New to me toys
If you want the drills sharpened let me know, I have recently acquired this, its and Archdale drill sharpener, old and very very heavy. Just got it working with a new motor, the old one probable works but was 3 phase and 550v which is what the transformer was for (any one want a 3 phase 400 to 550v transformer and motor?).
It does up to 3" diameter drills, so far I have tried it successfully up to 1 3/4", does a nice job, very strange action, the bit rotates and the grinding wheel spins and moves side to side and in and out. It doesn't do a split point on web thinning, but with a drill that size you are normally going to have drilled a pilot hole any way. Just need to get a coolant feed set up for it.
It even came with a free extra, I think it had been there for a while!
  • Like 2
  • Thanks 1
Thanks for the offer however I can sharpen them at work regards Stephen
You think you've got problems :ph34r:
Couldn't really turn this down for £100 - fully functioning and single phase to boot, most people use mugs for scale - since this is a Land Rover forum note the door for scale :hysterical:. Stamped "Made in West Germany" so that dates it reasonably well...
Acquired a few years before but my wee hydraulic press on the right and a table with 3 (there's another one on the floor) Elliott Progress drills. This was in my old place and I couldn't lift the largest of the three drills onto the table. Came across a manual and realised why - the 2G (G stands for gearbox to drop it to ~40rpm) bench mount version comes in at 180kg... And the table has three drills of similar size on it.
Nice solid table though.
That is until I bought this little one for a general purpose work bench :SVAgoaway:
Now I just need the building work downstairs in the workshop to actually finish - but the roller door went on yesterday :D
  • Like 3
On 10/15/2019 at 3:39 PM, Bowie69 said:
OK that's it, I am officially labeling you as a 'git' ;)
On 2/23/2021 at 5:40 PM, Bowie69 said:
Oh you poor thing, how will you ever cope.
Thanks Bowie I'm taking that as a promotion, poor thing is way better than Git lol regards Stephen
I went back, have bought something else but I will post up when I get it home, however I did get some free stuff given
Some old lathe tools
A lathe 4 jaw chuck off god knows what along with about 10' of 4" round bar cut in half so I can man handle it 20210302_131136.thumb.jpg.200e4e8cb8a45b02129d4b593954faf9.jpg
A couple of micrometers
And this
Quiz time, what is it, I know what it is, dont know what I'll use it for but free is free. It's a bit of a beast
Regards Stephen
7 minutes ago, FridgeFreezer said:
Jeebus I don't know where you do your shopping but it looks very dangerous :ph34r:
It could be might be why it was free
6 minutes ago, Bowie69 said:
Truck 1" impact?
No where near
3 minutes ago, Bowie69 said:
Hang on, hot riveter?
No your losing your touch regards Stephen
6 minutes ago, sean f said:
Is it a heavy duty nibbler?.
It most certainly is, dont know what I'll use it for but the motor is powerful and could be adapted for something else who knows ?
Had a little play with it on some 5mm flat bar and some 3mm plate
It chews through pretty easily regards Stephen
  • Like 4
Sacrilege!
Use it for what it was intended for or pass it onto someone who might ;)
1 hour ago, landroversforever said:
Nice bit of kit! Does it still cut cleanly on thinner stuff?
Your wish is my command ( but only to a point )
2mm aluminium
2mm stainless
1mm mild steel, it struggled more with this and I think it's too aggressive for thinner material but having said that the cutting edges may need sharpening/ setting up regards Stephen
  • Like 2
