Hybrid_From_Hell Posted December 9, 2022 Share Posted December 9, 2022 Mate has been having weird misfires and engine rattling ... Turns out 4 of his inlet trunpets are not where they should be and have worked loose and bouncing around inside the plenum whats they best stuff / is there special gloop that glue these in ? Trumpet base and trumpets in my ultrasonic cleaner / have knocked all of them out (some were loose) so will be looking to glue in all 8 ?? Nige Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 9, 2022 Share Posted December 9, 2022 Waxoil? 😁 I'll get my coat.... 2 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 10, 2022 Share Posted December 10, 2022 I could take a few guesses / best pick from the various goops I have on the shelf but in your position but I would be calling Loctite's technical helpline to see what they suggest, they're very helpful folks who like a challenge! Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 10, 2022 Share Posted December 10, 2022 Clean and key the surfaces and JB weld. Make sure any porting is done first though, as they will be extremely difficult to remove afterwards. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted December 10, 2022 Share Posted December 10, 2022 On 12/9/2022 at 10:04 AM, Hybrid_From_Hell said: Mate has been having weird misfires and engine rattling ... Turns out 4 of his inlet trunpets are not where they should be and have worked loose and bouncing around inside the plenum whats they best stuff / is there special gloop that glue these in ? Trumpet base and trumpets in my ultrasonic cleaner / have knocked all of them out (some were loose) so will be looking to glue in all 8 ?? Nige Loctite 638 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 11, 2022 Share Posted December 11, 2022 20 hours ago, smallfry said: Clean and key the surfaces and JB weld. Are you sure? I thought JB weld was one of those super-useful fixes that's also almost always the wrong answer for whatever it's used for? 1 1 Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 11, 2022 Share Posted December 11, 2022 Gripfill 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 11, 2022 Share Posted December 11, 2022 33 minutes ago, FridgeFreezer said: Are you sure? I thought JB weld was one of those super-useful fixes that's also almost always the wrong answer for whatever it's used for? To be honest Fridge, it has been the right answer for whatever I have used it for. It has always exceeded my expectations. I wouldnt use it for anything structural, but I cannot think of anything that I have used it for, and it has failed. The automotive things I have used it for include are gluing a mounting lug on a gearbox bellhousing, building up a thermostat housing and water outlet, sleeving up a steel hose outlet to take it from 14mm to 19mm using a bigger tube. Sticking a broken alternator mounting lug on a tractor. All have been done a few years despite me expecting them to fail. I have pieced together a 75 year old toilet pan with it, including under the water line, handle on a saucepan, handles back on broken mugs. 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 11, 2022 Share Posted December 11, 2022 1 minute ago, smallfry said: To be honest Fridge, it has been the right answer for whatever I have used it for. It has always exceeded my expectations. I wouldnt use it for anything structural, but I cannot think of anything that I have used it for, and it has failed. The automotive things I have used it for include are gluing a mounting lug on a gearbox bellhousing, building up a thermostat housing and water outlet, sleeving up a steel hose outlet to take it from 14mm to 19mm using a bigger tube. Sticking a broken alternator mounting lug on a tractor. All have been done a few years despite me expecting them to fail. I have pieced together a 75 year old toilet pan with it, including under the water line, handle on a saucepan, handles back on broken mugs. Must admit I've always had excellent results when I've used JB weld regards Stephen Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 12, 2022 Share Posted December 12, 2022 12 hours ago, Jon White said: Gripfill 👍🏻 Or CT1 Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 12, 2022 Share Posted December 12, 2022 Will gripfill or CT1 handle the temperature? Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 12, 2022 Share Posted December 12, 2022 100c I believe for ct1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 12, 2022 Share Posted December 12, 2022 Ehem..... 'Someone' asking the same question 12 years ago... 4 Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 12, 2022 Share Posted December 12, 2022 44 minutes ago, Bowie69 said: Ehem..... 'Someone' asking the same question 12 years ago... So the question is - can Nige remember what he ended up using that time...? And, I guess, did it last? 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 12, 2022 Share Posted December 12, 2022 What sort of temp does that bit get to? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 12, 2022 Share Posted December 12, 2022 100C is quite possible. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 12, 2022 Share Posted December 12, 2022 Loctite 648 should be good then if the parts are a good fit. Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 12, 2022 Share Posted December 12, 2022 The reason I mentioned CT1 is it does have some flexibility, albeit not a lot. Whether it’s suitable temperature wise remains to be seen.. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 12, 2022 Share Posted December 12, 2022 44 minutes ago, Badger110 said: The reason I mentioned CT1 is it does have some flexibility, albeit not a lot. Whether it’s suitable temperature wise remains to be seen.. 5 to 40oC according to the data sheet. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 13, 2022 Share Posted December 13, 2022 23 hours ago, Badger110 said: The reason I mentioned CT1 is it does have some flexibility, albeit not a lot. As impressive as its list of purposes is, the fact it's a construction / DIY sealant & adhesive and not an automotive/industrial product would make me suspicious of its suitability, we know from experience that certain things (EG standard silicone sealant) cause damage to automotive things (lambda sensors Vs acetic acid given off by the sealant) even if they appear to "work fine". Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 13, 2022 Share Posted December 13, 2022 You should only be using neutral cure silicone sealers on mechanical stuff anyway. This does NOT contain acetic acid (Acetoxy cure) which is really only meant for building applications. It is also cheaper, and does not adhere as well as neutral cure stuff to metals. All proper RTV silicone sealers for automotive use are neutral cure, except blue Hylomar which was Acetoxy, (smells of vinegar) last time I smelt it, which TBH was years ago. Quote Link to comment Share on other sites More sharing options...
