MogLite Posted August 30, 2005 Share Posted August 30, 2005 The Optima yellow top I had for MogLite is dead, has been on charge with Fridge's Optimate charger for over a week, and it won't go over 10.9Volts So it looks like I've got to get a new battery. If I'm going to do it, I'm going to fit twin batteries, one for the rear winch and other accessories, and the other for starting. I'm going to run some kind of split charge, as covered in other threads as MogLite will be a V8 - it will need lots of starting if it gets wet. A red/yellow Optima combination is tried and trusted. But ISTR Exide Maxima DC900's out perform them, and are a bit cheaper, and have three connections per battery, which will be handy. LR90 - I know you run Exide's - anyone else ? Trev why did you go for Exides ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 30, 2005 Share Posted August 30, 2005 I run twin optimas...had one for 5 years and one for 7 years, so they are doing ok ! Use the Optimate on them regularly, Bought them as there was little competition about for them at that time, Exides I think may be as good / better, have a couple of mates who have them and no probs. There heavy, just like Optimas, but cheaper.... If I was to replace I would prob go Exides now, as I have heard Optimatas quality control is not as good as it was ? Nige Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 30, 2005 Share Posted August 30, 2005 I run two in the 24v set up thatJon put on the hybrid for the winches. Never had a problem with them, and when I first got the hybrid they went through long spells without use. Cheers Steve Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 30, 2005 Share Posted August 30, 2005 I'm going to run some kind of split charge, as covered in other threads as MogLite will be a V8 - it will need lots of starting if it gets wet. You're surely not going to all the trouble of building MogLite and still using a dizzy?!! Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 31, 2005 Share Posted August 31, 2005 I bought Exides cos I could get them local (Furnaux Riddel?), cheaper than Optimas and bit different. The extra lugs are usefull Also the more I looked into it there where many different models of optima 'yellow' top so it wasn't clear quite what I was going to be getting for my money. Not sure at the end of the day whether there will be much in it. Optimas have been kown to give up. So far mine are fine and I did burn out the isolator at Slindon so they must be delivering the amps Happy with my choice FWIW. Quote Link to comment Share on other sites More sharing options...
jules Posted August 31, 2005 Share Posted August 31, 2005 Try these guys there in Romsey www.dmstech.co.uk That way if it gives out like the optimas seem the have a habbit of you can throw it through there front window instead of shipping it across the globe to be told its fine Jules Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 31, 2005 Share Posted August 31, 2005 I've used Optimas in my truck. Over 4 years I've had one die (the starter red top). The yellow I use for the winch has performed faultlessly so far. Quote Link to comment Share on other sites More sharing options...
jules Posted August 31, 2005 Share Posted August 31, 2005 Andy has one that's died Ali has one thats died I'm not conviced mine is right (all it has to do is start a td4 freelander and it can't always manage that) The old 90 has a 5yr old truck battry in it and it's been run flat loads of times on sat I was cutting the lawn and had to move the 90 so I dug out the keys and it started not bad for leaving it for two months and forgetting to disconect the battry. It was furing up at its last Mot that was feb 04 so its not doing too bad but I have been looking at the dms red tops as they will make whet ever you want. Quote Link to comment Share on other sites More sharing options...
Neil Marshall Posted August 31, 2005 Share Posted August 31, 2005 If the Optimate won't revive it then nothing will....I have a red top which used to run flat when I left the truck standing for a few weeks [bloody Immobiliser spider problem] and a standard charger could never revive it. The Optimate would bring it back to full charge after 24 hours. I love them, but they are very expensive, and there are alternatives which are good enough for most uses. Throw it away and find a cheap source for a Maxima. Neil PS Trev - where is Furnaux Riddel and how much? Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 31, 2005 Share Posted August 31, 2005 PS Trev - where is Furnaux Riddel and how much? Pompey, so like Jules says if it don't work its easy to return Think I paid £130 ish but it was a while ago now. Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 31, 2005 Share Posted August 31, 2005 they are still 130 from riddalls Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 31, 2005 Share Posted August 31, 2005 in packs of four? Quote Link to comment Share on other sites More sharing options...
gelf Posted August 31, 2005 Share Posted August 31, 2005 i use an optima blue top.... extra trerminals for the winches and ive never had a problem. and cheap...... the company i work for owns optima Quote Link to comment Share on other sites More sharing options...
Divster Posted August 31, 2005 Share Posted August 31, 2005 Been running twin maxximas for about a year now with no probs. (Touch wood) Dave Quote Link to comment Share on other sites More sharing options...
MogLite Posted August 31, 2005 Author Share Posted August 31, 2005 they are still 130 from riddalls They are £147 + VAT according to their Website Quote Link to comment Share on other sites More sharing options...
ibexman Posted August 31, 2005 Share Posted August 31, 2005 HI Andy ive had twin maximas in jaffabex since she was built used them upside down numerous times to start dead engines cant fault them cheers chris Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted August 31, 2005 Share Posted August 31, 2005 For the record I use Exide Maxxima's, 3 of them, one for the vehicle and two for the 24 volt winches. No problems. Quote Link to comment Share on other sites More sharing options...
Paul Posted August 31, 2005 Share Posted August 31, 2005 I have 2 Exide Maxximas, although they're called Orbitals over here. The main reason I got the exides instead of Optima Yellow Tops was that they have almost identical specs., but the Optimas were $400 each and the Exides were $225 each. Being the Accountant type and having fresh batteries in my calculator, well...you know... Quote Link to comment Share on other sites More sharing options...
JST Posted September 1, 2005 Share Posted September 1, 2005 i am just running two Fann tractor batteries, both are about 30-40% bigger than (more amp hr) than the std LR one and they are only £40 each. but have only been in there a year! i can get the details of them if needed. its always worth trying your local agricultural merchant etc. Quote Link to comment Share on other sites More sharing options...
cols110 Posted September 1, 2005 Share Posted September 1, 2005 Had 1 maxxima for over 4 years now and still running sweet, my 2nd a 900dc has had quite a few full discharge cycles with my fridge and has perfomed perfectly. Scrap iron do the 900dc`s for about 130squid + the dreaded. Quote Link to comment Share on other sites More sharing options...
Bos Posted September 1, 2005 Share Posted September 1, 2005 I've got a pair of Maxxima's although they haven't been on long enough yet to form an opinion - they work though B) . I decided to go for them as i thought it may be better to have two batteries the same, which could be swapped around easily if needed, plus they were cheaper than optimas. Quote Link to comment Share on other sites More sharing options...
