Popular Post Stellaghost Posted December 30, 2021 Author Popular Post Share Posted December 30, 2021 Aahhh you guys worry too much will soon be a pain in the forums butt, actually in the treatment room as we speak joking aside thanks a bunch guys take care oh and check your tackle just to be on the safe side Regards Stephen 5 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted December 30, 2021 Share Posted December 30, 2021 2 hours ago, Stellaghost said: Aahhh you guys worry too much will soon be a pain in the forums butt, actually in the treatment room as we speak joking aside thanks a bunch guys take care oh and check your tackle just to be on the safe side Regards Stephen That's the way.. my mate has prostate cancer, with extra's. I had colon cancer myself. It does show you what kind of person you are, cup half full or half empty🤗 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 30, 2021 Share Posted December 30, 2021 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 31, 2021 Author Share Posted December 31, 2021 (edited) On 12/24/2021 at 11:35 AM, FridgeFreezer said: On 12/24/2021 at 11:35 AM, FridgeFreezer said: I've always wondered abut a concentric clutch release bearing as a difflock actuator for these sliding-collar style lockers. @FridgeFreezer what did you do that for........ Between you and @Daan your dictating how I do my build lol. Seriously you've put thoughts in my head, from studying previous measurements I can fit something in there bloody tight but doable I think. Nothing on the net suitable so going to have to make something from scratch. Inner axle case bore is 69mm and halfshaft diameter at splines is 42 mm, so that gives me 27mm to make a single acting hollow bore pneumatic cylinder, my ARB lockers only have O rings to keep air pressure in so I will also go down that route using the return spring built into the diff to push the piston home when air pressure released. The beauty of this is that the diff lock mechanism will be totally protected by double thickness axle cases Also I could install a back up cable system that could be stored away until needed pending a failure of pneumatic cylinder, thoughts and reactions are compulsory lol regards Stephen Edited December 31, 2021 by Stellaghost 3 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 31, 2021 Share Posted December 31, 2021 I accept no responsibility - people should know better than to listen to idiots on internet forums! The reason I suggested concentric clutch release is that it doesn't need compressed air - the Volvos use engine vacuum, but a simple cable or passive hydraulic master/slave also appeal for simplicity of operation. Not sure why you'd need to include a backup system, if it fails surely it's not too hard to lock it up by hand somehow if really needed? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 31, 2021 Author Share Posted December 31, 2021 16 minutes ago, FridgeFreezer said: I accept no responsibility - people should know better than to listen to idiots on internet forums! well idiots should know better than to make suggestions lol The reason I suggested concentric clutch release is that it doesn't need compressed air - the Volvos use engine vacuum, but a simple cable or passive hydraulic master/slave also appeal for simplicity of operation. the problem is a clutch housing has masses of room compared to an axle tube, also double skinned axle caseing does not help, all the ones I looked at on the net are bulky and not very packagable Not sure why you'd need to include a backup system, if it fails surely it's not too hard to lock it up by hand somehow if really needed? True, but I'm thinking if I put a manual system in so I don't have to crawl under a vehicle that could possibly be stuck in mud, having said that I could winch to dryer land Regards Stephen Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 31, 2021 Share Posted December 31, 2021 7 minutes ago, Stellaghost said: why you'd need to include a backup system I just took it that the whole ethos of the build seems to be to outlive the cockroaches 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 31, 2021 Share Posted December 31, 2021 It’s a new year mate, and you can only move forward 👍. You’ll get through this nut of a problem and back to the Mogs when time is right. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 31, 2021 Author Share Posted December 31, 2021 21 minutes ago, uninformed said: It’s a new year mate, and you can only move forward 👍. You’ll get through this nut of a problem Very true thankyou, however I only have one nut to worry about now lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 1, 2022 Share Posted January 1, 2022 Just belatedly read this, and I am sorry to have not responded earlier, I wish you a speedy and total recovery, Stephen 1 Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted January 1, 2022 Share Posted January 1, 2022 Wishing you well and a full recovery, Stephen! 1 Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted January 1, 2022 Share Posted January 1, 2022 Wishing you a swift recovery, Stephen! