The Hunt for a Waterproof V8
I first do have to say a few BIG "thankyous" :
Jon White _ wiring and soldering eggspurt :D
Mr Fridge - for bleating and making me go this route at all :P
Bull Bar CowBoy (Ian G) for operating his "Samaritains Help Line" and general helpful knowledge :)
SWMBO for putting up with paper diagrams and oiley bits everywhere in the kitchen :huh:
Bill Shurvington - For some of the parts and general help........................ :)
The problem for me and for many other V8s is that V8s do not like water :
So for a number of months the hunt was on........
1st I toyed with making myy own dizzy with an outer sealed casing - got so far and scrapped that,
then a SAS ex 110 RF cover system, bought but still not good enough,
and after many many routes, INC research into Buick Dizzy (now with R Vogue on this toy :P,
and DUI dizzys along with the HEIs, ......
none of which is really water proof - more water resistant ..............I decided on one route
MEGAJOLT EDIS 8 V8
There was a final and impelling reason for me to fianlly choose this route -
namely that the 4.5 Eales V8 has NO VACUMN just a set at 30 degrees at 4000 rpm and job done.
This makes for a very lumpy tickover as the advance is around 16 degrees - far too much, with MEGAJOLT I also have the option of a 10x10 ignition MAP thereby re-using the vacumn, and being able to reset the ignition at whatever it SHOULD be at 10 x RPM buckets along with 10x Vacumn settings :
So, 1st job was to read read read print read and learn :
The MEGAJOLT Site :
http://picasso.org/mjlj/?q=
Here I learnt as best I could (and with help from Fridge and Jon W) decided to go this route, I have gone this route also as the EFI system is tunable for me, and megasquirt is even more complex, my problem was not carbs / EFI mine was Water and a V8 not mixing :P
You will need.
Trigger wheel 36:1 and gap
EDIS 8 Unit
Megajolt ECU
2x Ford Mondeo or other 4 cylinder coil packs
Make up new (longer leads)
Vacumn pipe
VR sensor and plug (ford)
Beer
mate to do wiring (hello Jon :P )
Mate to cry down the phone to (Hello Fridge)
Beer
Asprin
time
More Beer
A PC running XP serial port so you can connect to the ECU to play with the Ignition MAP
This system also has the attraction, that if it fails, it has a 10 degrees set advance "Limp Home Mode",
or if I reconnect 1 wire to the coil, place a rotor arm and the old dizzy cap and leads back on I still have the old system as a back up unit.
EDIS 8s are not available from the UK, they come off Lincoln V8 town cars, I have bought a few from E-Bay USA, this is not the same as UK and adding "Worldwide" as an option - so go and look here :
http://www.motors.ebay.com/
Trigger words are EDIS8 EDIS 8 Lincoln Ignition Module etc, pay about £25-£30 for EDIS and the plug with wires (you cannot get this plug new or elsewhere !) EDIS 8 on its own even cheaper (my spare)
The trigger wheel I 1st bought a "should do basic model" much machining later it was no good too big.
Ended up making my own, got it slighly wrong (5mm OD too small) but with a spacer ring to move it back it allowed me to have the sensore almost behind the pulley :
The bracket with the sensor has up/down movement and in out movement,
as the VR sensor has to be set at 10 degrees adavnce and around .5 - 1.5mm from wheel,
................nothing 10 hours on a lathe can't sort, ...........oh for a CNC punch.... :(
The EDIS8, shown here wired up and connected, these are arraently also waterpoof, but I have mounted mine high up to be super safe, if this gets under water, then thats the least of my probs !
below are the pics of the FORD coil packs mounted on the rover cover,
.....................I did spend ages deciding where to fit these :
and here with the leads made and fitted -
I will prob remake new leads later, these were a "Quick Job" to see if all worked - these are done by buying cheap long leads, chopping off the coil end, (or dizzy end) then "Undoing" a FORD end (scrappy for loads and loads of leads - some break - some do come apart) then recrimping the ends back on to the new leads, the coil packs are an exellent fit betweem lead and coil,m best waterprrof connector I have vever seen :
And finally the megajolt ECU shoved temporilary loosely in the cubby box :
Getting it all running was a bit of a pain, had to use the bit of a bodge method which has been outlinned by Mr Fridge and geoff B, but it worked, I am pursuing "A better Bodge" and will advise....
