Wytze Posted October 18, 2021 Share Posted October 18, 2021 3 hours ago, Stellaghost said: Bump stops and pan hard rod brackets, paint, build and then see about getting them under, at which point I will decide to reduce width or create some half decent wheel arch extensions regards Stephen Just make the bulkhead wider, and the rear tub. Bonnet to , offcourse😊 It's still in my head to take that route. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 18, 2021 Author Share Posted October 18, 2021 9 minutes ago, Wytze said: Just make the bulkhead wider, and the rear tub. Bonnet to , offcourse😊 It's still in my head to take that route. Hmmmm lightweight Hummer............ Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 18, 2021 Share Posted October 18, 2021 24 minutes ago, Stellaghost said: Hmmmm lightweight Hummer............ Regards Stephen Yes😁 You know it makes sence😇 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 18, 2021 Share Posted October 18, 2021 Arches ? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 18, 2021 Author Share Posted October 18, 2021 1 hour ago, Anderzander said: Arches ? Ok maybe not arches more like shelves regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 19, 2021 Share Posted October 19, 2021 This looked good on my Sankey, it's just folded aluminium at about 30° and joined in the corners. Mike Quote Link to comment Share on other sites More sharing options...
L19MUD Posted October 19, 2021 Share Posted October 19, 2021 12 hours ago, Wytze said: Just make the bulkhead wider, and the rear tub. Bonnet to , offcourse😊 It's still in my head to take that route. @steve b did exactly this to his 109 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 51 minutes ago, L19MUD said: @steve b did exactly this to his 109 Any pictures regards Stephen Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 19, 2021 Share Posted October 19, 2021 20 minutes ago, Stellaghost said: Any pictures regards Stephen what Stephen said😁 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 19, 2021 Share Posted October 19, 2021 Wasn't @Fatboy also widening a land rover? 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 19, 2021 Share Posted October 19, 2021 Like the Dunsfold one? 2 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 19, 2021 Share Posted October 19, 2021 1 minute ago, missingsid said: Like the Dunsfold one? That does look good! 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 1 hour ago, missingsid said: Like the Dunsfold one? Isn't that a Santana 1 tonne 109" with I think a 6 pot version of the 2 1/4 ? A couple of pic's These are quite old pic's , she's not so shiny now, and sadly having a rest after 120k miles of use the gearbox and transfer box and a few other bits.... need some attention . Missing having her on the road so I'm hoping I'll get time on her sooner rather than later Steve 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 That's an impressive set of wipers regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 With the extra width three won't cover the screen . A fellow sympathetic 109 resto.at the place of the blue roundabout Side view Other side and rear roll bar detail - note the seam in the tropical roof and at the front the central roof joint with the old central rib either side Steve 2 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 Sorry for the drift away from your lovely axles Stephen Steve 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 You drift away, good to see the pictures, did you widen the roof only to fit or did you widen all aspects of the landrover regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 All of it , bonnet , roof , front panel and a scratch built back door out of 40 x 20 x 3 RHS to include the rear wheel carrier into the frame . The BH and floor pan and B/C posts are built to end up with RRC seating plan and are in 50 x 50 x 3 and 5mm and 100 x 50 x 4 RHS ( lower B post ) . Windscreen and rear door glass are cut from 4mm vehicle spec laminated glass by a local car glass specialist . Extra width on the chassis is in the outriggers , new fab'd up to suit new BH , floor pan etc Steve 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 9 minutes ago, steve b said: All of it , bonnet , roof , front panel and a scratch built back door out of 40 x 20 x 3 RHS to include the rear wheel carrier into the frame . The BH and floor pan and B/C posts are built to end up with RRC seating plan and are in 50 x 50 x 3 and 5mm and 100 x 50 x 4 RHS ( lower B post ) . Windscreen and rear door glass are cut from 4mm vehicle spec laminated glass by a local car glass specialist . Extra width on the chassis is in the outriggers , new fab'd up to suit new BH , floor pan etc Steve Wow impressive, is there a build thread for this I would like very much to read it regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 No , haven't bothered but probably could get something together . I built it pre digital camera (for me ) so what few pic's I have would need scanning or photographing digitally Steve 3 Quote Link to comment Share on other sites More sharing options...
Popular Post miketomcat Posted October 19, 2021 Popular Post Share Posted October 19, 2021 45 minutes ago, steve b said: All of it , bonnet , roof , front panel and a scratch built back door out of 40 x 20 x 3 RHS to include the rear wheel carrier into the frame . The BH and floor pan and B/C posts are built to end up with RRC seating plan and are in 50 x 50 x 3 and 5mm and 100 x 50 x 4 RHS ( lower B post ) . Windscreen and rear door glass are cut from 4mm vehicle spec laminated glass by a local car glass specialist . Extra width on the chassis is in the outriggers , new fab'd up to suit new BH , floor pan etc Steve I think there is a que of people that would love to read about your build @steve b. Mike 7 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 38 minutes ago, steve b said: No , haven't bothered but probably could get something together . I built it pre digital camera (for me ) so what few pic's I have would need scanning or photographing digitally Steve Out of curiosity, why did you widen it regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 Thanks all for the kind words , I'll try and find the pic's and do some copying . If there is enough to help tell the story then I'll start something . Steve 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 19, 2021 Author Share Posted October 19, 2021 Just now, steve b said: Thanks all for the kind words , I'll try and find the pic's and do some copying . If there is enough to help tell the story then I'll start something . Steve Brilliant thank you regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted October 19, 2021 Share Posted October 19, 2021 Stephen , I posted at the same time . Ergonomics , pure and simple also combining what I feel are the best bits of LR . The very first time I sat in a RRC the ergonomics of the Series and then ( worse ) the 90/110 really bugged me . It took a lot of years to get to the right time with the right plan to do it Steve Quote Link to comment Share on other sites More sharing options...
