Mean Green Posted July 5, 2020 Share Posted July 5, 2020 The filler plugs on both swivel hubs are rusted solid and are at a real risk of rounding. I have tried soaking with both WD40 and plus Gas but it is not helping. Can I fill the hubs through the top swivel pin? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 5, 2020 Share Posted July 5, 2020 Tons of heat in cycles - from a blow torch. You can file the plug flat and get something to fit it nice and tight if you need to - a good adjustable works well. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 5, 2020 Share Posted July 5, 2020 A good heavy weld to the top of it will put a decent amount of heat into it. should be able to free it off. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 5, 2020 Share Posted July 5, 2020 I’ve had to hammer sockets on before to get them off. The square design is not good and they are one of those parts that is exposed to lots of corrosion but not undone regularly, as a result I keep spares in case I have to resort to such measures. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 6, 2020 Share Posted July 6, 2020 You can get brass or stainless versions from the hydraulics shop, a lot of them are BSP or BSPT thread standard blanking plugs. For bonus points you can get them with magnets in to collect any swarf/debris - Nige makes some lovely ones that have insanely strong magnets in: https://megasquirt-v8.co.uk/diff_offroad.php Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 6, 2020 Share Posted July 6, 2020 When your trying to undo them, give them a good belt on the end with a hammer, the shock will help break the crust up. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 6, 2020 Share Posted July 6, 2020 The plugs should be taper thread, so they only need to be nipped up with light finger pressure - you will feel them tighten as they are wound in. No need to "torque them up" tight. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted July 7, 2020 Share Posted July 7, 2020 I've fitted all plug locations which didn't already have magnetic plugs with a regular steel plug with a high strength magnet glued to it. Every time I remove one of these plugs, either for an oil change or just a check, there is a "bloom" of material on it. I've learnt to not be alarmed by this since if you smear it on garage cleaning paper it amounts to no more than oil/grease with a very small amount of ferrous material in it, although enough to make it magnetic. I also have a magnetic sleeve for my engine oil filter and when I used to check the filter content at oil change the residue there used to frighten me. There's no apparent deterioration in my 300Tdi engine, so I no longer worry about the "bloom". Likewise for my transmission and differential drain plugs. Yes, I do recommend fitting magnetic plugs to all oil drain points. Mike Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted July 7, 2020 Share Posted July 7, 2020 Freeze/Heat Warm it up to hot, then when it's cooled , use plumbers freeze spray to super-cool it. I made up a socket, using a pin socket and then used the rattle gun to assist in breaking the rust bond Quote Link to comment Share on other sites More sharing options...
monkie Posted July 7, 2020 Share Posted July 7, 2020 I don't apply heat to the plug as that will make it easier to accidentally round off if you get it really hot followed by some force. Instead, I get the area surrounding the plug hot with a blow torch to expand the threads around the plug followed by a good few whacks with a hammer directed traight on the plug itself. Then try to undo it. I think if you do it like that it should come undone. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 8, 2020 Share Posted July 8, 2020 Blimey.... I am going to sound like mmgemini.... My plugs never get stuck as I undo them to check the levels every 6000 miles 🙂 1 Quote Link to comment Share on other sites More sharing options...
