ianmayco68 Posted July 12, 2020 Share Posted July 12, 2020 Hi all , I’ve just fitted some new springs and some Koni heavy track raid to the front of the 110 , got same on the rear and I’ve got a problem, the shocks are hitting the turrets which are the tubular ones from paddocks and going down the road it’s bouncing around like a kangaroo 🦘. So obviously I need new turrets but has anyone come across a similar problem with there set up and which turrets did you fit ? Before I spend my hard earned on them , been looking at the adrenaline 4x4 ones https://www.ebay.co.uk/itm/182475371495 any help much appreciated as always . Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 12, 2020 Share Posted July 12, 2020 I had Gwyn Lewis shock turrets - and I really liked them, loads of space, galvanised, and a nice simple design to keep clean. He did them in. Std height and +2, which requires the turret covers cutting or removing. Where are they catching? Are your new shocks a wider body? I can’t remember what the fronts are .... but if they are pin to pin, could you turn them upside down ? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 Yes the body’s wider , can’t turn them upside down as it says to fit them they way I have them . The body of the shock is hitting the base of the turret as they encroach on the opening in the spring mount if the internal diameter of the turret was bigger it wouldn’t be a problem, I’ll see if I can get a pic . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 Got some pics mite only just catching the corner do you think I’d be okay sanding the inside down ? Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2020 Share Posted July 12, 2020 Wonder if the upper end needs to be shifted over a bit, looks like its not centered in the top mounting. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 12, 2020 Share Posted July 12, 2020 Yes that doesn’t look centred does it .... Are the turrets ‘sided’ ? (gwyn’s are) Or would they flip 180° round to put the shock more in the centre ? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 No they aren’t sided not that I no too did look when I brought them ages ago , I’ll have a look at that tomorrow night Ralph but the lip on the rubber washers is in the hole and both sides are the same , the terrafirma ones I took off sat forward slightly. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 12, 2020 Share Posted July 12, 2020 +2 for Gwyn lewis turrets. 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 These ate the ones I’ve got fitted https://www.ebay.co.uk/itm/163143042072 but from paddocks just looked on there web site and doesn’t say there handed , I think I’m going to take the off and sand down the inside won’t need a lot taking off and shouldn’t weaken them , need to get them sorted as I’ve got to borrow the wife’s disco sport tomorrow and she’s not happy about me using it for work😁 . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 What shocks have you got fitted @Daan ? Any clearance issues ? Quote Link to comment Share on other sites More sharing options...
Daan Posted July 12, 2020 Share Posted July 12, 2020 Old man emu and fox. If it is that tight, you need these without relocators: https://gwynlewis4x4.co.uk/product/front-challenge-turrets2-without-re-locators-gl1051/ They don't reduce the ID of the turret, like yours does. Daan Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 12, 2020 Share Posted July 12, 2020 The shocks look very off centre - is the mount hole on the turret offset? What happens if you rotate it 180 degrees? Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2020 Share Posted July 12, 2020 My tubular towers look the same as the ebay link above, I bought them galvanised from a guy in one of the Land Rover groups on Facebook, pretty sure they are not handed, mine definitly aren't. they do have the 'blip' on the inside, I'll sort a photo when home from work tomorrow. I run OME dampers as well. N44 on the front IIRC. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 It stays the same I think , they look identical from memory because when I first brought them I thought they’d be handed but I tried always and I couldn’t get them to mirror, if you know what I mean . One sits with the opening slanted to the rear and the other side slants to the front , I’ll have a play when I get home from work tomorrow . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 12, 2020 Author Share Posted July 12, 2020 Yes it’s the blip on the inside that’s catching on the shock Ralph if the ring had a bigger inner diameter there wouldn’t be a problem, I might take them off and sand the blip off . Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 13, 2020 Share Posted July 13, 2020 Something is not right there, surely the shock should come through the centre of the hole. I would be investigating why this is so rather than sanding bits. Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 13, 2020 Share Posted July 13, 2020 Another vote for Gwyn's ones. and they definitely are handed. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 13, 2020 Share Posted July 13, 2020 17 hours ago, ianmayco68 said: It stays the same I think , they look identical from memory because when I first brought them I thought they’d be handed but I tried always and I couldn’t get them to mirror, if you know what I mean . One sits with the opening slanted to the rear and the other side slants to the front , I’ll have a play when I get home from work tomorrow . Did someone sell you two identical ones instead of a LH and RH one maybe? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 13, 2020 Share Posted July 13, 2020 I wondered that ! In fact - is it off centre on both sides or just one? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 13, 2020 Author Share Posted July 13, 2020 Rite update I’ve done a bit of measuring, a standard turret is roughly 100/110mm internal diameter,a standard shock is 50/60mm measured these off old parts lying around . The Koni shock is 70mm diameter and the gap on the turret I’ve got fitted between the bits that stick over the spring housing is 80mm , the turret overhangs the inside by 10/15mm , so there’s not enough wiggle room for the shocks just 5mm each side . Quote Link to comment Share on other sites More sharing options...
pat_pending Posted July 13, 2020 Share Posted July 13, 2020 Mine were similar to those, the id of the ring is too small. They came second hand but unused from ebay so I took a grinder to them, still plenty of metal left in them. I also seem to recall re drilling the holes. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 13, 2020 Author Share Posted July 13, 2020 Yippee cheers @pat_pending now I know I’m not going mad 👍.Does any of the kind gentleman that have gwyn Lewis shock turrets have any to hand so they could measure the inside clearance for me please ? So think I’ve found the reason for the shocks sitting forward, as they wider , the bolt that holds the spring plate & retaining plate down was too high , I’d put a washer and spring washer on and the shock wouldn’t swivel back. So here’s a pic of the turret so do I do as pat has done and sand the nibs off that would give me 100mm clearance or buy some new turrets , options please ? Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 13, 2020 Share Posted July 13, 2020 I wouldnt grind/sand them off. Looking at the underside pictures you will remove/weaken half of the attachment points? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 13, 2020 Author Share Posted July 13, 2020 I’d only sand the nibs back to make the circumference of the inner circle even , then tap the tubes in if needed then reweld and weld the inner part of the tube, can’t see it weakening it that much . Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 13, 2020 Share Posted July 13, 2020 I can measure the Gwynn Lewis ones tomorrow morning for you. What height suspension are you running as this will cant the diff over and make the shock off centre? Quote Link to comment Share on other sites More sharing options...
