Bowie69 Posted January 13, 2022 Share Posted January 13, 2022 Sheesh, you don't hang about! Glad it looks like it will work out 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 13, 2022 Author Share Posted January 13, 2022 (edited) 11 minutes ago, cackshifter said: I do think you might need more than that to secure the cylinder. On the bench fine, but under battle conditions it might get tossed around a bit, the dogs might put some force on it etc. Absolutely, on a prior post I mentioned making a crush tube that will be held in position by the hub pressing onto it and therefore putting pressure onto cylinder to hold it firm regards Stephen Edited January 13, 2022 by Stellaghost Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 13, 2022 Author Share Posted January 13, 2022 6 minutes ago, Bowie69 said: Sheesh, you don't hang about! You know what they say " no time like the present " thank you again regards Stephen Quote Link to comment Share on other sites More sharing options...
muddy Posted January 15, 2022 Share Posted January 15, 2022 Nice work! could you tack a piece of sacrificial flat bar with a 1/4 hole in the centre across the bulb to centre the holesaw? might be more work depending how long the plasma clean up operation took. Might be worth seeing what the minimum pressure required is to try and keep reliability, nothing worse than blowing your ring out! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2022 Author Share Posted January 15, 2022 7 hours ago, muddy said: Nice work! could you tack a piece of sacrificial flat bar with a 1/4 hole in the centre across the bulb to centre the holesaw? might be more work depending how long the plasma clean up operation took. Might be worth seeing what the minimum pressure required is to try and keep reliability, nothing worse than blowing your ring out! Thank you Even with the holesaw there is still more material to move and clean up, still a good idea to be stored away. Seals will hopefully be OK, rings are 3mm diameter and there is 0.5 mm gap for them to force out, couldn't go any less as difficult to get thing together, also been using my garage compressor which delivers a lot more air and they have been fine, its a bit suck it and see, I'm quite sure there will be some fine tuning for the whole of the build once used in anger, it all looks fine and dandy on the bench but we all know used in anger can be a totally different story regards Stephen Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 18, 2022 Author Popular Post Share Posted January 18, 2022 That's one axle done with regards to getting air to the pneumatic cylinder pin made in lathe drilled out Tapped to 1/8 bsp flange welded on flange shaped, drilled along with axle casing and axle casing tapped to m6 Air pin fitted regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 18, 2022 Share Posted January 18, 2022 I guess another hidden advantage of the cylinder being inside the axle is the axle breather should be kept clear Quote Link to comment Share on other sites More sharing options...
steve b Posted January 18, 2022 Share Posted January 18, 2022 The bigger Ag mog's have positive air pressure feeds to axles and gearboxes , 0.5bar iirc. Nice engineering as always Stephen . Steve 1 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 18, 2022 Share Posted January 18, 2022 Damb you quite good at this really. Mike 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 18, 2022 Author Share Posted January 18, 2022 4 minutes ago, miketomcat said: Damb you quite good at this really. Mike Thank you, improving day by day lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 18, 2022 Share Posted January 18, 2022 Wow - on each piece of scope creep I’ve ended up thinking ‘there’s months of work there’ ….. then about 5 posts later you’ve done it. Astonishing. 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 18, 2022 Author Share Posted January 18, 2022 2 minutes ago, Anderzander said: ‘there’s months of work there’ I hope to have this finished in months, my target is to be complete by the end of summer, including fitting new seats etc regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 18, 2022 Share Posted January 18, 2022 Yep, when you think this build thread couldn't get any better, it does!! Steve 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 18, 2022 Share Posted January 18, 2022 Presume there's a gasket or goo in there? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 18, 2022 Author Share Posted January 18, 2022 3 minutes ago, Bowie69 said: Presume there's a gasket or good in there? Be a bloody bad job if there isn't lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 18, 2022 Share Posted January 18, 2022 2 hours ago, Stellaghost said: I hope to have this finished in months So we should stop giving you silly ideas? 