xychix Posted August 9, 2014 Share Posted August 9, 2014 Hi all, Currently my series III 109 runs on 7.50R16 112L tyres. As they have to be replaces for MOT I tend to buy a new set. As it is my hobby car I will never wear these tyres out. Therefore I don't want to buy tyres that seem to big (current ones seem to hit the chassis a little bit on the rear end of the right front tyre when steering right fully. What is the standard size? What is the bigges tyre used without problems? (I like my current size for it's acceptable road speed and spot on speedometer) Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 9, 2014 Share Posted August 9, 2014 7.50 (the size you have fitted) is the correct size. Replace the current ones like for like or perhaps replace them with the metric equivalent size which is 235/85 16 You can adjust the steering lock stops to prevent the tyre from fouling Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted August 9, 2014 Share Posted August 9, 2014 750-16s are the standard fitment for 109s. There are points to adjust the steering lock stops so that they don't rub the chassis. I think they are on the front axle in the swivel hub area. You could go to 265/75/16 as I did on my Stage 1 V8 but it's really up to personal preference. It came with those tyres so I just ran with them. HTH Josh Quote Link to comment Share on other sites More sharing options...
xychix Posted August 9, 2014 Author Share Posted August 9, 2014 265/75/16 would be wider right? A french site gave my 225/75/16 as alternative. I like a small (rover look alike) M/T tyre, not something wide like one would put on a BMW x5 I don't want to eat more of my turning circle as it is already horrendous. I can't even get in my driveway in one turn, while I can do it in 1 turn with a heavy 5 meter trailer behind my ford transit thanks all for the quick replies by the way :) Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted August 9, 2014 Share Posted August 9, 2014 Wider and taller I believe. (Marginally) The turning circle is truly dreadful on a 109 I agree, fond memories of million-point-turns on narrow streets! It still looks like an LR. No X5 anywhere to be seen! Quote Link to comment Share on other sites More sharing options...
xychix Posted August 9, 2014 Author Share Posted August 9, 2014 Awesome thanks for the picture gives me an idea. I'd like to stay close to the width of the spare wheel on the bonnet. it's more the ideal hight I'm looking for. Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted August 9, 2014 Share Posted August 9, 2014 Fair enough 750/16 will do you just fine I'd say, just adjust your lock stops and you'll be just fine Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 9, 2014 Share Posted August 9, 2014 Keep the 7.50 x 16. Narrow tyre makes steering lighter. I like the avon rangemasters. It's a good general purpose tyre, wears well and keeps the MPG reasonable. Not the best in mud, but quieter on the road for that. G. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted August 9, 2014 Share Posted August 9, 2014 7.50r 16 or 235/85 r 16 virtually no difference . Adjust your lock stops to prevent fouling , if you want a bit more lock fit FC rims (more offset) allows a little tighter turning circle with standard tyres. Its a 4wd so you are never going to get a 2wd type turning radius , Quote Link to comment Share on other sites More sharing options...
Diff Posted August 10, 2014 Share Posted August 10, 2014 It looks like you have the standard Land Rover 5.5 inch wheels. The manufacturers minimum rim width for a 235/85 x 16 tyre is 6 inch so unless you want to buy new wheels, you should stick to the 7.50 x 16 tyres suggested, as they are the correct fitment. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 11, 2014 Share Posted August 11, 2014 I agree with all of the above - 7.50 will suit you best. 235/85 are a little wider, which is not ideal for Series rims (other than 1-ton or FC) and will not help steering loads or fuel economy. 225/75 would be an alternative for 6.50s on 88"s. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2014 Share Posted August 11, 2014 235/85 R16: Quote Link to comment Share on other sites More sharing options...
ian_s Posted August 11, 2014 Share Posted August 11, 2014 when i replaced my 7.50's with 235/85 the new tires were noticeably wider, and i lost a lot of turning circle until i changed to different rims Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 11, 2014 Share Posted August 11, 2014 ... and while the offset rims regain the lost steering lock, they make turning the steering wheel heavier still, so you you get a double whammy from the wider tyres. The thicker tyres will also reduce forward visibility more in the case of a bonnet mounted spare. 7.50s are better if you can find a decent quality radial in the right tread. Quote Link to comment Share on other sites More sharing options...
xychix Posted August 11, 2014 Author Share Posted August 11, 2014 I believe i ordered unipneu 7.5/16 atleast 65% offroad thread, nice looking tyre. 630 euro's fitting included. As the guy was shocked himself by the prices per tyre he fit's 4 for the price of 2. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2014 Share Posted August 11, 2014 Jeez you guys need to man up a bit - 235/85 R16's are not exactly unsteerable on a Series, they're a little bit heavier than standard. 1st outing with the 109 I was on 9.00x16 Petlas and the PAS wasn't plumbed, that built up the arm muscles a bit but even then it wasn't unusable. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 11, 2014 Share Posted August 11, 2014 235, even with offset rims or spacers, are fine running around the country, but become a little irksome when manouevering in town, especially parking. It's fine having a heavy steering vehicle as a toy, Fridge, but as an everyday vehicle it become less fun. I still manage with mine, but my wife finds it too heavy to use unless compelled, and I'm not getting any younger myself. Quote Link to comment Share on other sites More sharing options...
xychix Posted August 11, 2014 Author Share Posted August 11, 2014 for parking a series in town.... did you really say that..... I believe this is the best parking aid for a series III 109 Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 11, 2014 Share Posted August 11, 2014 the 235/80(or85)R16 on offset rims with a metro steering wheel (13") is what i run on an 88" i dont have any problems steering, yeah its a bit of a work out but thats half the fun right? Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 11, 2014 Share Posted August 11, 2014 for parking a series in town.... did you really say that..... I believe this is the best parking aid for a series III 109 wouldnt trust Klaus to park anything with a forklift! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 12, 2014 Share Posted August 12, 2014 I've never had problems parking the 109, turning it in tight spaces (with a trailer) etc. The hardest car I had to park was a non PAS Peugeot 306, MAN that WAS a shoulder builder. Just choose your line and you're grand. G. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2014 Share Posted August 12, 2014 It's fine having a heavy steering vehicle as a toy, Fridge If I could commute every day in it I would, power steering or not. I was just amused that you seem to suggest 7.50's are fine with no PAS but 235/85's which are only a little bit bigger are absolutely useless. Quote Link to comment Share on other sites More sharing options...
Pepé le Pew Posted August 12, 2014 Share Posted August 12, 2014 My daily commute serie 2a sits on 255x85x16 and I find the steering very light. Not heavier than the 235x85x16 I had before. I used to own a 110 without PAS and that had definitely heavier steering. Eric. 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted August 12, 2014 Share Posted August 12, 2014 My daily commute serie 2a sits on 255x85x16 and I find the steering very light. Not heavier than the 235x85x16 I had before. I used to own a 110 without PAS and that had definitely heavier steering. Eric. I presume these are mud terrains? I had this experience also, the profile blocks just bend when you steer, rather than drag like a roadgoing tyre. I also find that a larger offset (as in wider track) actually helps, as the wheel will roll over the road, rather than drag. One mod I did to my series 3 was to fit grease nipples to the upper swivel pin. This drastically reduced the steering effort. Also top up the idler bearing unit with oil occasionally. Daan Quote Link to comment Share on other sites More sharing options...
ToyRoverlander Posted August 12, 2014 Share Posted August 12, 2014 Or fit PAS Quote Link to comment Share on other sites More sharing options...
