B reg 90 Posted April 29, 2013 Share Posted April 29, 2013 My info on Volvos is:Standard Volvo front axle weighs 150kg, the rear 130kg. I'd guess that going discs shaves a little off. I weighed a front at 140KG and a rear at 120KG with a portal tech disk conversion. I think that a rover front axle with ARB, ashcroft shafts etc and a 10mm thick diff pan was 120KG. A rear rover with disk brakes, normal diff pan and ARB was ~ 100 KG. Adrian Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted April 29, 2013 Share Posted April 29, 2013 Have a couple of full-width Dana44 axles coming my way from a Cherokee Chief, will weigh them when I get them Quote Link to comment Share on other sites More sharing options...
o_teunico Posted April 29, 2013 Share Posted April 29, 2013 I think that it will also be interesting to know the weight of steel vs alloy wheels, "big" (35" and so on) tyres compared with stock 205s, rear seats (that will be usefull when preparing overlanding vehicles, where rear seats are normally taken away to gain cargo space). Quote Link to comment Share on other sites More sharing options...
Wingnut Posted April 29, 2013 Share Posted April 29, 2013 The second row seats and the two rear fold down seats from a Discovery 2 weigh approximately 190 pounds on our bathroom scales - SWMBO was not home that day! This is a figure remembered from some time ago, but I think it is fairly accurate. I can't remember the exact figures, but I do recall being very surprised that a 5/6mm steel winch bumper was only a mater of a few pounds heavier than the standard item that came off the same car (again according to our bathroom scales - and this time I remembered to wipe them clean). Peter. Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 29, 2013 Share Posted April 29, 2013 I think your bathroom scale may have just been at its upper limit, no way that a winchbumper is the same weight as a stock bumper. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 30, 2013 Share Posted April 30, 2013 If you scales are like my wife's.........................there very accurate.....hat, coat, running hard. Mike Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 30, 2013 Share Posted April 30, 2013 Hmmmm, brave or foolish Mike? I'm thinking the latter....... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 30, 2013 Share Posted April 30, 2013 I have a Mazda SL35Ti in the garage which I would be interested to know the weight of if anyone has any idea? I would measure it if A. I had a suitable measurerer and B. I wasn't 450 miles away! Quote Link to comment Share on other sites More sharing options...
Wingnut Posted April 30, 2013 Share Posted April 30, 2013 I think your bathroom scale may have just been at its upper limit, no way that a winchbumper is the same weight as a stock bumper. You would be surprised how much steel reinforcement and fittings the plastic is covering. Peter. Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 30, 2013 Share Posted April 30, 2013 You would be surprised how much steel reinforcement and fittings the plastic is covering.Peter. I've lifted both, the winchbumper is definitely a fair bit heavier. Perhaps that a tubular one can come close... Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted May 3, 2013 Share Posted May 3, 2013 Well not an engine component, but as I had my Krawler off today I thought I might as well put it on the scale. Info: 35"x13,5"-15" BFG Krawler on 8"x15" Modulars with beadlocks (somewhat heavy version with a rolled piece of flat-stock to close the bolts off) Tyres are slightly cut/grooved but not much weight removed, a kilo tops! Result: 52,5Kg Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 3, 2013 Share Posted May 3, 2013 Just happened across a weight for Renault TRM2000 portal axles following the "Stage 1 saga" thread: TYPICAL AXLE WEIGHT LBS (KG) = 992 lbs. (450kg) Zoinks! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 3, 2013 Share Posted May 3, 2013 Just happened across a weight for Renault TRM2000 portal axles following the "Stage 1 saga" thread:TYPICAL AXLE WEIGHT LBS (KG) = 992 lbs. (450kg) Zoinks! I thought he was being flippant when he said they were nearly half a tonne ....... obviously not .... still should stop you falling over Quote Link to comment Share on other sites More sharing options...
