6 hours ago, MECCANO said:
Disappointed you haven't wittled these from a oak you felled before your morning brew. Just not good enough.
You will have to stay disappointed.........
Woodwork was never a strongpoint for me..... Regards Stephen
21 minutes ago, Stellaghost said:
I'd like to say I bought it...............
but the truth is I forged it from a piece of comet I rode through earths atmosphere, then quenched it in the North sea to temper it, finishing it off crushed diamond shards.......
Regards Stephen
Your super hero name is BS😂😂
9 hours ago, cackshifter said:
Is that actually wood or just  cleverly painted steel?
'scumbling' can be used to make wood effect steel, some vintage wagon restores use it on the inside of cab roofs.
38 minutes ago, miketomcat said:
Don't tell @FridgeFreezer you have that he gave up trying to find the correct angle and therefore a reamer.
Mike
Funny enough I've just been reading that
This reamer is for mog tie the rod ends, still tracking a 11 degree reamer for Landrover tie rod ends regards Stephen
Wouldn't a tapered end mill of 11 degrees do the job as well as a reamer?
It certainly would but only finding them on American sites at the moment
However I have a cunning plan, I can make a track arm out of heavy wall pipe that I can tap to landrover track rod thread at one end and unimog thread at the other end so m16 and m24
Regards Stephen
My whole thing was I didn't want to ream out the axle ends because then you've modified a casting that is hard to replace (and also likely hardened/heat treated because Sweden) - also LR rod ends are tiiiiny.
