Mutley Posted September 15, 2018 Share Posted September 15, 2018 Ok so changed the oil in the transfer box on my Defender 90 300Tdi.... i do about 5000 miles a year so not much, but do like to change all fluids once a year. So i have done this a few times! I just don't remember putting the new oil EP90 in being that difficult in the past!?! So what are you guys using to get the oil into the Transfer Box? I have seen the 500ml syringe and the small pump bottle, i appreciate with EP90 it's going to be slow going in but what make and model pump type do you guys recommend for the job? Cheers Andy Quote Link to comment Share on other sites More sharing options...
rtbarton Posted September 15, 2018 Share Posted September 15, 2018 I have a modified propane cylinder. Dip tube to the bottom and a means of introducing compressed air to the top. There's a gate valve and spout at the end of a long flexible pipe. Connect it up to about 20 psi and crawl around under the vehicle to top up gearboxes & axles. Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 15, 2018 Share Posted September 15, 2018 We use for the oil changes a Pela 6000 Heat up engine (=oil), take out dipstick and pump it out. Works also very good for the other oils. To fill the gearboxes, we heat the oil and use a tube with a funnel on the end and and fill it from way up.. Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2018 Share Posted September 15, 2018 I just changed the oil on my transfer box too, I bought 2 of these from this site http://draper.thetoolstoredirect.co.uk/Draper-23242-FHP-1L-1L-Multi-Purpose-Pump?search=23242 I use 1 for axles/transfer box & 1 for main gearbox. Quote Link to comment Share on other sites More sharing options...
Mutley Posted September 15, 2018 Author Share Posted September 15, 2018 I was looking at the very same one Western, how did they cope and are they worth a punt? Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2018 Share Posted September 15, 2018 Did the job great, takes quite a lot of pumps & only holds 1 litre, so a few fills will sort the TB oil, once you stop pumping the oil in the tube doesn't drain out all over the floor, so I quite happy with them. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 15, 2018 Share Posted September 15, 2018 I have two of the Draper type but bought from Aldi’s “aisles of randomness”. They are also up to the job and as Mr@V8 Freak has shown me, you can add a tyre fitting and hook it up to an air pressure source. 1 Quote Link to comment Share on other sites More sharing options...
Mutley Posted September 15, 2018 Author Share Posted September 15, 2018 Ok so i have realised why it was harder/more difficult this time to refill the TB!!!..... Being a complete Muppet i used the WRONG filler hole!!!.... Instead of using the one behind the handbreak drum, i used the one higher up nearest the passenger side up by the chassi rail! Doh.... it's gotta be an age thing!?! Just glad i actually put EP90 in and not ATF!!!! Any way have just checked taking off the right filler plug, it was about 500ml over filled and has only done 5 mile, so some sort of result at least??? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 15, 2018 Share Posted September 15, 2018 I just use a garden sprayer (quick search reveals they're about £8 from screwfix). Fill up with oil, pressurise, insert nozzle into transfer box, place rock on trigger, play with dogs and suddenly remember to go and check on it, usually just after it starts pouring out. Cheap enough to keep one per kind of oil. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 15, 2018 Share Posted September 15, 2018 I think mine are garden sprayers. They hold 5l and I also have two. They have made the oil changes much easier. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 16, 2018 Share Posted September 16, 2018 I've got the B&Q sprayers.... I think £15 each from memory. Quote Link to comment Share on other sites More sharing options...
Mutley Posted September 17, 2018 Author Share Posted September 17, 2018 Having remembered which filler hole to use on the TB, i also remembered what i use to fill it with The spout fits the filler hole nicely plus has a screw on cap untill you are ready and with it having a screw on lid, once the flexi spout is in the filler hole just rotate the jug upside down and let it drain, i use the 1Lt jug so 2 and a bit and we are good to go!.....Memories a wonderful thing!!!!! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 17, 2018 Share Posted September 17, 2018 I've had one like this for years. The spout has a 90 degree bend that's ideal for filling main or transfer gearboxes. https://www.workshopping.co.uk/product/gear-oil-transfer-pump/TP67/ I also have a similar but almost antique version that I use for filling our tractors with hydraulic oil. I picked it up at an auto jumble years ago. Quote Link to comment Share on other sites More sharing options...
paintman Posted September 17, 2018 Share Posted September 17, 2018 I just use one of the old 500ml gearoil bottles, the type that came with a pipe with a hook on the end that fits in the fill hole & a straight pipe that fits on the inside of the bottle cap & goes to the bottom of the bottle so squeezing the bottle pushes the oil out form the bottom. OK so I have to refill it a few times - which I do in an old washing up bowl so any drips are contained - but it works & cost nothing :) Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted September 17, 2018 Share Posted September 17, 2018 I use the same as paintman with a length of tube attached. The biggest help is warming the new oil prior to filling. I can squeeze in a litre of EP in seconds. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted September 17, 2018 Share Posted September 17, 2018 While I appreciate the topic is "handpump"... I used one of these instead. Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 5, 2018 Share Posted October 5, 2018 I bought somthing similar ^^^ 12v oil transfer pump, not actually given it a shot yet, but peanuts from China, and worth a punt. Quote Link to comment Share on other sites More sharing options...
