roamingyak
Replacement for a NATO hitch on a Defender
Any suggestions for something lighter/smaller than a NATO hitch when you just want to recover/pull things rather than tow a trailer from the back of a Defender please?
I'm replacing the rear chassis cross member so seems a good idea to save some weight and hopefully knock myself in the groin less with its replacement!
Share this post
Link to post
I love the Southdown tank guard as it give good protection and a very sturdy recovery point
Share this post
Link to post
Thanks Martin (Motorhead!), looks ok, but 4 bolts would be better than two.
Western, definitely not with the groin whacking ball in such a protruding position (and I don't have any use for the ball...)
Thanks!
Share this post
Link to post
I looked at the welding on that I concluded there's no hope I would ever trust it in a deep bogged, or any other recovery situation.
Share this post
Link to post
A pair of jate rings works well.
For general dragging you can just loop a strap through one, or use both for heavier recovery.  Weight almost nothing and well out of the way.
I've got a few spare I can post out for cheap.
Share this post
Link to post
Why? If it's suitably rated it will be fine. Many 2 bolt jaws use bigger bolts than the 4 used on other ones.
Share this post
Link to post
Jate rings are ok, but do require you to crawl under a bit to attach to them. Which off road may be an issue if they are buried in the ground or under water. You also need to have some way of attaching to them, meaning you need to carry shackles about with you. And you really should use them with either a bridle or long enough rope to attach to both sides of the vehicle.
Share this post
Link to post
I don't think he wants it for pay & play days in a quarry though, and a shackle isn't really a problem to carry, I just leave one on the jate ring.
I'd rather risk getting dirty knees strapping up a pair of jate rings than trusting one of those welded U bolt attachments anyways...
Share this post
Link to post
Thanks!
You could find a 2nd hand item and chop the ball off
Share this post
Link to post
Thanks!
Or just turn it upside down so the ball is on the bottom?
Share this post
Link to post
Thanks for the suggestion, but I have a (Aluminium) Safety Devices fuel tank guard, and suspect it would get in the way, or at least the edges of it would chaff if pulling on an angle...?
Share this post
Link to post
I have the type that Zardos suggested above with the hoop. I can't remember what brand it is but the welding is good and it has served me well for tow recovery and acting as an anchor for winching and snatch blocks. Simple and effective, it's what I recommend.
KISS is a good ethos to follow.
Mo
Share this post
Link to post
I bought a galvanised version rather than zinc and passivated, so it looks like this after 8 salty winters 😊
Mo
  • Like 1
Share this post
Link to post
Equipe used to make one like that.
Share this post
Link to post
There is a version of the Bradley jaw-and-pin hitch where the top of the pin is a standard towball. Very convenient !
Rated to 5000Kg - should be strong enough! https://multec.co.uk/shop/tractor-hitch-lifting-attachments/bradley-ball-pin-tow-hitch-eu-approved-5000kg-swl/
Share this post
Link to post
I have this on my D2, but I would never use it for a recovery point.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
