dirkthe1 Posted October 14, 2010 Share Posted October 14, 2010 As it sounds really. After losing a few litres of deisel on a nice conctrete floor, its stained rather nicely. Can anyone suggest a cleaner/solvent that will remove it? I have tried the swarfega oil and degreaser which hasnt done much to it (in fact i think it may have made it worse!) Quote Link to comment Share on other sites More sharing options...
simonr Posted October 14, 2010 Share Posted October 14, 2010 I think your only options are to absorb it in something else or let (help) it evaporate. If the diesel was clean, it won't leave a stain long term. Si Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted October 14, 2010 Author Share Posted October 14, 2010 And if it was red that had been in the tank a long, long time (so much so there was 4 inches of sludge and sediment at the bottom? I threw a load of the "nappy" absorbant mats down which got alot of it, its just its a nice flat screeded workshop floor!! Im presuming it would have to be something with ammonia in it to get it out well? Quote Link to comment Share on other sites More sharing options...
Phillis Posted October 14, 2010 Share Posted October 14, 2010 horse tiddle has lots of ammonia in it. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted October 14, 2010 Share Posted October 14, 2010 Floor paint? Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted October 14, 2010 Share Posted October 14, 2010 This might sound crazy... but perhaps try rubbing a tub of cheap margerine into the stain, and then using fairy liquid to remove it. (This is what my mum does when i get my clothes oily) Sounds silly, but it might just work, and its cheap! Quote Link to comment Share on other sites More sharing options...
pete3000 Posted October 14, 2010 Share Posted October 14, 2010 cat litter for the soaking up action (fullers earth). Then some nice biological washing powder and a scrubbing brush. Choose your own fragrance. Of course you know know you should have painted the floor first. Quote Link to comment Share on other sites More sharing options...
vinny Posted October 14, 2010 Share Posted October 14, 2010 I use petrol on waste oil, mop up what you can with rags, pour on some petrol and scrub it in with a nail brush. Then mop this up with some more rags. Its quick and it removes 90% of a black oil-y stain?! Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 14, 2010 Share Posted October 14, 2010 Or just splosh some more diesel around the rest of the floor to make it all match, clean it up then walk away whistling. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 14, 2010 Share Posted October 14, 2010 If slippyness isn't a prblem I'd agree with the above. A steam clean may shift the worst of it, otherwise it will break down eventually. Any residue or contamination will be what leaves the stain long-term. Quote Link to comment Share on other sites More sharing options...
jbs Posted October 15, 2010 Share Posted October 15, 2010 Now this is going to sound even stranger but I used-the last time I wanted to remove oil stain's from my concrete paving slabs that make up my driveway-Mr Muscle oven cleaner after seeing a thread on here about the very same situation, I also used a broom to scrub it in with and then pressure washed it all off-you won't get it all out but it'll get most of it off HTH John Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 15, 2010 Share Posted October 15, 2010 I've used Mr Muscle on oil stains before too, took most of it off, and the remaining bit went away by itself after a couple of days of rain I suspect though, a paving slab (or monoblocking in my case) isnt quite as porous as a poured concrete floor. The floor in my garage seems to act like a sponge though. i spilled a load of EP90 in one corner (Standing that "drained" axle case on its end is NOT a clever idea), scooped up the worst of the puddle got Mildly miffed off and left it. Came back a few weeks later and it had all "soaked in", and a while after that the dark stain faded away. No idea where it went mind Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 15, 2010 Share Posted October 15, 2010 Try brick cleaner, available from any DIY/hardware shop Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted October 15, 2010 Share Posted October 15, 2010 I've been told Coca-Cola is the Daddy when it comes to removing oil/diesel stains. I'm going to try it on the road outside my drive where I normally park the Disco this weekend and can report back. Quote Link to comment Share on other sites More sharing options...
fozsug Posted October 15, 2010 Share Posted October 15, 2010 I've been told Coca-Cola is the Daddy when it comes to removing oil/diesel stains. I'm going to try it on the road outside my drive where I normally park the Disco this weekend and can report back. Coca-Cola is also excelent for using instead of WD40 on rusty bolts and nuts, but it must be proper Coke not Asda or Tesco own brands Quote Link to comment Share on other sites More sharing options...
Pinn76 Posted October 15, 2010 Share Posted October 15, 2010 I freed off an old outboard engine a few years back with coke-a-cola. after 2wks soaking with wd no joy, 2 nights with that in there had it free enough to disassemble. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 15, 2010 Share Posted October 15, 2010 It also corrodes stainless steel, dissolves steak and can be used to clean toilets amongst other things. Quote Link to comment Share on other sites More sharing options...
piper109 Posted October 15, 2010 Share Posted October 15, 2010 I freed off an old outboard engine a few years back with coke-a-cola. after 2wks soaking with wd no joy, 2 nights with that in there had it free enough to disassemble. Clean concrete with muriatic acid. Use Red-ex soak to free engine. Steve Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted October 15, 2010 Share Posted October 15, 2010 The Coca-Cola disolving steak thing is a myth, it doesn't happen. And I very much doubt it corrodes stainless steel, I'm off to perform an experiment now.... Quote Link to comment Share on other sites More sharing options...
b50bsa Posted October 15, 2010 Share Posted October 15, 2010 I'm not sure what you would call ether of these in the UK, but I have removed oil stains from concrete by putting "Kitty litter" on the stain and then squirting "brake clean" on top of that. I can only guess that the "brake clean" goes through the "kitty litter", solves the oil, and allows the whole mess to be absorbed by the "kitty litter" H Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 16, 2010 Share Posted October 16, 2010 Caustic Soda? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 17, 2010 Share Posted October 17, 2010 Blow lamp? I have heard a rumour that diesel will eventually burn....? Quote Link to comment Share on other sites More sharing options...
Steve 110 Posted October 21, 2010 Share Posted October 21, 2010 Coca cola is what the state troopers use to remove blood stains on the motorways in the us so I guess must be pretty effective. There is some sort of citric acid based cleaner (italian brand banned from switzerland ) that's supposed to be the mutz dangles to remove stains from driveways... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 22, 2010 Share Posted October 22, 2010 Coca cola is what the state troopers use to remove blood stains on the motorways I'm pretty sure that's an urban myth. Quote Link to comment Share on other sites More sharing options...
hobson Posted October 22, 2010 Share Posted October 22, 2010 I'm not saying that the above is true or false, but it makes sense, i know that Coca-Cola cleans things REALLY well because of all the chemicals in it (not that i'm saying it's harmful of course!) i know people who use it to clean all sorts of things from golf clubs to car parts. and i know just how good it is as my wife used to work for Barr Drinks before the plant closed and she tells me they used to use coke as a degreaser and cleaner in the industrial machines. and because she's witnessed first hand what goes in it, she now won't touch the stuff, and frowns when i have the very occasional can! Even if state troopers did use it, they'd have to keep it quiet, i can't imagine a huge company like Coca-Cola endorsing their human-consumption product for use cleaning up blood can you? If anyone wants to test it, get a glass of coke and leave an old 1p/2p coin in it overnight, see what happens. But back to the OP, there's a company called Oiltechnics who sell oil cleaning products to the navy etc, try them, but my guess is by now the stuff is either cleaned up or really well soaked in, so the best thing you could do is burn off any remaining and paint over the mess. Quote Link to comment Share on other sites More sharing options...
