Popular Post Stellaghost Posted June 27, 2023 Author Popular Post Share Posted June 27, 2023 25 minutes ago, Ed Poore said: Watch him now graft a turbo from a scania or something onto it... Was this what you had in mind @Ed Poore.......... Regards Stephen 7 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 27, 2023 Share Posted June 27, 2023 52 minutes ago, Stellaghost said: Was this what you had in mind @Ed Poore.......... Regards Stephen R.I.P. here lies the shattered remains of a 200tdi. 💀🚑 Mike Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 27, 2023 Share Posted June 27, 2023 21 minutes ago, miketomcat said: R.I.P. here lies the shattered remains of a 200tdi. 💀🚑 Mike That's if a 200TDI has enough air to get it spinning..... Quote Link to comment Share on other sites More sharing options...
NRS91 Posted June 27, 2023 Share Posted June 27, 2023 I can help you gain an easy 25-30hp with a Boost Pin and my Dynamic Timing Advance Spacer kit 😉 (full details on what they are and how they work on my website). As for VNT control I have tried boost controlled and vacuum controlled using a DigiBooster and they both felt a little clunky. I would like to try a little double acting air cylinder which uses exhaust back pressure to open the vanes and boost pressure on the other side to slow down the rate of opening. This should get you near the optimal 1:1 boost:drive pressure ratio to give you sprightly performance without high EGTs or fuel consumption. A 2256v off an Audi or Iveco would be the one to look at 2052v is a little small. Food for thought. 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 27, 2023 Share Posted June 27, 2023 14 minutes ago, Bowie69 said: That's if a 200TDI has enough air to get it spinning..... Just convert it into a supercharger by running it off of the flywheel ring gear 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 27, 2023 Share Posted June 27, 2023 2 hours ago, CwazyWabbit said: Was it this one? Perhaps, it was a long time ago. There's another thread about an Audi VNT fit which points back to that thread. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 27, 2023 Author Popular Post Share Posted June 27, 2023 Honey, I'm home ......... Regards Stephen 8 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 27, 2023 Share Posted June 27, 2023 Well at least Sid's roof is still intact which is a good sign. 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 27, 2023 Share Posted June 27, 2023 Recovery truck drivers really are a special breed aren't they Quote Link to comment Share on other sites More sharing options...
NRS91 Posted June 27, 2023 Share Posted June 27, 2023 looks like theyve done the usual trick of bending the jockeywheel 🤐 Quote Link to comment Share on other sites More sharing options...
Wytze Posted June 27, 2023 Share Posted June 27, 2023 11 minutes ago, NRS91 said: looks like theyve done the usual trick of bending the jockeywheel 🤐 I think sid did that😁 Pushing down harder on it then it could take💪 1 Quote Link to comment Share on other sites More sharing options...
