MECCANO Posted May 7, 2021 Share Posted May 7, 2021 ๐๐ looking good! Quote Link to comment Share on other sites More sharing options...
Daan Posted May 8, 2021 Share Posted May 8, 2021 Just saw this on Facebook: 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 8, 2021 Author Share Posted May 8, 2021 I'm liking that may have to get a spare diff to play with in the future regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 9, 2021 Author Share Posted May 9, 2021 20 hours ago, Daan said: Just saw this on Facebook: Ahhh Daan what did you go and do that for !!!! Can't get it out of my head lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted May 9, 2021 Share Posted May 9, 2021 I did look into doing that myself but decided is wasnโt doable. Clearly I was wrong and Iโm now sad I got rid of my mog diffs Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted May 9, 2021 Share Posted May 9, 2021 What page is that on @Daan? I wouldnโt mind having a look Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 9, 2021 Author Share Posted May 9, 2021 2 hours ago, dangerous doug said: I did look into doing that myself but decided is wasnโt doable. Clearly I was wrong and Iโm now sad I got rid of my mog diffs Don't be sad there's a guy on eBay selling 3 pairs of 404 axles for ยฃ600 per pair regards Stephenย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 9, 2021 Author Share Posted May 9, 2021 Going to have to strip one of my diffs down to see how doable it is with the equipment I've got. Daan did it say how much the diff nose was shortened by regards Stephen Quote Link to comment Share on other sites More sharing options...
Daan Posted May 9, 2021 Share Posted May 9, 2021 7 hours ago, Stellaghost said: Ahhh Daan what did you go and do that for !!!! Can't get it out of my head lol regards Stephen I did it because we are the most informative forum in existence, so it should be shared! 13 minutes ago, Stellaghost said: Going to have to strip one of my diffs down to see how doable it is with the equipment I've got. Daan did it say how much the diff nose was shortened by regards Stephen Have a look here:ย https://www.facebook.com/รssa-Offroadi-seiklused-102461024699138 2 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 Just for comparison hmmm which one is the 404 regards Stephenย 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 Why are these diffs a bloody pain to remove sorry moaning regards Stephenย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 Well thanks to Daan that's the diff pinion out so I can see what's what highly likely I will be having a go once I've sussed a plan of attack regards Stephenย 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 10, 2021 Share Posted May 10, 2021 Terrible influence this forum Quote Link to comment Share on other sites More sharing options...
Daan Posted May 10, 2021 Share Posted May 10, 2021 One day you'll thank me!ย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 14 minutes ago, Daan said: One day you'll thank me!ย Just not at the moment regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2021 Share Posted May 10, 2021 Lordy I can feel the weight of those things just from a picture Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted May 10, 2021 Share Posted May 10, 2021 6 minutes ago, FridgeFreezer said: Lordy I can feel the weight of those things just from a picture I promise you now, they are heavier than they look. To the point where my plan was to do what soren did and weld a mog flange on the end of a landy axle with the diff upside down. Iโve got one tacked together but canโt do a propper test fit with the shafts in place. Nige hasย got some 2.88 ring and pinions on the shelf with my name on to make the gearing a bit more sensible too... 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2021 Share Posted May 10, 2021 I'd be really concerned about the LR axle ever putting up with that amount of weight flapping around on the ends. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 (edited) So been having a bit of rough measuring I think I can take 110mm off pinion length plus what I've already removed gives me 155mm or a smidge over 6" ย I was looking to extend chassis by around 7" but I may get away with not lengthening at all, so all looking good on paper at least. But, there is a few issues namely splines to cut and threads to machine which is a pain as I have never done either with lathe or mill, also diff has internal threads for tightening up taper bearings so lots to do and think about regards Stephenย Edited May 10, 2021 by Stellaghost 3 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 On 4/26/2021 at 2:01 PM, Stellaghost said: I would agree most of the difficult machining is done although I still need to make tubes to hold radius arm bushes once I get around to needing to make the radius arm/arms regards Stephenย Talk about speaking too soon lol regards Stephen Quote Link to comment Share on other sites More sharing options...
Daan Posted May 10, 2021 Share Posted May 10, 2021 2 hours ago, Stellaghost said: So been having a bit of rough measuring I think I can take 110mm off pinion length plus what I've already removed gives me 155mm or a smidge over 6" ย I was looking to extend chassis by around 7" but I may get away with not lengthening at all, so all looking good on paper at least. But, there is a few issues namely splines to cut and threads to machine which is a pain as I have never done either with lathe or mill, also diff has internal threads for tightening up taper bearings so lots to do and think about regards Stephenย Just shim it like a land rover diff. Daan Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 10, 2021 Author Share Posted May 10, 2021 30 minutes ago, Daan said: Just shim it like a land rover diff. Daan Possibly, two taper bearings back to back, threads on pinion shaft tightens inner races and pushes bearing into tapered on-board bearing. Prop side bearing outer race is tightened by threaded castellated ring that screws into diff nose, may struggle with a shim to get bearing tight enough regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 10, 2021 Share Posted May 10, 2021 Adapt a crush sleeve from another diff?ย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 18, 2021 Author Share Posted May 18, 2021 Undercoat. Looking nicer already regards Stephenย 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 18, 2021 Share Posted May 18, 2021 Exciting !!ย Quote Link to comment Share on other sites More sharing options...
