Daan Posted October 13, 2013 Share Posted October 13, 2013 Evening.... not sure if this helps but as my truck is currently in bits... what would you like me to weigh? LS3 fully dressed 6l90e atlas case? bare 44 bogger-v's built up? bare 40" maxxis sticky? spidertrax pro series axles casing? my portal boxes? rd 99 air locker in alloy case? what type of scales are you guys using?.. All of it.... And while you are at it: we would love to see a build thread of your truck on here! Daan Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted October 13, 2013 Author Share Posted October 13, 2013 Evening.... not sure if this helps but as my truck is currently in bits... what would you like me to weigh? LS3 fully dressed 6l90e atlas case? bare 44 bogger-v's built up? bare 40" maxxis sticky? spidertrax pro series axles casing? my portal boxes? rd 99 air locker in alloy case? what type of scales are you guys using?.. I have been using a 500kg digital hanging scale, you could borrow it if you wanted Nathan, Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted October 14, 2013 Share Posted October 14, 2013 Hi dan Once i have my new concrete floor down this weekend i will be able to try and weigh the parts. What do you suspend the scales on? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 14, 2013 Share Posted October 14, 2013 Hi dan Once i have my new concrete floor down this weekend i will be able to try and weigh the parts. What do you suspend the scales on? His teeth Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted October 14, 2013 Author Share Posted October 14, 2013 Hi dan Once i have my new concrete floor down this weekend i will be able to try and weigh the parts. What do you suspend the scales on? Engine crane works well, His teeth P**s off!!! Quote Link to comment Share on other sites More sharing options...
Nigelw Posted January 11, 2014 Share Posted January 11, 2014 Anyone know the weight of a 2ltr T series engine as fitted in early Discovery MPis? Quote Link to comment Share on other sites More sharing options...
Daan Posted January 13, 2014 Share Posted January 13, 2014 Fully dressed 56A type J R380 59.15KG Measured on digital bathroom scales. Within the max weight of the scales even with me standing on them to. Is this with or without transferbox? Daan Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 13, 2014 Share Posted January 13, 2014 That is without transfer box Daan, but with bell housing and the levers. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 21, 2014 Share Posted January 21, 2014 I'll try and add some weights to this when I start the strip down of the 90 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 17, 2017 Share Posted December 17, 2017 As topic says, I'm obsessed with weight on different components on our dear Landys, so I thought why not make an official thread about it that myself and all others can contribute too along the way? Now If I could get the Admin to pin it, it would be even better! 2,5TD engine complete: 250kgs 3,5V8 with LT95 Complete: 320kgs Stripped but driving RRC 3,5 with LT95: ~950kgs There's a little something to start with, I'll add as I go along with my projects  Quote Link to comment Share on other sites More sharing options...
TSD Posted December 17, 2017 Share Posted December 17, 2017 I had this feeling of deja vu... Â Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 17, 2017 Share Posted December 17, 2017 Wow and I even contributed myself.. But that's what you get when threads just slide into oblivion, which is why I would like it pinned. Could even just be the other one, then I could move my info over there. Much the same with the Propshaft length thread that I think FF started, I needed it a while back and couldn't for the life of me find it again! I can't remember what the title was so finding it was far from easy.. Searching for 'propshaft length' on here gives like a billion hits  Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 17, 2017 Share Posted December 17, 2017 Is this the prop lengths thread if so it was mine. mike Quote Link to comment Share on other sites More sharing options...
