dirtydiesel
Engine and Component weights
My info on Volvos is:
Standard Volvo front axle weighs 150kg, the rear 130kg.
I'd guess that going discs shaves a little off.
I weighed a front at 140KG and a rear at 120KG with a portal tech disk conversion.
I think that a rover front axle with ARB, ashcroft shafts etc and a 10mm thick diff pan was 120KG. A rear rover with disk brakes, normal diff pan and ARB was ~ 100 KG.
Adrian
Share this post
Link to post
I think that it will also be interesting to know the weight of steel vs alloy wheels, "big" (35" and so on) tyres compared with stock 205s, rear seats (that will be usefull when preparing overlanding vehicles, where rear seats are normally taken away to gain cargo space).
Share this post
Link to post
The second row seats and the two rear fold down seats from a Discovery 2 weigh approximately 190 pounds on our bathroom scales - SWMBO was not home that day! This is a figure remembered from some time ago, but I think it is fairly accurate.
I can't remember the exact figures, but I do recall being very surprised that a 5/6mm steel winch bumper was only a mater of a few pounds heavier than the standard item that came off the same car (again according to our bathroom scales - and this time I remembered to wipe them clean).
Peter.
Share this post
Link to post
I think your bathroom scale may have just been at its upper limit, no way that a winchbumper is the same weight as a stock bumper. :hysterical:
Share this post
Link to post
If you scales are like my wife's.........................there very accurate.....hat, coat, running hard.
Mike
Share this post
Link to post
I have a Mazda SL35Ti in the garage which I would be interested to know the weight of if anyone has any idea?
I would measure it if A. I had a suitable measurerer and B. I wasn't 450 miles away!
Share this post
Link to post
You would be surprised how much steel reinforcement and fittings the plastic is covering.
Peter.
Share this post
Link to post
Peter.
I've lifted both, the winchbumper is definitely a fair bit heavier. Perhaps that a tubular one can come close...
Share this post
Link to post
Well not an engine component, but as I had my Krawler off today I thought I might as well put it on the scale.
Info:
35"x13,5"-15" BFG Krawler on 8"x15" Modulars with beadlocks (somewhat heavy version with a rolled piece of flat-stock to close the bolts off)
Tyres are slightly cut/grooved but not much weight removed, a kilo tops!
Result: 52,5Kg
Share this post
Link to post
Just happened across a weight for Renault TRM2000 portal axles following the "Stage 1 saga" thread:
TYPICAL AXLE WEIGHT LBS (KG) = 992 lbs. (450kg)
Zoinks!
I thought he was being flippant when he said they were nearly half a tonne ....... obviously not .... still should stop you falling over
Share this post
Link to post
There heavy!!!!!
LOL, kinda are though but would hopefully keep the wheels pointing down most of the time.
That weight is for the fronts, I think the rears are about 50 Kg's lighter. I would like to weigh them myself somehow just to know.
Same with the GMC 6.2. I've seen weights around the 300Kg mark for it but not sure. It is tiny and it is quite light.
Getting one of these in the post in the next few weeks if all goes according to plan:
You can add a Praga V3s portal axle weighs 332Kg.
Same stud pattern as the TRM which is handy for me.
Share this post
Link to post
Found this at Pirate (Nissan H233B rear axle)
Axle housing is the same in size, y61 is stronger at some places.
Y60/Y61 axle weights 136 kilogram
empty axle = 32 kg
diff clock = 40 kg
2x axle shaft + wheel hub = 34kg
Brake disks = 20kg
brake calliper = 10kg
Share this post
Link to post
O_teunico are those weights for a front or rear y60 axle?
The don't sound right some how 20kg for a pair of discs???
I have plenty of y60 stuff I'll have a measure tonight.
Share this post
Link to post
Have weighed a couple more of my wheel combo's:
From the left:
Series 3 wheel heavily lightened with a 205 RRC tyre with no tube: 24,5kgs
Series 1 wheel completely stock with 600x16" tyre AND tube: 24,5kgs
And lastly, 285/80x16" Goodyear on wolfrace alloy with Heavy Duty 900x16" tube: 31,5kgs
Now I've heard so many times that alloys are no lighter than stock steel wheels, and while this may well be the case with LR Alloys, it certainly isn't with my wolfrace's.
Compare 31,5 kgs with the 52,5 kgs of my Krawlers on beadlocks and remember that these measure the same height but is a tad narrower, and you really see a weight difference.
Share this post
Link to post
I have also been weighting wheels and tyres at my bro´s place.
109" steel 16x5.5" = 11.5kg
Discovery steel 16x7" = 13.5kg
Discovery alloy NTC7739 16x7" = 10kg
Tyres:
(Left to right)
Hankook Dynamic RF-04 205/80R16 104 load rating
-725mm diametre
-12kg
Recip Trial remould 205R16
-750mm diametre
-18kg! :o
Insa Turbo T&C remould (50% tread) 7.50R16
-775mm diametre
-17.5kg
Everything weighted with a 25kg fish scale
From memory my bro said that a 109" Santana six cylinder Station Wagon bare chassis was 240kg
Share this post
Link to post
I remembered this earlier whilst fitting an Alcon brake kit to a Land Cruiser, the Alcon discs are marginally larger than stock (5-10mm ish) and have separate bells so there's probably a few hundred grammes in the 20 or so bolts that you wouldn't have on standard discs but the pair of Alcon discs and bells weighed 24kg
The Alcon calipers are larger than stock four piston aluminium calipers and weigh 10kg for the pair. OE Toyota callipers are cast steel and are far heavier, though I didn't get chance to get an exact weight
Dan, are the Nissan brake components similar in scale to Land Cruiser parts? 100 series in this case
Share this post
Link to post
Nothing like mate, patrols are seriously anemic in the brake department,
The brakes on my y60 are about the same size as 60 series,
Y61 discs are nearly the same size as '94 on 80 series, but the patrol is on crappy sliding calipers
Share this post
Link to post
Fully dressed 56A type J R380 59.15KG
Measured on digital bathroom scales. Within the max weight of the scales even with me standing on them to.
Share this post
Link to post
Evening.... not sure if this helps but as my truck is currently in bits... what would you like me to weigh?
LS3 fully dressed
6l90e
atlas case?
bare 44 bogger-v's built up?
bare 40" maxxis sticky?
spidertrax pro series axles casing?
my portal boxes?
rd 99 air locker in alloy case?
what type of scales are you guys using?..
Share this post
Link to post
