200tdi not well
miketomcat
Sorry if I'm teaching you to suck eggs, I don't know if you have a pressure guage or are relying on a blinking oil pressure warning lamp?
My old safari truck in africa started flashing the oil pressure warning lamp very convincingly for a while which had me thinking the worst - turned out to be a bad sender thankfully - always nice when its the cheap fix 🙂
Also had this with a partially blocked oil filter. Changed oil and filter and it went away
I've got a set of 200tdi cam bearings here.
The great land rover curu, Pete Broom advised me that it is possible, in many cases, to simply reafix either the origionals, if not too mullered. or replacements, without resorting to the utter pita that line boring is
Mike, I would offer you a spare engine, but it has the same problem
3 hours ago, cackshifter said:
So going for expediency, if the cam bearing has moved, is it possible to just put it back loctited, IE no need for new bearings and reaming. Yes I know it would be a dirty fix, but if the rest is ok then that gives a good engine.
Exactly what I was thinking. If it has just moved, and you caught the problem in time, knock it out, put some bearing retaining (green) loctite on there, pop it back in and run it. Costs you a set of gaskets and some Loctite you can probably pinch from work :ph34r:
I mean, it's already broken, you're not going to make it worse.
  • Like 1
Changing the oil/filter made no difference hence I pulled the engine out.
Whilst I love your optimism I'm really not that lucky. I didn't check it with a guage but I'm fairly confident in the diagnosis as the exact same symptoms happened with our 110 shortly after the cam snapped.
Mike
  • Like 1
I echo the view of stripping the engine you took out to find the cause of the low oil pressure. It will cost you nothing to strip it down and then you will know what you are dealing with. It will either be financially none viable for you at the moment to repair or you might be pleasantly surprised. You won't know for sure until you have investigated. I have a box full of 200Tdi stuff in my garage, if I have anything you need, I'll gladly send it to you.
The problem with line boring isn't the cost, it's the need for a bare block. Fine if you have all the time in the world to strip the lump, and the parts you will need - for example all the shells (becuase why would you strip it and not replace?), then even more time to re-build it.
If Mike gets his spare lump up on the bench he does (technically) have the time to do it, as long as the sickly engine in his daily soldiers on for a while longer.
Also, Banda have done machining for me before with a non-stripped block, so it may also be possible to get it done without the full stripdown.
Turner Engineering sell a later type of cam brushes that have smaller oil holes to give correct lubrication without losing so much pressure.  They say that there is no need for reaming or line boring.  I can’t remember their price, but it was less than a couple of rounds down the pub…
  • Like 1
Those are the ones I have - yet to fit, on my spare engine, due to lack of time
  • Like 1
I intend some for mine, if I don’t just get a short engine from them when I pull the pistons and try to find a cause for the  persistent oil burning.  First thing will be the turbo oil drain hose, though - the head has been rebuilt twice, the turbo rebuilt and then replaced, and the block rebored with +20 pistons, which were then removed at about 10k and re-ringed, all to absolutely no effect. 🤬. The only job which was ignored when I rebuilt that engine from scratch was the cam bushes, because the machinists said they were good.  Now I wish I had done them as the oil pressure is a tad low on warm idle (15psi instead of 25, which seems typical of a Tdi but Ralph got the bookfigures).
  • Like 1
I wouldn't worry about 15psi. Oil tyope and manufacturer, gauge reading and oil condition all make the figure vary
A knowledgeable engine chap once told me that if you allow 10psi per 1k RPM, that will do nicely. More is just a bonus.
I can lower my oil PSI by simply running Smith and Allen semi synth 10w40, rather than Shell Rimula 15W40
  • Like 1
Ok so I've established I'm stripping the other engine as soon as I can.
However I need to prolong the one in there for now. Prior to the head gasket going it ran fine but smoked a little. Since replacing it I came back from Scotland fine, but it's now getting a bit warm at random occasion. It seems to take a long time to warm up but once it does it settles just above half way (it was just below half way before). However it seems to increase when in traffic or under load but once moving again it comes down a bit. It does use a bit of water but I'm not sure if this is being blown out or going into the bores again. The cooling system doesn't seem to have excessive pressure but is elivated due to running hot. I've replaced the thermostat.
It almost feels like the impeller has come off the water pump, but that was new when we fitted this engine.
Mike
I replaced the thermostat in an effort to reduce the running temp, but it's made no difference. I know the guage is fairly accurate as the electric fan keeps coming on which it didn't before so it's definitely running warmer. It is possible the thermostat housing is leaking as the new gasket didn't seal. I ended up reusing the original gasket however I'm fairly sure it's good.
Mike
  • Like 1
Mike
I have a new 200tdi waterpump in my box of bits I'd you want it to try swapping it over to see if that helps you?
I fitted a new Ali radiator at the same time as this engine. Thanks @monkie I should have a water pump here, failing that I can rob the one off the other engine.
It's typical I won't risk using the ibex for towing at the moment so I've got a fair bit to do, looks like the 110's getting a work out. :D
Mike
Thermostats along with many other parts are rubbish these days  - I no longer use anything but waxstat in the workshop and even then they can be faulty out of the box. Think I went through four new stats before getting a good one in my own 200tdi.
  • Like 1
