42 minutes ago, Anderzander said:
What you are doing is as much fabrication in an afternoon as the average car nut would do in a dark garage over a number of years.
Got to get the most use out of garage time....
Regards Stephen
Regards Stephen
:i-m_so_happy:
Couldn't agree more .
Excellent progress Stephen , now it's all coming together the excitement is building for so many of us , not just you :)
Loving all the real steel going into this chassis refurb .
Steve
  • Like 1
  • Thanks 1
That's it for today, might get welding done tomorrow
Some 3mm plate
sides cut and shaped equal
New sides Welded inside and out
20220616_132036.thumb.jpg.dadf2c72f11ccb3eeb7e788d479e1e32.jpg20220616_132050.thumb.jpg.22d3e4a5a37111b429de6bc90a0b8957.jpg
Cutting top and bottom sections
When you don't check where your workmate is in relation to your cut
stitched into position
Regards Stephen
  • Like 4
Outstanding.
Apologies if you have already mentioned it, are you doing any reinforcement work to the a-frame mountings or are they already made of oil rig?
I'm guessing the mog axles put most of their leverage into the A frame? or do the chassis mounts also take a hammering hence the 10mm?
Chris
  • Thanks 1
1 hour ago, MECCANO said:
Outstanding.
Chris
A frame mounting points all ready oil rig.........
Only the mounting bolt area is 10mm, landrover standard is 2x3mm so I made mine bigger, the rest is 6mm and longer so it can be welded to more of the chassis regards Stephen
  • Like 1
My wee bit of fabrication today. Went to go and fit the Southdown Guard and found an exhaust hanger rusted through so taking a leaf out of Stephen's book it's made from some 5mm plate because it saved me walking to my scrap pile 100 yards away.
