GBMUD Posted February 1, 2012 Share Posted February 1, 2012 My 90 has a heated windscreen fitted which I have not needed to test since I have owned the car. Yesterday I had to use the car early and there was still a good covering of frost on the screen so once the engine was running I turned on the screen - it is fed through a timer relay. I was not expecting an instant result but the screen seemed to take a long time to melt the covering if ice - I would estimate two minutes before the wiper were able towrope the screen clear. Does this sound too long? I guess I was rather expecting 30 seconds... Cheers Chris Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 1, 2012 Share Posted February 1, 2012 My Puma heated screen takes a minute or two, perhaps a bit longer to clear if there's a heavy frost. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 1, 2012 Share Posted February 1, 2012 I generally spray my 'screen to shift the hard frost. Mine's on two timer relays. On a damp morning whe the inside has a slight coating of mist/ condensation the 'screen generally clears in seconds on the inside. I can't remember about the outside but as I say I try to help the clearence. You, well I have to, clean the side windows so I spray the screen at the same time. Now where can I get heated side windows ? LOL Quote Link to comment Share on other sites More sharing options...
tuko Posted February 1, 2012 Share Posted February 1, 2012 I don't think from my experience with our Disco that 2 minutes is too long. I to was expecting it to work much faster but reality over rules expectations. Todd. Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted February 1, 2012 Share Posted February 1, 2012 <p style="margin-left: 40px">Our disco 2 doesnt have it - But my Puma clears in about 2 minutes that and the heated seats have turned me into a right softy, the S1, SII, and the 110 V8 Dont get used winter mornings,once youve tried heated seats & heated screen, its hard to go back!</p> <p style="margin-left: 40px"> </p> <p style="margin-left: 40px">Does anyone have any experience of, or has anyone fitted engine pre-heaters to a puma defender? </p> Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 1, 2012 Share Posted February 1, 2012 Just as a question about heated screens.... are the fine wire elements nearer to one surface than the other? My guess is they would be nearer the inside surface to demist the screen quickly which is the more likely need in this country. So when it comes to melting the ice it will take longer as it has to heat a thicker layer of glass.... does that make sense? or am I totally wrong? Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 1, 2012 Share Posted February 1, 2012 "Now where can I get heated side windows ? LOL ", you laugh, but a few years ago I approached Pilkington on just such a subject! Evidently it wouldn't be too difficult to do as the windows are just flat glass, the problem would be in the wiring, I thought about using "telephone" style telescopic stuff, but couldn't find any of a sutable rating. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 1, 2012 Author Share Posted February 1, 2012 Not as impressive as I had hoped, but I guess at least it means that is one thing that does not need fixing! Chris Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 1, 2012 Share Posted February 1, 2012 "Now where can I get heated side windows ? LOL ", you laugh, but a few years ago I approached Pilkington on just such a subject! Evidently it wouldn't be too difficult to do as the windows are just flat glass, the problem would be in the wiring, I thought about using "telephone" style telescopic stuff, but couldn't find any of a sutable rating. If they can heat the rear side windows why not the important ones at the front. I don't think curly wiring would really be a problem... Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 1, 2012 Share Posted February 1, 2012 If they can heat the rear side windows why not the important ones at the front. I don't think curly wiring would really be a problem... Perhaps you could have a set of contacts on a vertical pole that the window runner sits between and picks up current at any height? Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2012 Share Posted February 1, 2012 My heated screen doesn't work either only because it's not wired up Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 1, 2012 Share Posted February 1, 2012 I like the idea of heated side screens too...one to look into I think! I'm sure with some decent flexible cable and a bit of thought as to the routing it would be possible. Wouldn't like to imagine the current draw on a 110 SW with heated glass all-round though A few minutes sounds right to me, my Focus used to take about that long to defrost an iced up windscreen. About as long as it took me to scrape the door windows. When it was just misted up on the inside it cleared pretty much instantaneously. Quote Link to comment Share on other sites More sharing options...
Steve King Posted February 1, 2012 Share Posted February 1, 2012 My 2002 TD5 Defender has a heated front screen. To be honest it is not brilliant at clearing the screen when it is really frosted up, but once you have scraped the ice from the screen it keeps the frost off until the heater (eventually) kicks in! Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 2, 2012 Share Posted February 2, 2012 Mine takes several minutes as well Chris.... Much better to sit and organise ready for the journey than be outside scraping and getting cold ! Neil (Ralph.. That screen will be worn out before you wire it in....) Quote Link to comment Share on other sites More sharing options...
shotrock Posted February 2, 2012 Share Posted February 2, 2012 A coupe of minutes seems about right to me. I have had a couple of cars with heated screens and they are not instant, so no need to worry. SHOTROCK Quote Link to comment Share on other sites More sharing options...
Richy B Posted February 2, 2012 Share Posted February 2, 2012 I would agree with 2-3 mins on my defender, I also fitted the mud stuff side de mister vent kits, works real well especially with damp., can't feel an amazing amount of air rushing out but defo better than STD/none Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 2, 2012 Share Posted February 2, 2012 Abou 45 secs to a minute to get to the oint where the wipers clear - that's a single feed 30amp draw, through a 40amp relay and switch off a 1000CCA reserve battery. Mirrors are about 30 seconds. Rear window doesn't bloody work! Quote Link to comment Share on other sites More sharing options...