Popular Post steve b Posted June 27, 2023 Popular Post Share Posted June 27, 2023 A bent jockey wheel is right at the bottom of the list of issues with that trailer..... Steve 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 27, 2023 Author Popular Post Share Posted June 27, 2023 So for those that are interested here is a bit of a shakedown review from Sid's first outing The good My welded diffs held together, had discussed this with @Bowie69 the welded diffs because they were cast iron welded were my major concern, however they stood up to the abuse they were given Ground clearance Crawl speed Suspension and articulation Ride was never bouncy Steering rod clearances @CwazyWabbit will know what I mean Most of my fabrication work held together Front single link set up worked well, I think spending decent money on shock absorbers helped to keep side roll good Seats were great The bad 2" plus springs were terrible tyres High box Not doing the important things like temp gauge and oil pressure light Spare wheel carrier was a wobbly joke On the fabrication side, my air lockers were intermittent, don't know if they had just been left too long and the inside surfaces lost some of the oil coating My forged steering arm looks to have bent slightly, not through being hit just not up to the strain will need to brace or fab a new one up On the whole I am very pleased, like @Daan stated the car just needs dialing in a bit, any thoughts are always appreciated good or bad Regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 27, 2023 Share Posted June 27, 2023 6 minutes ago, Stellaghost said: My forged steering arm looks to have bent slightly, not through being hit just not up to the strain will need to brace or fab a new one up I can't remember was it tube or solid? Might be stronger if it's tube? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 4 minutes ago, Ed Poore said: I can't remember was it tube or solid? Might be stronger if it's tube? Solid Regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted June 27, 2023 Share Posted June 27, 2023 1 minute ago, Stellaghost said: Solid Regards Stephen S355 iirc? Maybe something like EN9 might be stiffer? Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 27, 2023 Share Posted June 27, 2023 Pretty fair summary! Steering box? Did you find out if it was the seal or a bent output shaft? I realise I have a 6-bolt out of LGT that are supposed to be HD, I think? Could send up with springs if you so desire.... 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 1 hour ago, Bowie69 said: Pretty fair summary! Steering box? Did you find out if it was the seal or a bent output shaft Well remembered Forgot about that, not checked properly as yet, just washed most of the Welsh mud off it in my neighbours field Regards Stephen Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 27, 2023 Share Posted June 27, 2023 That is a hell of a result for a first time out and something that’s had so much work that’s never been done before with little testing. Top marks sir! I think I did the gear ratios for you earlier in the thread(I’m not scrolling all the way back there😂), with your set up and a 1:1 box, your gearing will be approximately the same as a standard defender but a lower low ratio(obviously) Re steering arms; I’ll dig out some photos of some high steer arms for you, they’re mostly for hydro but you can use the mog arms for the track rod and the high steer arm for the drag link as I plan to do…. if you fancy switching to the correct engine….I have a 4.6 short block here, some heads and a few other bits and pieces to make maybe 70% of the engine. yours if you want it in return for the flanges👍 3 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 2 hours ago, Bowie69 said: I realise I have a 6-bolt out of LGT that are supposed to be HD, I'll pass on that for now as I have a good 4 bolt to put on, but thank you all the same Are they stronger, there seems to be different views on this Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 27, 2023 Share Posted June 27, 2023 food for thought 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 1 hour ago, dangerous doug said: That is a hell of a result for a first time out and something that’s had so much work that’s never been done before with little testing. Top marks sir! I think I did the gear ratios for you earlier in the thread(I’m not scrolling all the way back there😂), with your set up and a 1:1 box, your gearing will be approximately the same as a standard defender but a lower low ratio(obviously) Re steering arms; I’ll dig out some photos of some high steer arms for you, they’re mostly for hydro but you can use the mog arms for the track rod and the high steer arm for the drag link as I plan to do…. if you fancy switching to the correct engine….I have a 4.6 short block here, some heads and a few other bits and pieces to make maybe 70% of the engine. yours if you want it in return for the flanges👍 Thanks, I probably had less teething issues than I thought I was going to have A 1.1 box/ gears will be a sensible 1st move I think Just had a look at some high steering set up's, should be pretty easy to configure and fab up Way too generous on the short block etc, the flanges did not consume that much time, but very nice of you indeed. Going to explore the 200tdi tuning for now because it's convenient and I need to catch up on some neglected diy jobs Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 57 minutes ago, dangerous doug said: food for thought Wow @dangerous doug that's excellent info Thank you Regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 27, 2023 Share Posted June 27, 2023 11 minutes ago, Stellaghost said: Are they stronger, there seems to be different views on this I understood they stuck them on the 130 ambulances like @FridgeFreezer@FridgeFreezer's for that reason.... But I could be wrong. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 27, 2023 Author Share Posted June 27, 2023 1 minute ago, Bowie69 said: I understood they stuck them on the 130 ambulances like @FridgeFreezer@FridgeFreezer's for that reason.... But I could be wrong. When I did a bit of looking it was actually Nige on here that said they were weaker ??? Not saying your wrong and your knowledge is streets ahead of mine Regards Stephen Quote Link to comment Share on other sites More sharing options...
