutch, cutch cover and new gearbox input shaft bearing fitted. LT 85 cleaned up and bolterd to engine, together with 1.6 ratio ex mod LT 230 transferbox. Front wing removed ready for lift off Now this is heavy and hardwork on your own Still wont go in, removed wheel and front strut. Still wont go in had to remove headers All done, finally in with the gearbox and transferbox in the right position. Got a good 2nd hand early V8 wiring loom and proceeded to fit it. Steering column, stalks most of the dash is in,BUT i have a lot of issues of not knowing which wires go where, desite a lot of headscratching Need to get back to this, i have a good diagram but just cant seem to find a lot of the wires. All the pedals are done, just struggling to find the correct accelerator cable. Is there a proper part number or are they one offs? Trial fitted the gearbox tunnel and seatbox. Had to do a few mods to seatbox to get it to fit properly. (pics later) Steering finished. Brake servo ad both cylinders on. both brake and clutch pipework done. Fuel pipework just needs return to tank pipe finalising. The Start of megasqiurt wiring loom. HT leads sorted. Thats more or less where im upto.... Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted June 6, 2013 Share Posted June 6, 2013 LUSH Quote Link to comment Share on other sites More sharing options...
