MogLite Posted September 18, 2006 Share Posted September 18, 2006 MogLite has been balancing on some LongAcre corner weight gauges So I now know how heavy each corner is Full tank of fuel Recovery gear One pair of waffles Tool kit First aid kit and fire extinguisher Nobody on board I forget how heavy the Mog axles are, but bl00dy will suffice. The wheels and tyres are over 100kg per corner. The SuperWinch H14 on the front is massively heavy, and the husky on the back isn't light either There is a ~15L scuba tank and twin exide maxima's towards the front of the vehicle. So what do you lot reckon is the scores on the doors are for overall weight and front/rear balance ? Over to you. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 18, 2006 Share Posted September 18, 2006 3275 kg (Excluding 'Gimp Suited' driver ) Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 18, 2006 Share Posted September 18, 2006 2200kg, 1000kg up front and 1200kg at the back Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 18, 2006 Share Posted September 18, 2006 2250kg Chris Quote Link to comment Share on other sites More sharing options...
white90 Posted September 18, 2006 Share Posted September 18, 2006 2275Kg and title sorted Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 18, 2006 Share Posted September 18, 2006 including or excluding your pack lunch? Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2006 Share Posted September 18, 2006 Overall 2350kg, front 1100kg & rear 1250kg. a impressive machine Quote Link to comment Share on other sites More sharing options...
MogLite Posted September 18, 2006 Author Share Posted September 18, 2006 No packed lunch No change of clothes for the driver and someone is out by more than a 1000kgs Quote Link to comment Share on other sites More sharing options...
landrover598 Posted September 18, 2006 Share Posted September 18, 2006 a ton each end Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2006 Share Posted September 18, 2006 No packed lunch No change of clothes for the driver and someone is out by more than a 1000kgs reckon it's the stripy ginger cat Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 18, 2006 Share Posted September 18, 2006 2120kg Do I get to keep it if I am the closest? Pleeeeeeease...... Quote Link to comment Share on other sites More sharing options...
MogLite Posted September 18, 2006 Author Share Posted September 18, 2006 2120kgDo I get to keep it if I am the closest? Pleeeeeeease...... Yes - you can have it if you are the closest Alas you aren't No the offer doesn't apply to anyone else - just BogMonster - and he's had his go Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 18, 2006 Share Posted September 18, 2006 1850 ready to party 2650 including food rider 2950 including drivers spare "outfit" 4500 including driver 4950 including drivers "reference" magazines Im glad you kept the wipe clean covers in Andy - much more hygenic Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted September 18, 2006 Share Posted September 18, 2006 1875 kgs. Paul Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 18, 2006 Share Posted September 18, 2006 Group 7 Les. Quote Link to comment Share on other sites More sharing options...
reads90 Posted September 19, 2006 Share Posted September 19, 2006 Andy Recon it is about 1500 maybe abit more but not alot. could be nocking on the door of 2 ton but not anymore Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 19, 2006 Share Posted September 19, 2006 Yes - you can have it if you are the closestAlas you aren't No the offer doesn't apply to anyone else - just BogMonster - and he's had his go Git Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 19, 2006 Share Posted September 19, 2006 hmmmmmm tricky one to guess, heavy axles and wheels but none of te niceities like windows or a stereo i reckon 1100 front and 1350 rear makin it 2450kg Quote Link to comment Share on other sites More sharing options...
Petergg Posted September 19, 2006 Share Posted September 19, 2006 2540kgs, or plus 50kgs if you add any more paint. Peter Quote Link to comment Share on other sites More sharing options...
jules Posted September 19, 2006 Share Posted September 19, 2006 2540kgs, or plus 50kgs if you add any more paint.Peter Quote Link to comment Share on other sites More sharing options...
Daan Posted September 19, 2006 Share Posted September 19, 2006 Will you change the name of moglite if it is over 2500kg? Looks good andy. Daan Quote Link to comment Share on other sites More sharing options...
will_warne Posted September 19, 2006 Share Posted September 19, 2006 I'm going to say a nice round 2300 kg; 1100 on the front, 1200 on the rear. Light you're truck certainly won't be but it doesn't have any glass, trim, soundproofing or bodywork to speak of. Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 19, 2006 Share Posted September 19, 2006 1928KG Fronts 410KG each, Rears 554KG each Steve Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted September 19, 2006 Share Posted September 19, 2006 So it's obviously less than 2275kg. There's nearly a tonne in the wheels & axles, so I think 1500kgs all up is a bit optimistic... Hmmm... Chassis, cage & engine/driveline half a tonne? That's 1500 already. Bits & bobs, fuel, winches. 1999kgs. But I suspect the true figure will start with a '2'? Tricky one. Al. Quote Link to comment Share on other sites More sharing options...
MogLite Posted September 19, 2006 Author Share Posted September 19, 2006 Last chance saloon for guesses We've got Reads 90 who has guessed at 1500kg. Which is about 350kgs less than Perv's challenge spec 88" Bowler - which would be a helluva achievement - what a muppett All the way to Nige's red-wine fuelled 3 tonne + There isn't a prize BTW Quote Link to comment Share on other sites More sharing options...
