Mark Posted November 27, 2006 Share Posted November 27, 2006 Managed to bend the exhaust on the disco on sunday, so I started thinking about removing tha backbox and routing the tailpipe to somewhere less prone to damage. However, I have some questions... 1) Will the centre box be anough to keep the noise down to a sensible level? 2) Will there be any issues with backpressure into the turbo? 3) does anyone have any pics of what they have done to thier disco??? Cheers Mark Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted November 27, 2006 Share Posted November 27, 2006 I've an idea someone on here is running a Tdi with a straight through exhaust? I seem to remember the verdict was more turbo whistle but other than that the turbo killed the exhaust beat quite effectively. I could be talking rubbish though Quote Link to comment Share on other sites More sharing options...
steve_a Posted November 27, 2006 Share Posted November 27, 2006 I ran my 200tdi defender with very little exhaust for quite a while. This led me to a number of conclusions: 1) people thouoght it sounded good 2) it actually wasn't that loud with a single small silencer 3) it does seem to let the turbo spin up a bit better now i have a standard system back on All the side exit systems run a single box so there is no reason you can't bin the rear box. all IMHO got that PITA bend in the pipe on the disco though, if you salvage that it should be a doable job to route the pipe elsewhere after the axle. EDIT: (3) I mean I think it span up quicker with little exhaust, not that the std exhaust is better. Geoff - when my exhaust cracked off just in front the gearbox on the downpipe i did run without any exhaust or even a lot of pipe. it was getting on for antisocial, more tube may have helped, it was also a requirement to drive with the window open because the fumes were entering the cab... Quote Link to comment Share on other sites More sharing options...
90hybrid Posted November 27, 2006 Share Posted November 27, 2006 I've an idea someone on here is running a Tdi with a straight through exhaust? I seem to remember the verdict was more turbo whistle but other than that the turbo killed the exhaust beat quite effectively.I could be talking rubbish though Absolutely right. To my ears at least it actually makes the exhaust note sound better....and still well silenced to boot. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 27, 2006 Share Posted November 27, 2006 I have done exactly this to my 300TDi and I can't say that the exhaust sounds any different from inside the truck. I just cut the back box off and using a piece of exhaust scrounged from local exhaust place that had a suitable bend in it made a side exit exhaust. like this:- I don't know what the scrap bit of exhaust was from but i would guess it was a Van of some kind. HTH Pete Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted November 27, 2006 Share Posted November 27, 2006 ive got a disco TDI in my 90 and the only box it has is the small (tin can) on the rear section of a 90 TD. it still sounds quiet-ish Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 27, 2006 Share Posted November 27, 2006 Gosh, thats neat. Have to admit I didn't realise my Disco's exhaust has broken in two until I noticed bits hanging down below. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 27, 2006 Share Posted November 27, 2006 Mark, the back box on the 100" fell off about 2K miles ago (on the way to Romsey and beer) and I haven't got round to fixing it. It makes no noise difference on exhaust not but has cured an annoying rattle. No real performance changes, but if I don't close the rear door properly it gets a bit smelly in the vehicle Quote Link to comment Share on other sites More sharing options...
landrover598 Posted November 27, 2006 Share Posted November 27, 2006 I removed the big middle box on my tdi a few months ago (now just the small rear box) and haven't noticed and difference in noise or performance Quote Link to comment Share on other sites More sharing options...
Andy Posted November 27, 2006 Share Posted November 27, 2006 i cut my disco's zorst above the axle & put on a straight pipe out the rear wing. i do get a bit more noise, but i like it. seems that if you put any sort of curve in the replacement pipe it sounds almost the same. i even used the original mounts & the j-bolt off a metro battery tray to secure it all. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 27, 2006 Share Posted November 27, 2006 Nice tyres Andy. All the best off roaders are using them now! Quote Link to comment Share on other sites More sharing options...
Orange Posted November 27, 2006 Share Posted November 27, 2006 i cut my disco's zorst above the axle & put on a straight pipe out the rear wing. i do get a bit more noise, but i like it. seems that if you put any sort of curve in the replacement pipe it sounds almost the same.i even used the original mounts & the j-bolt off a metro battery tray to secure it all. Did you get an MoT with that on it?? I've looked at doing it to our RRC, but am put off by the MoT guidance that says: "any missing part or a silencer in such condition, or of such a type, that the noise emitted from the vehicle is clearly unreasonably above the level expected from a similar vehicle with a silencer in average condition." as a reason to fail it!! Nice solution, though!! Might nick that idea! Quote Link to comment Share on other sites More sharing options...
