X-Eng Pedal Box Lock - Naming Competition!
simonr
How would you feel about a slight flip in the location of the 'X'?
My suggestion would be...
Wait for it...
Drum roll, please...
Prot-X!!!
Yes, I know, not very imaginative, but it would then give you scope for two-word products:
Prot-X Pedal
Prot-X Brake
Etc, etc...
OK, here is an exhaustive list in alphabetical order with duplicates removed. I've only kept the first person to come up with each of them. I've also deleted the ones which did not match the X-Something formula or those that started X-Eng Something.
This evening (in the pub) we'll come up with a short list then add a poll for you to decide the overall winner!
x-(something) lock    Jad
X-ABC lock    Orgasmic Farmer
X-aegis    Lobosdoc
X-andbacon    TheRecklessEngineer
X-Anti Scrote    Phil Hancock
X-Armour    Steve 200tdi
x-asperate    Anderzander
X-Attack    Paul MC
x-block    dog1
X-Blocks    Chadler
X-Blox    Chadler
X-Box    HoSS
X-Calibur    Hybrid from Hell
X-cell    PaulMc
X-cellence    Ballcock
X-ceptional    Ballcock
X-Change    Steve 200tdi
X-Clamp    Barriesheene
X-clap trap    Orgasmic Farmer
X-Clude    Hybrid from Hell
X-Control    C18RCH
X-Cover    Big Mike
X-Cube    fozug
X-D Lock    Diff
X-defence    Jad
X-Defend    CwazyWabbit
X-Deflects    CwazyWabbit
X-Elephant    Bluehaze
X-ES    CwazyWabbit
X-Fastener    Bluehaze
X-Fend    Spearos
X-flap    Ianl1
X-Floor    Tuko
X-foot locker    Orgasmic Farmer
X-Fortify    CwazyWabbit
X-Fortress    Quagmire
X-G Lock    Diff
X-Guard    Quagmire
X-Guard Box    CwazyWabbit
X-Guard Ignition    CwazyWabbit
X-guarddog    Lobosdoc
X-Hard Guard    Crclifford
X-Hibit    Hybrid from Hell
X-hold    Lobosdoc
X-Impede    C18RCH
X-intercept    Lobosdoc
X-ist    CwazyWabbit
X-It    Les Brock
X-jam    Muddy
X-Jock    Orgasmic Farmer
X-keeper    Gazelle
X-Lox    Zoltan
X-Off    UdderlyOffRoad
X-on    Ballcock
X-ORCIST    Mike444244
X-oskeleton    Quagmire
X-otic    Ballcock
X-P Lock    Diff
X-Pedal    David Sparkes
X-pediant    Ballcock
X-Pert    Ballcock
X-Pert-Witness    Hybrid from Hell
X-plate    Borris113
X-Plode    Meccano
X-Praetorian    Bluehaze
X-pregnable    Spearos
X-Press    C18RCH
X-presso    Ballcock
X-protect    Dan110
X-protection    Maverik
X-Protex    Paul MC
Xquizit    BishBosh
X-Raptor    Warthog
X-Repel    Diablo
X-Resist    Diablo
X-Rhino    Bluehaze
X-S    Big Mike
X-safe    Dan110
X-Safety    Tuko
X-SAS    CwazyWabbit
X-Second    Tuko
X-Secure    Retroanaconda
X-Securem    Bluehaze
X-Security    Tuko
X-sentry    Lobosdoc
X-Shield    CwazyWabbit
X-Spell    Hybrid from Hell
X-Steal    C18RCH
X-Steel    C18RCH
X-Stop    Fatbloke
X-Stopper    Tuko
X-Target    Gazzar
X-Terminate    Superpants
X-Terminator    Superpants
X-theft    Lobosdoc
X-Tra Safe    Big Mike
X-tra Secure    David Sparkes
X-treme    Ballcock
X-truder    Muddy
X-TWOC    Fridgefreezer
X-vantage    Landy-Novice
X-vex    Orgasmic Farmer
X-Victim    Gazzar
X-ward    Lobosdoc
X-Watch    Diablo
X-watchdog    Lobosdoc
X-XXXX OFF    Early90
  • 3 months later...
Well I picked my X-Defend Gear Lock at Billing on Saturday.
Fitted today, really simple especially as I had the truck in bits anyway, it works really well and add another layer of protection to my Defender.
I can't fit a pedal lock at the moment as I have A/C but Si assures me he will work on that, I will however be fitting a steering lock protector when they get made.
By jasong4110 at 2012-08-12
Thanks again Si for making another great product.
Jason.
Definetly would like a one for a Series as well. I'm sure I could gas axe one to fit if it came to it.
Si,
As my Series 1 has Defender foot wells and Series 111 pedals fitted to the bulkhead is there a chance this might fit?
the only concern i have (which you will have thought of) is that the defender flooring is held down with plastic threaded blocks where the base of your plate seems to be located?
Cheers,
Marc.
Marc,
The base of the pedal lock plate actually bolts into the floor with 6 bolts it doesn't bolt into the bulkhead lip and doesn't use any of the existing fixings, you need to drill 6 new holes. All 6 bolt holes don't actually need to be used, a minimum of 3 are recommended in the instructions, some may not be usable depending what is on the other side of the floor panel.
HTH
Barry
Probably not - but if you bring it to one of the shows, I'd be happy to have a go!
As Barry says, it's bolted through the floor which is in turn held in with a load of the plastic inserts. The inserts once they have a screw in them are almost impossible to remove from underneath. I tried beating one with a hammer and it just deformed the floor! Even if you do remove them all (and there are quite a few holding the floor down), you cannot lift the floor from underneath because the pedal box holds the floor down. Also, if you are going to spend half an hour beating it with a hammer, the owner will probably wake up and come beat you with a big stick!
Si
As soon as more stock is manufactured! Billing was a sell-out on the security stuff.
I'm hoping to have more pedal box locks in about 3 weeks (in time for Peterborough) and the gear locks in a few days. I decided not to make that bit of the site live until I had something to sell!
Si
