New product from xcess4x4
A while back while dropping some big bolts(m125) off to nigel we got to talking about strengthening an axle case for an up and coming build I have. The I mentioned the KAM Solutions (cds tube down the case and fill the void with resin) to wich nige rolled his eyes and groaned.....can’t really remember the exact wordings but to summarise he said “don’t” and lead me down to the shed where he had prototype no1 of his new axle truss. Big mistake nigel, I proceeded to become a royal pain in the arse asking when they will be done once or twice a month(atleast). Today they arrived. These are only a prototype batch sent out to around 20 people to “try” and report back on figment issues or anything else to be changed. Super light weight but also super strong as it is made from that domex stuff he makes the clutch fork braces out of. in other words double hard person I'm not that keen on steel! And only 3MM!
so like I say, today they arrived......at 3 o clock and I had to leave to pick my daughter up at 4. Alot to do there....I’ll have a go! So this is what I came up with in just under an hour, not bragging about work speed or anything, it just illustrates how good the fit up is out of the box!
Forgive the mess, still going through a tidy up
start with a freshly blasted axle case
offer up truss and draw around it to identify where where I need to grind off the primer I specifically asked to be left off!
A few teeny tiney fitment issues that a tickle with the grinder sorted.....
and to put that fitment to the test we got the tig out!
basically ignored the instructions. Not because I know better but I wanted to see how this would all react(test donkey remember) and all seemed fine!
so now you know @Hybrid_From_Hell you have to really mess up to ruin it!
the main divergence from the instructions was I started the tacks in the middle and worked my way out. My thinking then was if something did warp and lift it would be easier to lose that in an end rather than the middle
A few little problems cause by me going in guns blazing but nothing too bad. Be nice, I havnt picked up my tig for nearly a year so the welds arnt my best.
all in all its a very nice thing, some minor fitment issues but that is probably down to my casing rather than the design of the truss.
The only thing that that bugs me are those holes. They are very nice but I think the weight gained by it filling with thick mud will out weigh the lightness of speed holes. however there are drain holes in the bottom so I could be proven wrong. This case won’t see combat for a long time yet so others will have to find that out for me.
And Although he says there isn’t a market for it I still think there needs to be a domex weld on diffpan to go with the trusses. those 6mm ones are heavy and it would finish it off just right.
anyway, thought I would share. I think after the prototypes are all fitted there will be tweeks to the next batch to make them even better.
and the best part is they are cheaper than a front and rear set than the kam/terrafirma counterpart!
Feedback welcome
Doug
1 minute ago, Bowie69 said:
Is the axle case still straight? I'd be a bit suspicious of it pulling it out of true when cooling.
A good question and one I will answer on Sunday! This axle is having the diff flipped in it so I made some bungs to go in each end and a bar that passes through the diff to aid in that. We will see if it all still fits and if it’s still straight. But that is another reason I wanted to use the tig as I don’t think it heats the sourounding material as much as an arc or mig while still delivering the penitration
What size tungsten did you use for that?  I find the TIG still fires a fair amount of heat into stuff when the Amps are wound up, the trusses look like a nice piece of kit though.
one question...wtf do you need to bolt with a M125?? :o
Tower crane base bolts ;)
12 hours ago, Arjan said:
Looks nice !
Didn't Series axles have a reinforcement like that ?
Yes as did the WOLF.
What Land Rover discovered during the WOLF trials ( a friend from uni was on the Land Rover team) was that the Salisbury axle would bend more easily than a Rover axle, under certain circumstances. Hence the reinforced Rover axle cases on the WOLF
I think it was the Sals axle tubes pulling out under chronic overloading, or at least that's what happened here in Oz.
As a consequence the Telstra 130 extended cab TD5's here had heavily trussed Wolf rear ends.
Interesting that Rover put the strengthening at such an angle. Facing partially into the direction of travel.
This from a  1972 lightweight that had VLK armour retro fitted in service.
Slight angular variations aside, the biggest difference between Land Rover stiffeners for Series axles, and the fitted example of the new product, is that the new product has been fitted above the axle, and the underside left with nothing, whereas LR put Series axle stiffening on the underside of the axle casing.
In the pictures of the fitted product in this thread I have taken the position of the axle breather to indicate the top of the axle casing.
Judging by the alignment of the name on the new product, the positioning on top of axle casing is what is intended.
Regards.
Regards.
You are right but the front lr axle is two identical Half’s welded together so if desirable you could weld on on the bottom aswell/instead
I suppose it depends on where the damage is coming from? I'd prefer above, ground clearance and all that, but Rover must have had good reason to go below.  Perhaps they saw the risk coming from rocks, or IEDs. Don't know.
I should pull out the rear axle and see if it's the same.
I've found TIG puts in waaay more heat than MIG but maybe that's cos I'm slow? :blush:
Was sort of tempted but bit blingy for me and don't really have a need and don't have any spare cash so that solved that.
I had the same thought over the holes and mud. Curious to know how a dimple die setup would compare to domex on strength vs weight vs cost.
My lightweight axle stiffener didn't look anything like that.... was square to the road surface.
1 hour ago, Bowie69 said:
80, ex RAF I think.
I wonder if they changed the specification? Is that a full width axle, or has it the short half shafts?
My 1968 lightweight had the strengthened front and rear axles, the front one was still bent despite the reinforcing!
If you look carefully, as well as being fitted with the additional VPK aeon spring mountings the front casing in photo above is reinforced on the short side too - bump stop is braced to the spring locating foot on front and back of front axle. Both my 1980 lightweights had standard unreinforced axles.
Edited by oneandtwo
Good spot, I think that was done to support the Aeon support springs, it doesn't look as factory as the strengthening.  On this lightweight both front axle rear spring chassis mounts had serious structural cracks where the tube was breaking away from the chassis.  Goodness knows what the army did to them, aside from chucking them out of helicopters!
G.
  • Like 1