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 18, 2022 Author Share Posted January 18, 2022 15 minutes ago, elbekko said: So we should stop giving you silly ideas? Eh........ no....... silly ideas can bear fruit, just have to convert silly into a workable........... On the other hand it you don't want this thread to end......................lol Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 19, 2022 Share Posted January 19, 2022 10 hours ago, Stellaghost said: On the other hand it you don't want this thread to end......................lol We do and we don't! It is great seeing all the engineering ideas but equally I am sure a lot of us are looking forward to seeing these under the Landy 🙂 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 19, 2022 Author Share Posted January 19, 2022 17 minutes ago, L19MUD said: We do and we don't! It is great seeing all the engineering ideas but equally I am sure a lot of us are looking forward to seeing these under the Landy 🙂 Must admit I'm very keen to get them under the lightweight regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 19, 2022 Author Share Posted January 19, 2022 On 1/18/2022 at 2:16 PM, CwazyWabbit said: I guess another hidden advantage of the cylinder being inside the axle is the axle breather should be kept clear Came back to this, air from pneumatic cylinder is exhausted back at the ARB compressor and not into the axle case so will not keep axle breather clear unfortunately, I'm also pretty sure some of the unimog variants run air braking systems so plenty of available air to use on pressuring up axle cases and gearboxes regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 20, 2022 Author Popular Post Share Posted January 20, 2022 Well that's the other pneumatic cylinder components made this afternoon on the lathe, just to weld together and drill once I've got rear axle unbuilt again, the joys regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2022 Author Share Posted January 21, 2022 Small job today too much other work on Rolled a piece of aluminium for my crush tube to keep pneumatic cylinder in place Steady away reducing diameter bit by bit Jubilee clip holding seams together, nice neat fit into axle tube and its also light lol, just needs tigging and cutting to finished length regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 21, 2022 Share Posted January 21, 2022 Good to see you're saving weight Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2022 Author Share Posted January 21, 2022 24 minutes ago, FridgeFreezer said: Good to see you're saving weight Like I've said before, every forum has a comedian lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted January 22, 2022 Share Posted January 22, 2022 Staggering engineering and ingenuity Stephen. 44 pages took some catching up on! I don't know if your research has turned this up but there are 2 different styles of ring and opinions used in 404's one style has a very odd ring gear design that breaks quite easily. I can't tell from the pics which style yours is. Earlier in the thread (page19) you asked if anyone had lightened or broken an axle case. I've never lightened one but I have broken 1. And repaired anothe that tibus offroad built, theres snapped in the middle where they'd done a shoddy job of joining the case. Mine cracked the outer under a suspension bracket then broke the inner tube off at the end where I'd welded it. The roller bearing you lost (and found) can be bought by the hundred from any bearing supplier. All the seals and bearings are pretty standard and easily available. I think the exception is the little rubber top hats that link the grease paths in the cv joints. I really like your diff lock setup, very clever and not too dissimilar to the sliding setup in a g wagon axle, although the cylinder is on the outside on those. One problem I've come across myself and with others when air actuating the diff lock, the dogs can sit on top of each other with the force of the cylinder holding them there until it slips in when a wheel breaks free. This then smashes the dog to pieces. A friend of mine converted his to cable with a spring setup like standard. As he claims to be able the "feel" them in. And hasn't broken the diff lock since. I'd be interested to see how your front 1 link looks complete. But from your description I think your overthinking the bushing needed, I've ran them directly welded to the axle cases for years with a ballistic joint at the chassis end https://www.ballisticfabrication.com/products/3-0-ultra-duty-ballistic-joint On my patrol, I run a ballistic joint at the chassis, and I've bolted the 1 link onto the radius arm brackets without any brushing, I've done about 40k road miles in it over 7 years and as regards NVH I can't tell the difference, there is no harshness at all. the loss of roll resistance in the suspension takes a lot of adjusting to though. 1 Quote Link to comment Share on other sites More sharing options...
