JeffR Posted January 18 Share Posted January 18 (edited) OK, so I've had a bit of a morning. Started swapping out the very leaky power steering box and sheared 3 out of 4 7/16 bolts (not a problem got new ones and a new box) so it got me thinking. Air temp round here is currently -5 C. thats a tad chilly, actually there's a queue of female sorceress' awaiting breast reconstructions, the bolts were put in during the summer and torqued up to 60ft lbs. also sheared the alternator belt tensioner on the family passat, but thats aluminium, so its not really metal..... Anyone know how much the tensile strength is affected by a reduction in temp? I wonder what the change in tension is when a relatively hot bolt (mid 20 C) cools down. Edited January 18 by JeffR 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 18 Share Posted January 18 It could be moisture or water in the threads or bolt hole frozen and expanded, wedging the bolts. Lowered temperatures do increase brittleness, but I think you’d need much lower than -5oC to significantly affect bolt tensile strength (but open to correction on that). 1 Quote Link to comment Share on other sites More sharing options...
JeffR Posted January 18 Author Share Posted January 18 could well be, but the threads on the cattle trucked bits showed no galling (cross threading is natures loctite), moisture or corrosion. Bolt heads sheared with a clean clearly defined "crystalline" pattern at the junction between threaded section and unthreaded section. Of course it could just be the bolts were ancient and past their sell by date (like their owner). To top it all I set fire to my beard again 3 Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 18 Share Posted January 18 50 minutes ago, JeffR said: To top it all I set fire to my beard again It was the "again" bit that had me fall off my chair 🤣 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 18 Share Posted January 18 Wikipedia suggests it's got to get down to about -74 for steel to become brittle: https://en.wikipedia.org/wiki/Embrittlement#Low_temperature_embrittlement Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 18 Share Posted January 18 Ordinarily. But this is Jeff we're talking about. 3 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 19 Share Posted January 19 It is definitely easier to snap bolts off in this weather. In fact in my experience anything you touch at subzero temperatures is likely to break. I'm sure there's science to it and plastic is worse you only need look in it's general direction. Mike Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted January 19 Share Posted January 19 This is really interesting. If the science says the difference isn't in the materials, maybe it's in the interface between them. I.e. everything is contracted in colder weather, clearances become tighter and the torque to break free becomes higher. Add in any rust in the threads and a tight tolerance may become no tolerance. I dunno, I'm neither a scientist nor an engineer, as evidenced by my car. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 19 Share Posted January 19 10 minutes ago, ThreePointFive said: This is really interesting. If the science says the difference isn't in the materials, maybe it's in the interface between them. I guess it's a line or curve down towards that -74 figure too, not a sudden change. Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 19 Share Posted January 19 13 minutes ago, ThreePointFive said: I.e. everything is contracted in colder weather, clearances become tighter and the torque to break free becomes higher. Add in any rust in the threads and a tight tolerance may become no tolerance. That's what I was thinking too. But the things it's bolting down should shrink as well, so not sure how much any of that matters. Quote Link to comment Share on other sites More sharing options...
toenden Posted January 19 Share Posted January 19 (edited) A couple of years ago, I was making "long postponed maintenance" in the depth of -15c (some time you get proud of yourself....) doing so, I dropped a 19mm spanner on the concrete paving and it snapped in two with a very high "pling"... the spanner was a reputable make. At the time the only reason I could come to was the temperature. Of course my dad pointed out, that I ought to use it faster next time, to get some heat buildup into it... 🙄 /mads Edited January 19 by toenden Spelling 4 Quote Link to comment Share on other sites More sharing options...
Escape Posted January 19 Share Posted January 19 What was the response to the warranty claim? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 19 Share Posted January 19 The answer to this is "it was your beard's fault" . Standard bolts are good down to -50 so it was definitely your beard. 1 1 Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 19 Share Posted January 19 The other day I had a G clamp frame snap. Have used it for years, and I never strain them by using any extension on the T bar. I also put it down to the temperature. Not an expensive one, so was probably cast iron rather than steel. Who know ? A few weeks ago I watched half of a program about ships disappearing in the late 19th, early 20th century in cold climates. They attributed this to failure of the steel plates or rivets. Not high tensile obviously, but interesting none the less. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 20 Share Posted January 20 Different materials have different expansion and contraction rates with temperature. Aluminium expands more with threat than steel for example, so also contracts more. That means a steel bolt into aluminium will be much tighter in the threads when the cold sets in. The same will apply to a lesser extent with different grades of steel. Quote Link to comment Share on other sites More sharing options...
