43 minutes ago, Stellaghost said:
Lifting operations today
Front axle out at the moment
wheels fitted for standing, front and back views
Jerry can for perspective
Close up of wheel rim mods now fitted, hub nut just in view on last picture
total width is 76" and lightweight with coiled axles sits at 71" so 21/2" extra width to accommodate with mud guards, I'm really quite happy with that because it's not going to look stupid wide
Now to lift the rear axle back in for pneumatic cylinder fitting and A frame modifications
regards Stephen
Very ,very nice indeed Stephen..     The rim's look factory to..  Great!
  • Thanks 1
3 minutes ago, Anderzander said:
My goodness they look amazing.
Must be so satisfying craning those out - where not only have you hand fabricated so much of them - but where they look like a factory produced item.
Outstanding.
Thank you, you are too kind
However I must admit I had a right big smile on my face this morning
Honestly, they will never be as good as factory, but I'm happy with them and that's what counts at the moment, but it is very nice of you and others to say they have a factory finished look about them
 Regards Stephen
  • Like 3
Really very, very nice, the stainless(?) cap heads really set them off very nicely. Perhaps when they are full of mud you may curse them, but perhaps they will be fine ;)
So tidy..... very nice work indeed.
  • Thanks 1
1 hour ago, TD5toV8110 said:
Wait a minute....
You have a job as well as doing this?
Double all the impressiveness.
Yep sure do, need the job to fund my hobby and tool addiction
Although I plan to retire within a couple of years regards Stephen
  • Like 3
Yes , retire so you can build axles full time... Can you do mine first? 😄
I can feel myself turning green with envy. If i had half your skills i would be a happy man.
Now i Just need to convince the wife mog axles are a sound investment.
  • Thanks 1
The jerry can under the axle does indeed show perspective :) . Absolutely brilliant work Stephen and on the
home straight now . By the time the chicks have fledged you'll be ready to chuck 'em under
Steve
  • Thanks 1
Finally managed to get a decent spare tyre
A part worn Comforter cf3000
37 13.5 r20 no idea what they are like but as long as it gets me home it will be champion
fitted, looks good for height regards Stephen
  • Like 4
Just to add with built axles
Thought I'd made a massive mistake because wheels are canted outwards at the top but after consulting Google it would seem that mog axles are cambered ( phew)
Lightweight body is no where near as heavy so undecided as yet whether to leave them as they are or machine the camber out
What do you guys think, will it give me any issues ??
Regards Stephen
Regards Stephen
I think, off road it will be no problem at negative camber..  Hookin it round a round about will not be it's thing, just go straight over it😁
  • Like 2
  • Haha 1
Regards Stephen
Search for “mog9 build” and there is a guy who’s machined a spacer to take that camber out
  • Thanks 1
Personally I’d say it will help with steering off road your getting extra pressure on the outside of the wheel when turning out of ruts and changing direction on soft surfaces. Mogs are extremely good at this type of operation.
or just put some washers behind the wheel on the bottom two studs 🙈
  • Haha 3
Top of tyre out is positive camber. The boy racers with top in is negative camber.
Mike
  • Like 1