When it was all sorted I had a annoying Hic-cupy type misfire, this was fuelling, now I have such a good spark it burning weak - so a good hard tweak of the "More Fuel" on the adjuster on the ECU now sees it run very smoothly (better than before by miles) yet with a 10x10 "Guesstimeated IGN MAP".
next steps are :
1. Finish the snorkel FFS :lol: and quickly !
2. Me, my wallet, Mark Adams, my 90 and a certain 4wd Rolling road :) ..... for real time tweaking
Yes, its a lot of work, yes you have to do a lot of research, but I for one am chuffed to bits and am looking forward to a V8 that doesn't misfire near in or under water B)
Thanks to all again who have helped, much appreacited !, oh and lastly these pics are in LR4x4.com gallery - I lost ALL my pics due to an error on Photobucket.com :angry:
Nige
I was having a think about diesels v v8 the other day actually.
if you want power buy a V8
if you want reliability/"waterproofness" then buy a diesel.
To both you need to spend some money.
it always make me laugh when you hear dieselly peeps talking about how a diesel can have as much power as a V8- of course it can if you spend the money. Much in the same way that you can get a V8 to be reliable and waterproof by spending money.
To me the only questions worth considering are:
1. Which suirts your driving style better? i like to be able to squirt the power in whenever i like so a V8 suits me. if you were careful and sensible then a diesel would win hands down
2. how important is fuel efficiency- i got 20mpg avg from my last V, but if the vehicle is used for commuting then you might as well get a diesel or an lpg conversion
3. Sound/desireability/comfort- V8 all the way for me
other questions are just a function of money/time.
The end with the classic "Me Feets wet" comment always makes me chuckle
Nige
"My seat's wet!" is the sound I hear, but I agree, it raises a smile, especially the tone of voice it's delivered in.
She sounds as if she isn't certain whether the cause is the stream itself, or a personal accident!!
David
Nice job Nige, good to see the Holy Grail has been attained at last :D
Have you tried lobbing a bucket of water at it yet as a test?
I've turned a hose on mine. Pictures don't really do it justice, it got a thorough soaking and still ran perfectly. :D It's been wellied through a shallow ford a few times as well, with no problems, but lack of four wheel drive means it'll be a while before it gets tested properly. :(
Well Done, Nige. I'll be genuinly intersted to see how this works out.
All very true. However; if you wan big power/torque from either then its big money time. Personally I prefer the simplicity of a mechanical diesel but its difficult to get the instant point and squirt. I'll be very intersted to see what Nige eventually gets from his V8 when tuned up correctly on a RR. I'm finally going to pull my finger out and get my 2.8 tuned propperly on a RR near me. Maybe we should look at doing a side by side power run at the same rolling road once both engines are running propperly.
Well Heeeelllllo Jon,
I am not going to Bite Mr W :P
Much :)
I won't mention my concern of you doing the wiring, when it took you 2 goes to wire up your own recently fitted 90 heater, and you complained for months how c*ap it was, ahem, till you turned the 2 wires around..... :lol: I think you mentioned this was the 50/50 school of wiring technique ?
Nor will I make comment about how your truck seems to have got a "Gay Boy" Pink panel painted on it :huh: .....Dear :unsure:
Nige :ph34r:
PS I HAVE PICS :D Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm :D
Trev have you got any pics of you Tonk Stringy and Jules playing in the water that time at Bunny Lane? :D
Tracy captured that on vid is didn't she? Will see if I have a copy.
Nige
ROTFLMAO :lol:
The better bodge is currently being evaluated .............. 2 techs and 2 design engineers and a systems integration engineer have been working on it all day ............ oh, and a project manager who thought that it was much better than work .................... I think these bu**ers have planned the rest of the week around it as well ! :blink: …………… mind you the project manager looked happy when I asked him for a Gantt chart and critical path …… :lol:
And the really amusing thing????
Mr Barker has NO CLUE as to how/why this system works........
rotfl.......
Jon
Ah, but he will, when we write the 'Janet & John' book of 'HFH automotive electronics' ;)
Ian
You mean something like this
Ok I will admit when I got to the others side of this 50m long 1.5m deep mud run she was only running on about six..
