U-Pol Raptor Chassis
Hi Folks!
I'm new here but technically I receive 80% of my advice from this forum anyway so I feel like I know you all!
I'm about to start the dreaded chassis replacement on my 90 TD5 in a couple of weeks so i'm planning on doing a mini-diary in case anyone is interested. Hopefully there won't be any images of an upside down land rover or gratuitous injuries to my person....
Re the galv chassis, I think i'm going to go with either Richards or Sheilder from TerrainTech. There's the option to have the whole thing coated in U-Pol Raptor bed liner which i'm quite tempted by. I like a black chassis and my other options are to have it powder coated (Sheilder do that themselves) or paint it myself with etch primer/Hammerite. Does anyone have any experience with the Raptor coating? Is it worth going for? Any issues with chassis/body fitment or earthing points?
Cheers!
Hammerite is a great product - for applying to stone indoors.
Don't use it on metal, unless you like welding.
I'm going to use the raptor on my chassis, t-wash, raptor primer and then raptor, I think it's the best way to go, from what I've read.
G.
I'd not go with the raptor - I've found it chips easily on corners, on a chassis this will allow water behind it and it will creep under the rest of the coating and it will peel off in small sheets.
If you dont like the galv look paint the chassis with T wash to get a key then use black chassis paint - "the paint man" does a good quality chassis paint
If you really want to use a coating you can get the chassis plastic coated - I've done this on bumpers and wheel carriers, it's very durable but more suited to a show or road vehicle and will eventually get damaged off road or from stone chips.
However you could go the Line-x bedliner route this is far superior to raptor and far more durable but is also much more expensive than raptor.
Just my 2c based on experience.
Regards
Gren
Edited by Gren_T
G.
I've had a similar experience with Hammerite before. I was hoping they'd sorted the formula out but all evidence and testimonials are to the contrary so i think i'll take your advice and leave it be.
I'd like to paint the chassis myself but in my experience i can never get paint to stick properly and have always ended up with either rust showing through (Hammerite) or flaking paint. Is it easy enough to get a decent, durable finish with T wash and chassis paint?
Hammerite is based on sand, I think, so it expands and contracts at a different rate to steel. Landrover chassis flex, the hammerite doesn't, and so it cracks, let's in water. Etc.
If you go down the paint route, get as much zinc primer as you can.
G.
Not used Raptor on my chassis, I just used red-oxide primer followed by chassis black followed by an annual waxoyl.
I have however rebuilt a large trailer and used Raptor coat, I went for black on the chassis and green on the topsides (to match the Landrover) and I can confirm that it does indeed chip off on the corners and high use areas and water gets behind it and if there are any rust blisters in places sheets of the stuff fakes off. It's also quite hard to clean due to the textured finish, I am never sure about putting a pressure washer on it in case it just forces more water behind it.
In my opinion, the brittleness of the finish would work against you using it on the chassis as its going to get chipped with every sone the flies up and once it starts to lift it's going to be a real PITA to refinish.
That's interesting, and disappointing.
I'm trying to get away from the annual waxoil routine, so the search goes on for the apply once, and forget, solution.
Can you get line-x for diy application?
G.
On 8/13/2018 at 1:20 PM, landroversforever said:
T-wash and then two coats of POR15 on my chassis. It's held up to being bashed in the workshop OK, even on the edges.
This is important for Ross as his chassis will be in the workshop for ever 😂
Mo
  • Haha 1
and not to forget the old school method of spraying old engine oil on the chassis - leaves a nice smooth black patina, it's free. doesn't chip off and you can do it as often as you like. I used to do it on an old td5 disco rear chassis and it kept the rust at bay - that is until the 15p head decided to implode🤤. as long as you leave time for the oil drips to drip there's no oil on the road either. you do however need an old driveway with covers to do it on - a nice block paved suburban drive is not ideal!😲
I heard of a similar approach to treating the internals. Someone told me to park on a slop (nose up) and then pour used engine oil through the dumb irons and let it work it's way to the rear cross member. It almost seems too easy but sometimes the old tricks are the best ones!
If the chassis is galvanized, presuming it IS a new one ? I reckon you are best off T-washing it and brush painting good old chassis paint on it.
I know its relatively soft, but its cheap and is easily touched in or recoated. Once you get a few coats on it, is adds some age, which I like !
Depends what you are trying to achieve.  A workhorse, to disguise it, or make it a bit flash (thief magnet)
Waxoyl is another sh1te Hammerite group product. Wouldn't waste ANY money on it all.  For a few quid more, buy either Bilt Hamber, or Dinitrol and get something that actually works..
Yup, it'll be a new galv chassis. It's certainly not a flashy wagon but i also want to stay away from the farm truck look. Essentially i'm looking for a robust matt black coating that won't discolour too quickly. Also want to stay away from brush marks but maybe that's a bridge too far without investing in some spraying equipment.
Hammerite is horrific and i've never had a good result after i've used it. Doesn't matter how much i prime and prep, rust always shows through pretty quickly. I do like their waxoyl though and i've had some good results with that when i'm already working with a clean surface. I think T wash and then a buzzweld product for the top coat is the combo i'll go with.
On 8/22/2018 at 11:51 AM, landroversforever said:
IMO the engine oil ones are not a good idea.... No matter how you do it you're going to end up leaving oil on the roads. Not great for bikers and other road users.
I can guarantee that never happens on my vehicles! - the idea is not to leave gallons sloshing around the chassis but just a thin coating.
I sprayed Buzzweld CIO onto my new chassis after T-wash and a degrease. I used a Schutz gun for the second coat after brushing the first and it really finishes well, a nice matt finish.
Edited by Peaklander
A picture's worth...