Mark Posted November 27, 2006 Author Share Posted November 27, 2006 Some neat solutions there chaps. I think I will have to go raid the local exhaust place's skip to see what bits of bent pipe I can find! Cheers Mark Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 27, 2006 Share Posted November 27, 2006 Did you get an MoT with that on it?? I've looked at doing it to our RRC, but am put off by the MoT guidance that says:"any missing part or a silencer in such condition, or of such a type, that the noise emitted from the vehicle is clearly unreasonably above the level expected from a similar vehicle with a silencer in average condition." as a reason to fail it!! Nice solution, though!! Might nick that idea! your MOT man should get upset as long as it looks secure and doesn't leak thats all there really looking for mike Quote Link to comment Share on other sites More sharing options...
mwncidur Posted November 27, 2006 Share Posted November 27, 2006 I have disco 200 in my 110, there is a disco centre box (with nothing in it) and thats it, rest is just home made using 300tdi pieces of zorst. only gets slightly loud on absolute full beans! Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 28, 2006 Share Posted November 28, 2006 "any missing part or a silencer in such condition, or of such a type, that the noise emitted from the vehicle is clearly unreasonably above the level expected from a similar vehicle with a silencer in average condition." My Tdi Defender passed an MOT with no silencers in it, no problem. The regulation quoted is so open to interpretation that pretty much anything can pass. For example; what constitutes a silencer? A turbo? A bend in the pipe? I do not think that "silencer" has a definition in the MOT regs. FWIW, I have no rear silencer fitted now and the exhaust note, standing next to it, is a little "fruitier" than without but is not intrusive in any way. Without any silencer in the system it sounded fantastic at tickover and at lower revs (rather like a MUCH bigger turbo diesel - or something fitted to a cross channel ferry!) but at higher revs it started to sound distinctly chav (IMHO). Chris Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 28, 2006 Share Posted November 28, 2006 My 90 (disco 200tdi lump) has only the middle silencer and sounds exactly the same as a full system, but then it wasnt loud with no exhaust When i bought the disco donor car it had failed the MOT on the exhaust (amongst other many things) because the pipe near the back box had rotted through and the rear silencer had fallen off, it made no noticeable diffrence in any way (noise/power) on the 100mile trip home Lewis Quote Link to comment Share on other sites More sharing options...
white90 Posted November 28, 2006 Share Posted November 28, 2006 one box leaves it sounding fine even a straight through one no boxes is/was annoying and I fitted a box after 1 journey as it got on my nerves and I felt it was too obtrusive Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 28, 2006 Share Posted November 28, 2006 I realised that my original photo doesn't really show much so here is another one. I just cut the box off as far from the hanger as possible and then cut the scrap pipe to suit and welded it on the end. HTH more, Pete. Quote Link to comment Share on other sites More sharing options...
2drdan Posted November 28, 2006 Share Posted November 28, 2006 For another 2 penneth....... I have a std mid box with a short down turn after it, not MOT'd like this just how far I got to get it driving. RRC with Disco 200TDi, not noisy just noticable. 'don't know if it'll pass with out the pipe directing the exhaust away from the car tho..??? .?? B) Quote Link to comment Share on other sites More sharing options...
Mark Posted December 9, 2006 Author Share Posted December 9, 2006 Thanks for the pictures chaps, I decided I should sort this out today, so I did a tour of all the local exhaust places and some motor factors too. Strangely none of them had sections in stock, and very few had any scrap stuff. As a last resort, I went into kwik fit, and they were more than happy to let me rummage around thier scrap area. I managed to find a very nice looking system which had a really long run of straight pipe, and a couple of bends, and to cap it off, was stainless. It looked about the right size and must have come of some high power saloon car. Anyway, I hacked the backbox off one end and the flexi joint off the other, and they were more than happy for me to take it away! Result. Got home, hacked the back box of the disco, only to find that not only was my bargain bit of pipe about the right size, it was the perfect size to just slide over the existing pipe - double result! So this is what I ended up with: The hole is a little low, but thats just where it ended up! I havn't decided if I ought to do something with the edge of the hole in the panel yet? The new bit is just held on with a couple of exhaust clamps (bringing the price of this mod up to £2.96 for 2x57mm exhaust clamps from Halfords). The fit on the pipes was so good I was utterly amazed! The old hanger was used - bent a bit, and welded to the new pipe. Seems to work well. Cheers Mark Quote Link to comment Share on other sites More sharing options...
