Making my own main loom/harness
monkie
Man do I feel your pain. I started mine on December 22. I have my son every other week so I don't touch it when he's with me so I do take breaks but basically been a month of work. I've added a LOT of options to mine and I find if I make a break down list of what I need to do then cross it off as I do it it really helps mentally. You can see your progress even though you feel like you're not getting anywhere. I can finally see an end now, but having to figure things out along the way really takes it toll so I try to have some easy jobs to do along the way. You'll get through it.
 I gotta say I really hated fishing the wires for the door jamb switches haha. 30 relays and just under 50 fuses later........gotta test it all out and then clean it up, I never want to touch this again!
Sean
  • Like 1
Sean
All that work Sean, then you discover that your steering wheel is on the wrong side 😉🤣
Mo
  • Like 1
  • Haha 2
Sean
The thing is, you can be properly proud of what you have achieved.
Well done fella :D
  • Like 2
20 minutes ago, elbekko said:
Does £700 still sound like a lot for not having to do it yourself?
That has been going through my mind as soon as I started to chop up my old loom! I have added a few mods to mine like upgrading to modern connectors, relays for the headlights, better earthing for each corner and glow plug relay.
Also indid a little more on it today with a fresh mind. I sorted out the parts that were bugging me yesterday and it's really taking shape. I think I spent too long on it yesterday.
  • Like 3
Good to hear, don't back down haha.
I've spent more than 700 on wire and plugs alone haha. The problem is with a kit it will never be what you want and you have to modify them. I've read so much on Defenders having a bad ground and the search is on to find it. For this alone I ran three ground busses (engine bay, cab, rear) all tied to the battery. I suck at electrical trouble shooting.
Mo
I knew when I took it down to the frame I might not get it back together properly. I also put the wrong engine back in!
Sean
  • Haha 1
sgo70, I'm about to start making my own looms for total wiring replacement on my 110 CSW, so I have been following this thread closely.  I am currently struggling to find suitable, accessible locations for auxiliary fuse and relay panels.  Please, what locations have you selected for your 30 relays and just under 50 fuses?
Mike
2 hours ago, sgo70 said:
I sent you a pm cause first I feel like I'm hijacking Monkie's thread and also I don't think I'm allowed to post a link to my build which is easier than explaining everything.
Sean
Don't worry about that. The more information the better, it's all a learning process as far as I'm concerned. I have taken inspiration from how you and other people have done things, I don't want to be reinventing the wheel.
1 hour ago, Bigj66 said:
For connections to relays etc are you guys just using standard blue/red crimped insulated spade connectors or something else?
Yes but I try to buy decent quality ones, ideally Tyco/Amp, as the cheap ones are often so badly made they'll never work reliably if they stay on at all.
I use these type sockets with the hanger so I don't have to unscrew a relay to change it. You have to get the terminals with the tabs on them to hold them in.
https://www.12voltplanet.co.uk/standard-mini-relay-socket-with-terminals.html
Spent all day yesterday laying on my intake manifold running engine bay wires, sore today. If you look closely at that spaghetti mess of a fuse box you can see 3 relay holders on the side. Thats the fuse box with 10 relays and 40 fuses, couple smaller ones inside the truck. One 60 amp relay and 3 stereo wires to go!!!
Sean
Edited by sgo70
Sean
This is top quality work, my eyes are drawn to the large blue wire on top of the engine. I think one is going to cause you a bit of trouble :lol:
4 minutes ago, landroversforever said:
That's what I was thinking.... what on earth needs that many relays? One for each and every single light on the car? :o
I don't know they add up pretty quickly
  • 4x for the headlights*
  • 1x Glow plugs
  • 2x Heated windscreens
  • 1x Hazard relay
Thats 8 before you start adding any extras such as an air compressor etc. For example when I eventually get around to the 1UZ swap there's two more for the igniters, at least one fuel pump, ECU main power and so on.
* Or you get into the situation I did where lose one light and lose both whilst doing 60mph down on a narrow road next to a Loch in Scotland in a storm at night - not a pleasant experience I can testify to.
  • Like 1
4 hours ago, FridgeFreezer said:
I can see an LS but I still don't know how you manage to fit that much wiring into a Defender :ph34r:
It's a giant Faraday Cage. 🙂
Beautiful workmanship but watch out for thieving "travellers", if they strip the car they'll get £9k in copper!
Can't wait to see the end product.  👍
G
Here's my entire fusebox and relay collection for the 109:
That's everything in the truck fully fused & relayed including heated screen, EFI, digital dash, and dual-speed electric fans (Freelander dual fan relay behind dash). ECU+EDIS are behind the gauges, midi-fuses for the main power feeds are in the battery box. Total <10 relays and <30 fuses (that's the fusebox capacity but I've got unused slots).
  • Like 1
Yeah I had to add 2 for each window for power windows, 2 for power door locks, 3 for the AC to get the engine to idle up and turn on the rad fan, 3 for headlights, air compressor, brake relay for engine ecm, reverse relay, 2 seat heaters, starter, 2 LED flashers, I can't remember the rest. It takes quite a few just for engine controls because it has to go from a 20g signal wire to the load. I didn't even count the 4 built into the push button start, remote start, alarm etc. I don't even want to show what I did to the batteries today, you guys will make fun of me haha. I'm afraid to hook up the positive cable still, have at it lol.
Sean
Edited by sgo70
  • Like 2
And yet despite all those relays he'll still be driving it long before you drive yours Ross 🤣
Mo 😉
  • Haha 3
