Something for the weekend sir?
Les Henson
Bizzy bizzy bizzy this weekend - no peace for the wikkid etc :)
I finally got all the bits I need to fix the Free S3 and the TD engine that's plonked in catflap.
TD bits:-
Remove head and sump, pop out the pistons, replace rings, re-seat valves, replace the timing belt and tensioner, crank woodruff keys, along with timing belt, new inner and outer crank seals, crank sprocket, camhaft seal too, plus all necessary gaskets.
Make new chassis mounts to sit the engine in the correct position.
The Free S3:-
Dress the cylinder bore, replace the wrecked piston, replace both valves for No1 cylinder, and re-grind all of them, reassemble the engine and run for a while. Arrange for MOT early next week.
So, what are you doing this weekend?
Les :)
Finish my own 90 (suspension mods), then Kittygripper spades to bend up, and TIG weld (that will be a mess not too good (read dreadful) at Ali welding) rear suspension wheel box "Raisers", and change petrol tank too.
Sunday SWMBO has booked it (gardening - hedge lawns and tidy my rubbi...er spares from HER Shed !
..........so early start and late finish Staurday :lol:
..............Lie in Sunday.... late start, and early finish with some luck :P
Nige
Picking up the New Caravan in the newly MOT'd and actually back on the road Discovery :)
And try to think about sorting out the car trailer, and checking everythings ready for next weekend, after Testing the Caravan over the weekend....Monday = Day off... :P
Probably working too :(
Finish fixing up the new Escort (fit new column stalks, oil flush check it over. Fit new oil level sensor if I can find the old one on the back of the engine block). Maybe start stripping down the Range Rover engine if I get the time.
After fixing the PAS box leak 2 months ago (which ha now come back) I'll be fitting a new PAS box to the Discovery. The leaks not too bad but, I'm off to Libya in four weks so don't want to take any chances. Still got a few other things to check/ service in prep for the trip.
Ivan
- might lift the tarpaulin off the snakey to work on that - needs [paint tidy, a hole patching (undecided how I will do that) and civ lensts to fit.
- see if I have a water leak from inlet manifold
- finish off dash?
- go for a ride on the mtb
A TOP TIP.
Since I had 16 valves to grind in, I used fine grinding paste (jeweller's rouge actually), wrapped some inner tube on the valve stem and spun the valves in a cordless drill - worked well and much quicker than by hand especially since I did not have the suction cup tool. (the inner tube prevents marking the valve stem - no guesses how I figured that out)
Working Sat :angry:
drop off misses racer at stinning in Bournmouth then finish belly guard off on my racer and take it home and strip all stickers off and remove all seals and plastic trim and load back on trailer to be taken up to Marlboro for its respray.
I need a holiday :(
I shall be going out with the tiverton stag hounds tommorow during the day to chase a stag around exmoor somewere.
Then out on the p*** saturday night.
Recover sunday
Go out with the quantock stag hounds on monday to chase a stag about on the quantocks
Mine and a TD5 to service on Sat morning. Getting some climbing in on Saturday afternoon. :) Out for a few beers Sat night. More training for my trainee search dog on Sunday morning, DIY Sunday afternoon, off Monday to fit new albrights and loads of other prep for next weekends challenge
Glad you reminded me - I'm hoping to get time to follow my local fox pack tomorrow too.
do they still hunt with a full pack? tauton vale and west somerset fox hounds do.
you should try coming out with one of the three stag hounds packs its abit more blood thirsty but its more fun from a spectators view as you tend to see abit more. give me a shout next time your in devon or somerset as theres hunting 6days a week if you want to go.
sorry for going of topic
Out tomorrow evening,food & wine & beer
I shouldn't leave the pc as I'm late with the job but will probably end up greasing the yokes/shafts
and checking fluid levels in the afternoon...oh,and some terribly late stickers...
:rolleyes:
Another busy Sat of mine...
<_<
