Stellaghost Posted January 20, 2023 Author Share Posted January 20, 2023 3 minutes ago, elbekko said: Can you just tuck it under the wing? Have been looking at that, not sure without some sort of protection from debris kicked up from tyres Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 20, 2023 Author Share Posted January 20, 2023 Pan hard rod roughly put together and Bolted up tight Time for a bit of flexing Now the other side nothing touching as yet, will need to do the same at front but cannot yet due to snow that is left regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 20, 2023 Share Posted January 20, 2023 Blimey! Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 20, 2023 Share Posted January 20, 2023 1 hour ago, Stellaghost said: Have been looking at that, not sure without some sort of protection from debris kicked up from tyres Regards Stephen Not sure if it needs a whole lot. A small shield would probably do. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2023 Share Posted January 20, 2023 That's looks cracking! A piece of thin piece of rubber would probably be enough protection , I'm sure you could liberate some from somewhere if you don't already have some kicking around. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 20, 2023 Author Share Posted January 20, 2023 7 minutes ago, Bowie69 said: That's looks cracking! A piece of thin piece of rubber would probably be enough protection , I'm sure you could liberate some from somewhere if you don't already have some kicking around. Thanks Already got some rubber if push comes to shove Regards Stephen Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted January 20, 2023 Share Posted January 20, 2023 3 hours ago, Stellaghost said: Have been looking at that, not sure without some sort of protection from debris kicked up from tyres Regards Stephen If memory serves the lightweight bonnet covers an ammount of the top of the wing. Enough room to mount them on top of the wing and be covered by the bonnet? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 20, 2023 Author Share Posted January 20, 2023 4 minutes ago, dangerous doug said: If memory serves the lightweight bonnet covers an ammount of the top of the wing. Enough room to mount them on top of the wing and be covered by the bonnet? Will check that out, shock tops are taking some of that room up Regards Stephen Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 20, 2023 Share Posted January 20, 2023 Is this a "rated" recovery point? 🤔 Needs more Scottish Beef.......🤪 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted January 20, 2023 Share Posted January 20, 2023 6 hours ago, elbekko said: Not sure if it needs a whole lot. A small shield would probably do. You know we're now going to see a 2 inch thick plate of Rolled Homogenous Armor perfectly formed into the shape of a reservior shield. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 20, 2023 Author Share Posted January 20, 2023 2 hours ago, TD5toV8110 said: Is this a "rated" recovery point? 🤔 Needs more Scottish Beef.......🤪 Nope, not for recovery, just a winch hook holder regards Stephen Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 20, 2023 Share Posted January 20, 2023 Aye, I was teasing.....😘 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2023 Author Share Posted January 21, 2023 I have a dashboard ! Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2023 Author Share Posted January 21, 2023 @Anderzander been playing with my Christmas present... Tesa tape my new best friend so glad I've been introduced to this Been tidying up my loom this morning, yes it still looks carp but I have a better idea where I'm at now regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Stinkfloyd Posted January 21, 2023 Share Posted January 21, 2023 On 1/20/2023 at 12:12 PM, Stellaghost said: Have been looking at that, not sure without some sort of protection from debris kicked up from tyres Regards Stephen Some old rubber transport belt would suffice as good protection, no? Wonder where you could get you hands on some of that? 🤔 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2023 Author Share Posted January 21, 2023 A now very apparent downside to fitting these axles is due to my lack of height 5'7" I can no longer reach into the engine bay etc I now have to employ these..lol Regards Stephen 3 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 21, 2023 Share Posted January 21, 2023 40 minutes ago, Stellaghost said: @Anderzander been playing with my Christmas present... Tesa tape my new best friend so glad I've been introduced to this Good stuff isn’t it !! Goes on really well and has that factory look to it. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 21, 2023 Share Posted January 21, 2023 On the ladders - I was working around the turbo on the 90 and needed to stand on an axle ramp. I need to find something better .. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2023 Author Share Posted January 21, 2023 It's all a bit haphazard today, too bloody cold so just doing bits and pieces but still adds up to completion at some point Expansion tank First easy bracket drill and tap Sorted regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 21, 2023 Share Posted January 21, 2023 About the Tesa tape, note it is deceptively visible when you are applying it but if you need to remove it, after a few days the end seems to have disappeared. Out comes the knife to try to find it and the whole tape wrap then seems to take control and you have a fight. Best advice is to get the cables and positions correct first time. 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 21, 2023 Share Posted January 21, 2023 1 hour ago, Stellaghost said: A now very apparent downside to fitting these axles is due to my lack of height 5'7" I can no longer reach into the engine bay etc I now have to employ these..lol Regards Stephen You need one of those topside creepers, or whatever they are called. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 21, 2023 Share Posted January 21, 2023 51 minutes ago, CwazyWabbit said: You need one of those topside creepers, or whatever they are called. The old stand on and top forwards things? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2023 Author Share Posted January 21, 2023 Some electrical haphazardness Earth for battery Power isolator Multiple Power Point Winch isolator regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 21, 2023 Share Posted January 21, 2023 Nicely done Stephen 👏🏻 1 Quote Link to comment Share on other sites More sharing options...
muddy Posted January 21, 2023 Share Posted January 21, 2023 I learnt the hard way the issues those cheap plastic islolaters can give, I would recccamend swapping it out for This type. Quote Link to comment Share on other sites More sharing options...