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 2, 2022 Author Share Posted January 2, 2022 (edited) On 12/31/2021 at 5:14 PM, FridgeFreezer said: idiots on internet forums! So having listened to said idiot lol a bigger idiot has started to see how doable it actually is, so the pictures below give an idea on the limited packaging space available Inside diff case With halfshaft installed going to have to remove some of that inner casing bulb diff lock mechanism ,cylinder is going to need to move around 30mm diameter of bore to play with 69.7mm Slightly undersized cylinder wall fitted to give an indication this may end up being a lot of work for nothing but as I've said before nothing ventured nothing gained potential problems Fitting some sort of thrust bearing / mechanism to push on diff lock cog face Choosing internal o ring type to withstand air pressure, axial and possibly rotational movement thinking ptfe ?? Feeding cylinder with compressed air once installed, insert air pipe through axle cases?? Fastening cylinder in place so it can be removed for seal replacement, i have ideas on this may get away with an aluminium crush tube arrangement that will nip cylinder in place once portal hubs installed and nipped up Anyone think of anything else or even just say its a load of carp Thoughts appreciated as always regards Stephen Edited January 2, 2022 by Stellaghost Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 2, 2022 Share Posted January 2, 2022 5 minutes ago, Stellaghost said: Anyone think of anything else or even just say its a load of carp Well I think you definitely shouldn't listen to me. That axle casing looks very tight - at least the Volvos are square and have a bit of wiggle room, the mogs seem to have just filled all the available space with more metal just in case Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 4, 2022 Author Share Posted January 4, 2022 On 9/19/2021 at 8:53 AM, Ed Poore said: Another option is a mate of mine might still have a custom 0.9:1 (yes I do mean 0.9 to 1) LT230 kicking around in his yard. A wee bump @Ed Poore how's the box hunting going regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 4, 2022 Share Posted January 4, 2022 19 minutes ago, Stellaghost said: A wee bump @Ed Poore how's the box hunting going regards Stephen ******* **** I was there last week and completely forgot to have a hunt with Bob for the box, and I'm off up your way next week too . I'll chase him up this evening and see what we can work out. Him finding time is the issue... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 4, 2022 Author Share Posted January 4, 2022 25 minutes ago, Ed Poore said: ******* **** I was there last week and completely forgot to have a hunt with Bob for the box, and I'm off up your way next week too . I'll chase him up this evening and see what we can work out. Him finding time is the issue... As I said no rush but would be a nice option for me to have cheers regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 10, 2022 Author Share Posted January 10, 2022 So my mog axle lightweight project now has a new name, this will keep me straying close to names associated with other Unimog/ Landrover/ Buggy projects on this forum. Name related to some comments here... and because it's built to last....... So from now on it is affectionately being called.............. Sid the Roach Regards Stephen 2 2 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 10, 2022 Share Posted January 10, 2022 1 hour ago, Stellaghost said: So from now on it is affectionately being called.............. Sid the Roach Regards Stephen Love it. Mike 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 11, 2022 Author Share Posted January 11, 2022 So been having a wee bit of sedate pottering over the last couple of days exploring " idiot" suggestions Started making pneumatic cylinder on lathe slid into position not as far up as I wanted but bore tapers in so I will have to adapt from diff side bench testing rig Halfshaft in More to follow regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 11, 2022 Author Share Posted January 11, 2022 Video of bench test 20220111_122008.mp4 Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Wytze Posted January 11, 2022 Share Posted January 11, 2022 Oh yes... you brilliant man you😁 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 11, 2022 Author Popular Post Share Posted January 11, 2022 Happy with bench test will be better in axle when no scope for movement Next issue is fitting some sort of thrust bearing so cylinder piston does not spin and wear o rings prematurely Cue one landrover clutch release bearing cut plastic insert out make carrier bush to press into piston and then press clutch release bearing on Fit it together how it will look so all I need to do now is package it into axle...... that will be another story...... regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 11, 2022 Share Posted January 11, 2022 Those bearings just press off the plastic carrier, no need to cut the plastic. Just saying. Mike Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 12, 2022 Author Share Posted January 12, 2022 Think I've got this packaging sussed Managed to trim bulb with plasma cutter because this didn't work next problem cannot quite reach with disc grinder so bodging in order.. one shaft from knackered grinder some heavy wall pipe pressed together Grinder tightening nut welded on sorted then cleaned up with die grinder, burr and flap wheel had to thread air line through axle to achieve this air cylinder piston cut to length Placed into axle tube and air pipe connected I then installed diff, video to follow What's left to do, obviously make another one for rear axle Solder copper pipe in and feed through axle case, just don't know best way yet Roll up an aluminium crush tube to keep cylinder tight in bore Think that's about it regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