B reg 90 Posted May 3, 2013 Share Posted May 3, 2013 There heavy!!!!! Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted May 3, 2013 Share Posted May 3, 2013 There heavy!!!!! LOL, kinda are though but would hopefully keep the wheels pointing down most of the time. That weight is for the fronts, I think the rears are about 50 Kg's lighter. I would like to weigh them myself somehow just to know. Same with the GMC 6.2. I've seen weights around the 300Kg mark for it but not sure. It is tiny and it is quite light. Getting one of these in the post in the next few weeks if all goes according to plan: You can add a Praga V3s portal axle weighs 332Kg. Same stud pattern as the TRM which is handy for me. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted May 8, 2013 Share Posted May 8, 2013 Found this at Pirate (Nissan H233B rear axle) Axle housing is the same in size, y61 is stronger at some places.Y60/Y61 axle weights 136 kilogramempty axle = 32 kgdiff clock = 40 kg2x axle shaft + wheel hub = 34kgBrake disks = 20kgbrake calliper = 10kg Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 8, 2013 Author Share Posted May 8, 2013 O_teunico are those weights for a front or rear y60 axle? The don't sound right some how 20kg for a pair of discs??? I have plenty of y60 stuff I'll have a measure tonight. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted May 8, 2013 Share Posted May 8, 2013 The data about Nissan diff was taken from http://www.pirate4x4.com/forum/nissan/641356-have-you-ever-busted-h233b-rear-axle-shaft-6.html Aparently H233 is used front and rear and HD H260 only rear Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted May 11, 2013 Share Posted May 11, 2013 Have weighed a couple more of my wheel combo's: From the left: Series 3 wheel heavily lightened with a 205 RRC tyre with no tube: 24,5kgs Series 1 wheel completely stock with 600x16" tyre AND tube: 24,5kgs And lastly, 285/80x16" Goodyear on wolfrace alloy with Heavy Duty 900x16" tube: 31,5kgs Now I've heard so many times that alloys are no lighter than stock steel wheels, and while this may well be the case with LR Alloys, it certainly isn't with my wolfrace's. Compare 31,5 kgs with the 52,5 kgs of my Krawlers on beadlocks and remember that these measure the same height but is a tad narrower, and you really see a weight difference. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted May 11, 2013 Share Posted May 11, 2013 I have also been weighting wheels and tyres at my bro´s place. 109" steel 16x5.5" = 11.5kg Discovery steel 16x7" = 13.5kg Discovery alloy NTC7739 16x7" = 10kg Tyres: (Left to right) Hankook Dynamic RF-04 205/80R16 104 load rating -725mm diametre -12kg Recip Trial remould 205R16 -750mm diametre -18kg! Insa Turbo T&C remould (50% tread) 7.50R16 -775mm diametre -17.5kg Everything weighted with a 25kg fish scale From memory my bro said that a 109" Santana six cylinder Station Wagon bare chassis was 240kg - Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 23, 2013 Share Posted May 23, 2013 The don't sound right some how 20kg for a pair of discs??? I remembered this earlier whilst fitting an Alcon brake kit to a Land Cruiser, the Alcon discs are marginally larger than stock (5-10mm ish) and have separate bells so there's probably a few hundred grammes in the 20 or so bolts that you wouldn't have on standard discs but the pair of Alcon discs and bells weighed 24kgThe Alcon calipers are larger than stock four piston aluminium calipers and weigh 10kg for the pair. OE Toyota callipers are cast steel and are far heavier, though I didn't get chance to get an exact weight Dan, are the Nissan brake components similar in scale to Land Cruiser parts? 100 series in this case Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 23, 2013 Author Share Posted May 23, 2013 Dan, are the Nissan brake components similar in scale to Land Cruiser parts? 100 series in this case Nothing like mate, patrols are seriously anemic in the brake department, The brakes on my y60 are about the same size as 60 series, Y61 discs are nearly the same size as '94 on 80 series, but the patrol is on crappy sliding calipers Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 16, 2013 Share Posted June 16, 2013 iirc mog 404s are 460kg per set (220/240) Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 10, 2013 Share Posted October 10, 2013 Fully dressed 56A type J R380 59.15KG Measured on digital bathroom scales. Within the max weight of the scales even with me standing on them to. Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted October 13, 2013 Share Posted October 13, 2013 Evening.... not sure if this helps but as my truck is currently in bits... what would you like me to weigh? LS3 fully dressed 6l90e atlas case? bare 44 bogger-v's built up? bare 40" maxxis sticky? spidertrax pro series axles casing? my portal boxes? rd 99 air locker in alloy case? what type of scales are you guys using?.. Quote Link to comment Share on other sites More sharing options...
