Anderzander Posted May 31, 2022 Share Posted May 31, 2022 Are you coming up north ? Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 31, 2022 Share Posted May 31, 2022 That crane is Skookum as Frigg, as I believe the saying goes. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted May 31, 2022 Share Posted May 31, 2022 2 hours ago, Stellaghost said: But if I did that you would want it lol......... Regards Stephen Nope Few hundred kilos at 8m and a little over a tonne up close I think. If I need heavier the 2CX will lift 2t to 14ft Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 1, 2022 Author Share Posted June 1, 2022 Up up and away regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted June 1, 2022 Share Posted June 1, 2022 Dom has an interesting engine crane he's restoring here: It has adjustable height as well as the hydraulics. Steve Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 5, 2022 Author Share Posted June 5, 2022 Demolition progress needle gun debris some work to do regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Popular Post CwazyWabbit Posted June 5, 2022 Popular Post Share Posted June 5, 2022 3 minutes ago, Stellaghost said: Demolition progress --SNIP-- At first glance I thought you'd upgraded the rear wheels on your engine hoist! 1 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 5, 2022 Author Popular Post Share Posted June 5, 2022 Seriously......lol I love this crane regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 5, 2022 Share Posted June 5, 2022 That crane wouldn’t look out of place popping an engine into a big ship Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted June 6, 2022 Share Posted June 6, 2022 19 hours ago, CwazyWabbit said: At first glance I thought you'd upgraded the rear wheels on your engine hoist! I thought the same too! 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 6, 2022 Share Posted June 6, 2022 22 hours ago, Stellaghost said: some work to do Less than I thought from the first look when you lifted the body 😊 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 38 minutes ago, Anderzander said: Less than I thought from the first look when you lifted the body 😊 To be fair now I've needle gunned it, it's not bad and if I wasn't putting mog axles on it would only be a couple of patches and out riggers Although I'm not anticipating it will take me long to sort out, the pain will be test fitting stuff before I'm in a position to paint chassis and build up for good regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 One irony that's come out of this is I needn't of built the A frame but at the time I did not realise I was going to aquire the engine crane. However I'm sure it will come in for something Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 @landrovers hi Ross Where did you order your fox shocks from and what is the stroke please regards Stephen Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 6, 2022 Share Posted June 6, 2022 I have the FOX 2.0 shocks on my 90 in plus 50mm size. I bought them from Gigglepin who are the only uk supplier I found when I looked for defender specific fitments Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 6, 2022 Share Posted June 6, 2022 2 hours ago, Stellaghost said: @landroversforever hi Ross Where did you order your fox shocks from and what is the stroke please regards Stephen Fixed the tag ⬆️ 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 2 hours ago, L19MUD said: I have the FOX 2.0 shocks on my 90 in plus 50mm size. I bought them from Gigglepin who are the only uk supplier I found when I looked for defender specific fitments Yes you've mentioned this previously, how good are they ?? I'm looking at the Fox adjustable dampening ones my thoughts being I could stiffen them up for road use and reduce roll on corners with the single link set up I'm going with at the moment The prices are eye watering Also there isn't enough information on the sites ie: piston stroke, I'm looking to get a minimum of 10" more would be better , @L19MUD how much stroke do your shocks have ? Any info from anyone would be great, would it be cheaper to import them myself ?? Thoughts please regards Stephen Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 6, 2022 Share Posted June 6, 2022 13 minutes ago, Stellaghost said: Yes you've mentioned this previously, how good are they ?? Also there isn't enough information on the sites ie: piston stroke, I'm looking to get a minimum of 10" more would be better , @L19MUD how much stroke do your shocks have ? I fitted them to the back initially around 7 years ago and added them to the front 2 years ago when I did my rebuild. It is hard to give a totally solid comparison as I inevitably went from tired oil filled to the gas Fox ones. My feeling is that the 90 does not crash over bumps now and I get a more comfortable ride at all speeds. A mate of mine who had a TD5 90 Van always comments on how much nicer the ride feels in my 90 compared to his totally standard spring/shock/wheel setup. In theory mine should be worse as I have the genuine HD suspension spring setup with 2 inch lift blocks and 285/75 R16 tyres I would give Jim at Gigglepin a ring as they have always been really helpful with me 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 6, 2022 Share Posted June 6, 2022 Stephen, they came from Blackbird Industries. Part owned by our very own @discomikey . It’s been that long… I think they’re 14” travel fronts, and will be 12” rears. The 14” cause a lot of tyre clearance problems but you should be ok with the portals. How wide did you end up at in the end? 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 57 minutes ago, landroversforever said: Stephen, they came from Blackbird Industries. Part owned by our very own @discomikey . It’s been that long… I think they’re 14” travel fronts, and will be 12” rears. The 14” cause a lot of tyre clearance problems but you should be ok with the portals. How wide did you end up at in the end? Cheers Ross @discomikeycan be difficult to get hold of and not responding to pm's at the moment Width to tyre outside edges is 74" my lightweight on 265's is 71" so I've managed to get total width down to only 1 1/2" extra per side, pretty happy with that regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 6, 2022 Share Posted June 6, 2022 Not entirely sure when he was last on here. He is difficult to contact, but they’re totally flat out at the moment (spoke to him on the phone this afternoon!). Either them or go direct to prolinx. Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted June 6, 2022 Share Posted June 6, 2022 (edited) Here in Australia these are the dogs gonads... SUPERIOR ENGINEERING - Custom Valved Shocks – KINGPIN Fab (kingpindesignandfab.com.au) Edited June 6, 2022 by TD5toV8110 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 6, 2022 Author Share Posted June 6, 2022 15 minutes ago, TD5toV8110 said: Here in Australia these are the dogs gonads... SUPERIOR ENGINEERING - Custom Valved Shocks – KINGPIN Fab (kingpindesignandfab.com.au) Wow they look very nice indeed regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 7, 2022 Share Posted June 7, 2022 A friend recently fit the OME BP-51s. From what I've heard he's happy with them. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 7, 2022 Author Share Posted June 7, 2022 1 hour ago, elbekko said: A friend recently fit the OME BP-51s. From what I've heard he's happy with them. I think he should be I've just priced them...............ouch Regards Stephen Quote Link to comment Share on other sites More sharing options...