Daan Posted December 17, 2017 Share Posted December 17, 2017 Now Merged with the other weights thread. Shall I pin it to the top? Â Daan Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 17, 2017 Share Posted December 17, 2017 49 minutes ago, miketomcat said: Is this the prop lengths thread if so it was mine. mike it just might be  Sure looks like the one I recall, just thought it was FF 13 minutes ago, Daan said: Now Merged with the other weights thread. Shall I pin it to the top?  Daan I would love so  Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 19, 2017 Share Posted December 19, 2017 Got another one today, as my old man is in the process of swapping his 5MB 2,25D for a 2,5TD I was able to weigh both. And honestly I expected them to be very similar. but the 2,5TD a bit heavier. But how wrong was I! The 2,25 was 20kgs heavier! Granted the clutch is fitted to it still and so is the alternator, none of that was on the 2,5TD, but it had the downpipe on. So I would say a maximum of 10kgs in those components, so that still leaves the 2,25 10kgs heavier. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 20, 2017 Share Posted December 20, 2017 Stands to reason the 2.25 would have a bit more metal around the bores than the 2.5 (if it's a bore difference, that is), but if that's worth 20kg... doubtful. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 20, 2017 Share Posted December 20, 2017 4 hours ago, elbekko said: Stands to reason the 2.25 would have a bit more metal around the bores than the 2.5 (if it's a bore difference, that is), but if that's worth 20kg... doubtful. Yes a good point, but I think its only stroke. Anyways its incredible that not even the turbo is enough to make the weights more similar. I was thinking that perhaps the timing belt setup is lighter than the all steel chain setup? Must several things that add up.. Â Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 20, 2017 Share Posted December 20, 2017 Both had oil in? There's 7KG there ish... Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 20, 2017 Share Posted December 20, 2017 Clutch covers and alternators are relatively heavy, and I suspect the aluminium timing case and Kevlar belt are a lot lighter than the steel case and chain of the 2.25.  The heads, blocks and pistons, cam shaft and rocker gear would be the same, but the 2.5 crank is probably a little heavier. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 20, 2017 Share Posted December 20, 2017 5 hours ago, Bowie69 said: Both had oil in? There's 7KG there ish... Yup, though to be fair some of it from the 2,5 had drained as it had been tipped over, but not more than a couple of liters max 5 hours ago, Snagger said: Clutch covers and alternators are relatively heavy, and I suspect the aluminium timing case and Kevlar belt are a lot lighter than the steel case and chain of the 2.25.  The heads, blocks and pistons, cam shaft and rocker gear would be the same, but the 2.5 crank is probably a little heavier. Yes I think you're quite right, but I'm still amazed that the 2,25 is actually heavier. Just look at the two fuel pumps and its much larger on the 2,5.. I'm getting a spare 2,25P 3MB in the near future, interesting to see what that weighs. Should be lighter with only 3MB. And it'll give me a good indication how much weight I can loose on the 80" if I choose another engine Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 28, 2018 Share Posted January 28, 2018 Another one: Rover V8 3.5 SD1 Vitesse (190bhp) 180kgs: Flywheel is missing but the table should make up for that. Alternator and starter is laying on top and both Cast exhaust mnaifolds are fitted so pretty accurate Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted April 8, 2018 Share Posted April 8, 2018 Some more weights for the list: The legendary Toyota 3B from the BJ's with a crude homemade adaptor for LR trans, made out of thick steel plate. Wet and ready to run: And a Cooper Discoverer STT 37"x13,5"-16" on a 10" Modular: 54,5 kgs Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted November 14, 2018 Share Posted November 14, 2018 A few weights for the the thread. A sumb front axle complete with brakes is 324Kg. add some 16.00x20 Michelins with Daf wheels (why would you?) was 752Kg. A cummins 6Bt is 480kg with ve pump and SAE3 flywheel housing. A 6Bt with P pump and SAE2 flywheel housing is 520Kg. An LT230 without handbrake or oil is 48Kg An Eaton 6 speed with hydraulic PTO is 202Kg A weight I stole from the Bader site for one of their 404 axle builds at 205Kg An LT95 with 101 bellhousing plus winch pto at 142Kg A front of a C304 Volvo with no rear body on it at 986Kg An A4 Audi quattro gearbox at 78Kg. I can update a TRM2000 rear axle at 335Kg and not the four hundred and something as quoted by a website somewhere. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted November 20, 2018 Share Posted November 20, 2018 Great stuff Jamie, that c304 is surprisingly light at the front end, especially considering it has 6cyl engine Quote Link to comment Share on other sites More sharing options...
