Anderzander Posted June 19, 2021 Share Posted June 19, 2021 Well - that makes it all the more impressive what you are achieving with them 🤩 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 20, 2021 Share Posted June 20, 2021 On 6/17/2021 at 7:55 PM, Stellaghost said: Absolutely. At the moment I can only find replacement cutters in America at a cost of £250 ouch regards Stephen 9 hours ago, Stellaghost said: Just to add to this I have been checking out tool cutter grinders, how expensive are they really only havnt got one as yet because you can buy a lot of cutting tools for several hundred quid and of course I've only had my milling machine for a couple of years and my lathe two years longer, both of which were bought to assist with mog axle conversion, not that I'll be getting rid of them once the axles are finished lol Regards Stephen They are convenient to have around for when you have a blunt cutter at the weekend and no spares. I'm sure you'd find lots of strange used for a Clarkson, just make sure you get one with most of the tooling, that can be expensive to pick up afterwards. Quote Link to comment Share on other sites More sharing options...
Timc20xe Posted June 21, 2021 Share Posted June 21, 2021 what a great build this is . if you ever start offering the diff shortening as a service I would definitely be interested. I've 2 mog axle builds on the go . and have done a sumb axle build before Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted June 21, 2021 Share Posted June 21, 2021 (edited) 3 hours ago, Timc20xe said: what a great build this is . if you ever start offering the diff shortening as a service I would definitely be interested. I've 2 mog axle builds on the go . and have done a sumb axle build before We need pictures of these builds, lots of pictures!! Start a new topic and put them in this modified forum please. I have a sumb axle build ongoing and always looking for inspiration. Edited June 21, 2021 by Jamie_grieve 2 Quote Link to comment Share on other sites More sharing options...
Timc20xe Posted June 21, 2021 Share Posted June 21, 2021 10 minutes ago, Jamie_grieve said: We need pictures of these builds, lots of pictures!! Start a new topic and put them in this modified forum please. I have a sumb axle build ongoing and always looking for inspiration. Jamie I've got you on my Facebook. my builds are the big green 130 with 44" boggers. and now building a set of 404 axles up for my 90 with 38.5 mud treps , the sumb axles were on my old d1 years ago , my back still hurts lol I've not been on this site for years 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 21, 2021 Author Share Posted June 21, 2021 15 minutes ago, Jamie_grieve said: We need pictures of these builds, lots of pictures!! Start a new topic and put them in this modified forum please. I have a sumb axle build ongoing and always looking for inspiration. Second that regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 22, 2021 Share Posted June 22, 2021 8 hours ago, Timc20xe said: Jamie I've got you on my Facebook. my builds are the big green 130 with 44" boggers. and now building a set of 404 axles up for my 90 with 38.5 mud treps , the sumb axles were on my old d1 years ago , my back still hurts lol I've not been on this site for years I third a build thread, I find Facebook disjointed and generally horrible for build threads. Unless you know someone or happen across one it's hateful and even then you'll never find it a second time. Mike 2 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 22, 2021 Share Posted June 22, 2021 Another vote for a build thread 1 Quote Link to comment Share on other sites More sharing options...
Timc20xe Posted June 22, 2021 Share Posted June 22, 2021 16 hours ago, Stellaghost said: Second that regards Stephen what are you doing with your front axle ? are just using it upside-down and putting another diff drain in or are you cutting and shutting the axle casing ? cheers Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 22, 2021 Author Share Posted June 22, 2021 (edited) 7 hours ago, Timc20xe said: what are you doing with your front axle ? are just using it upside-down and putting another diff drain in or are you cutting and shutting the axle casing ? cheers Not doing the upside down thing I'm going to swap the axle tubes ( cut and shut ) regards Stephen Edited June 22, 2021 by Stellaghost 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 25, 2021 Author Share Posted June 25, 2021 Managed a bit this morning, Shaft now ready to complete splines tomorrow providing my cutter sharpening is up to it regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 25, 2021 Share Posted June 25, 2021 I like that plan Stephen, Saves you a lot of cutting length! Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted June 25, 2021 Share Posted June 25, 2021 How does the pinion shaft splines compare to the half shaft splines? What major and minor diameters are they? You need to make new short shafts to move the front diff over? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 25, 2021 Author Share Posted June 25, 2021 1 hour ago, Jamie_grieve said: How does the pinion shaft splines compare to the half shaft splines? What major and minor diameters are they? You need to make new short shafts to move the front diff over? Pretty similar however I will measure tomorrow and feed back Short half shaft wise I have a new one with extended splines that may do the job I will be taking a closer look shortly regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 26, 2021 Author Share Posted June 26, 2021 (edited) 14 hours ago, Jamie_grieve said: How does the pinion shaft splines compare to the half shaft splines? What major and minor diameters are they? You need to make new short shafts to move the front diff over? 12 hours ago, Stellaghost said: Pretty similar however I will measure What a load of rubbish I speak sorry So half shaft major diameter is 41.32 mm minor diameter is 36 mm. Pinion major diameter is 37.5 mm and minor is 32 mm Picture of them side by side This is the extended splines shaft for the short side, this is what came with the axles when I bought them and is used when flipping the front axle which of course I'm not doing regards Stephen Edited June 26, 2021 by Stellaghost 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 26, 2021 Author Popular Post Share Posted June 26, 2021 Good news for me cutter sharpening did the trick out of mill and prop flange tried it fits yea, Reduced end cut off Diff built up to see if all OK looking good, still have seals to do and a detailed drawing of pinion dimensions, the Eagle eyed among you will notice the paint has gone crinkly that's due to high temp wash at work so I will need to do it again Couple of pictures to try and show the finished difference between original and modified diff I'm reasonably happy with the result regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 26, 2021 Share Posted June 26, 2021 Reasonably happy ?! It’s fantastic! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 26, 2021 Author Share Posted June 26, 2021 (edited) 1 hour ago, Anderzander said: Reasonably happy ?! Wrong word choice, I was sulking because of the paint I'm well bloody happy regards Stephen Edited June 26, 2021 by Stellaghost 2 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 26, 2021 Share Posted June 26, 2021 Yay !! I get the sulking - I’ve just ticked off 5 jobs well done and then made a right hash of bending up my brake reservoir pipe, I’m sulking about that but bloody happy about the others. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 26, 2021 Share Posted June 26, 2021 That’s fantastic! Loosing that length is going to be a great help 1 Quote Link to comment Share on other sites More sharing options...
Timc20xe Posted June 26, 2021 Share Posted June 26, 2021 looks great 👍 I've got another diff here for you to shorten if you get bored 😆 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 26, 2021 Author Share Posted June 26, 2021 Front axle tired me out today its so bloody heavy Moving and balancing don't really want to do the handling Split into manageable chunks Researched diff removal this time it has to go 90 degrees to the left then it lifts out a doddle All steam cleaned Axle on bench ready to play cut and shut regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 26, 2021 Share Posted June 26, 2021 Cool - flying along. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 26, 2021 Author Share Posted June 26, 2021 32 minutes ago, Timc20xe said: 👍 if you get bored 😆 I dream of being bored lol regards Stephen 1 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted June 26, 2021 Share Posted June 26, 2021 3 minutes ago, Stellaghost said: I dream of being bored lol regards Stephen ...no , you don't , you dream of the next engineering challenge . Absolutely great work Stephen , this is one hell of a build . Steve 1 Quote Link to comment Share on other sites More sharing options...
